nomis05
Wifi problem (TP Link) on official Raspbian
Wed Aug 29, 2012 2:42 pm
Hey,
I'm using a TP Link WN 821v3 Wifi stick with my raspberry Pi.
A 1A powered USB Hub is connected to the bottom USB port providing enough power for the Stick. To the top port there is a Logitech wireless adapter connected.
With OpenElec, Xbian and this Raspbian Release I don't have any problems and the Stick works really good.
But with any official (17-05 and 18-06) it doesn't work and I keep getting these errors. Because it works with the other Distributions I'm a bit confused and I'm asking for help ...
[   24.277467] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
[   29.287473] smsc95xx 1-1.1:1.0: eth0: Failed to write register index 0x00000114
[   34.297471] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
[   38.898278] usb 1-1.3.1: USB disconnect, device number 6
[   38.937906] ath: Failed to wakeup in 500us
[   38.973626] ath: Failed to wakeup in 500us
[   39.006161] ath: Failed to wakeup in 500us
[   39.158179] usb 1-1.3.1: ath9k_htc: USB layer deinitialized
[   50.195808] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
[  770.527720] usb 1-1.3.1: new high speed USB device number 7 using dwc_otg
[  770.629211] usb 1-1.3.1: New USB device found, idVendor=0cf3, idProduct=7015
[  770.629246] usb 1-1.3.1: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[  770.629267] usb 1-1.3.1: Product: USB WLAN
[  770.629281] usb 1-1.3.1: Manufacturer: ATHEROS
[  770.629304] usb 1-1.3.1: SerialNumber: 12345
[  770.829837] usb 1-1.3.1: ath9k_htc: Transferred FW: htc_7010.fw, size: 72992
[  771.887431] usb 1-1.3.1: Service connection timeout for: 256
[  771.887474] ath9k_htc 1-1.3.1:1.0: ath9k_htc: Unable to initialize HTC services
[  771.887504] Failed to initialize the device
[  771.888970] ath9k_htc: probe of 1-1.3.1:1.0 failed with error -22
Having it connected from the beginning makes it hang on boot because of the auto network settings and gives that smsc95xx error. When i disconnect the stick it continues booting but when connecting again there is that 'failed to initialize device' error. The correct firmware is already provided with the official raspbian image.
nomis05
Re: Wifi problem (TP Link) on official Raspbian
Thu Aug 30, 2012 5:02 pm
Solved by installing the 'untested' firmware:
https://github.com/raspberrypi/linux/issues/60
deb http://archive.raspberrypi.org/debian/ wheezy main untested
eix
Sun Dec 02, 2012 2:47 pm
Is that untested firmware now in stable?
I am asking because I also have a Sitecom 8-ports hub and experiencing the random ethernet dead issue, and also never been able to connect my RTL8191S wifi dongle until recent firmware/kernel upgrades..
Return to “Raspberry Pi OS”
