Superman1001
How to install XBMC?
Wed Aug 29, 2012 4:26 pm
when i try to install xbmc i get this:
[email protected]:/home/pi# apt-get install xbmc
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
 xbmc : Depends: xbmc-bin (>= 2:11.0~git20120510.82388d5-1) but it is not installable
        Depends: xbmc-bin (< 2:11.0~git20120510.82388d5-1.1~) but it is not installable
        Recommends: python-qt3 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
what have i to do?
onirrapdivad
Re: How to install XBMC?
Fri Sep 14, 2012 4:36 am
I have the same problem...
Licaon_Kter
Fri Sep 14, 2012 2:07 pm
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install -f
output?
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
onirrapdivad
Fri Sep 14, 2012 5:30 pm
I have done the first two steps before,
What does "sudo apt-get install -f" mean?
redhawk
Fri Sep 14, 2012 5:33 pm
-f probably means "forced" even if there are errors regarding the request.
Richard S.
abishur
Fri Sep 14, 2012 5:40 pm
Just to make sure, you are using Raspbian correct? And the latest image that is obtainable off the downloads page? And you have the latest firmware (well apt-get update && upgrade should get you that, but I like using hexxeh's rpi-update tool just to be safe)
Dear forum: Play nice ;-)
plugwash
Fri Sep 14, 2012 6:50 pm
The debian XBMC packages are not built in raspbian and even if they were they would not be much use.
Various people have prepared Pi specific XBMC packages but they are not currently included in raspbian itself (they may be in future but there are other issues that need to be dealt with first).
onirrapdivad
Fri Sep 14, 2012 8:21 pm
plugwash wrote:The debian XBMC packages are not built in raspbian and even if they were they would not be much use.
Why wouldn't the packages be of much use?
I used synaptic to find the packages, they are there but I always get an error when I try to install them; something to do with broken packages.
Could you link us to a discussion which explains the issues which you speak of?
ghans
Fri Sep 14, 2012 9:41 pm
mattanl
Fri Sep 14, 2012 10:01 pm
I installed XBMC using this link
http://www.raspbian.org/RaspbianXBMC
It took few hours (because it downloads the XBMC source code and then compiles it) but it worked.
onirrapdivad
Sun Sep 16, 2012 6:10 pm
mattanl wrote:I installed XBMC using this link
Has anybody else had success with this method?
MvK68
Sun Sep 16, 2012 7:52 pm
Yep, several times!
Return to “Raspbian”
