tgenc
playing HD videos
Mon Aug 08, 2016 11:45 am
hello there,
I am using raspberrt pi 3 and raspbian jessie. There is no problem to play videos with omxplayer but there is no GUI. I found a basic GUI for omxplayer but it's so poor. and also some subtitle characters does not show.
I have tried to open videos with SMPlayer and VLC but hardware accelaration does not work. so CPU usage is getting more than 90% even does not play the video. I have tied to configure video output driver to vdpau, gl3 etc.. but couldn't work.
My question is, is it possible to play HD videos with another popular video player like SMPlayer, VLC? do I need to make any configuration?
Thanks and best regards
Tanzer
Re: playing HD videos
Mon Aug 08, 2016 11:54 am
tgenc wrote:hello there,
Tanzer
Have you tried " omxplayerGUI - GUIs for omxplayer including an audio player, a video player and a media player frontend." ??
viewtopic.php?t=40860
Asus ChromeBox 3 Celeron is my other computer.
tgenc
Mon Aug 08, 2016 12:11 pm
Tanzer
Hi there,
Thank you for your recommendation first. Yes I have tried it. it's not perfect but works anyway. interface is very poor and i have problem with subtitle codepages, so this is why I am looking for better interfaced a video player.
Also tried KODI but it can't open some of videos
dom
Mon Aug 08, 2016 1:40 pm
tgenc wrote:Also tried KODI but it can't open some of videos
Kodi is the most fully featured media player you will get. I suspect if kodi can't play a file then nothing will.
Perhaps you can post the mediainfo and/or debug log of a file that didn't play with kodi?
tgenc
Mon Aug 08, 2016 1:45 pm
I have enabled both hardware acceleration OMXPlayer and MMAL. 80% of videos are working well but some of them has problem. it stucks
dom
Mon Aug 08, 2016 1:49 pm
tgenc wrote:I have enabled both hardware acceleration OMXPlayer and MMAL. 80% of videos are working well but some of them has problem. it stucks
Post a debug log.
Either you are playing files that hardware doesn't support (perhaps 10-bit h.265 or h.265) in which case no media player will work.
Or you have a configuration issue (perhaps insufficient gpu_mem assigned).
In either case provide some info if you want to know what the issue is.
tgenc
Mon Aug 08, 2016 2:12 pm
Post a debug log.
tried to open movie.
added the log as attached
kodi.log.tar.gz
(13.42 KiB) Downloaded 160 times
dom
Mon Aug 08, 2016 3:11 pm
17:07:29 T:1945571904  NOTICE: ARM mem: 944MB GPU mem: 64MB MPG2:0 WVC1:0
This is too little gpu memory. We recommend 256M for Pi2/Pi3 running Kodi.
tgenc
Mon Aug 08, 2016 3:27 pm
thank you for your comment. could I ask how can I increase it to 256 ?
thanks
Tanzer
tgenc
Wed Aug 10, 2016 7:45 am
hello there,
I found how to change gpu memory to 256.
https://www.raspberrypi.org/documentati ... fig-txt.md
adding gpu_mem=256 to last line is working.
dom
Wed Aug 10, 2016 11:41 am
tgenc wrote:I found how to change gpu memory to 256.
adding gpu_mem_256 to last line is working.
If you are using the Pi predominately for Kodi, the a dedicated distribution like LibreELEC or OSMC is strongly recommended.
That would have settings like gpu_mem set appropriately out of the box, and in general everything is configured for the best experience.
tgenc
Fri Aug 12, 2016 8:04 am
it's solved. all my problems has gone.
thanks for support
jeffinjoe
Sat Dec 09, 2017 9:19 am
I tried to play a video that i made with iMovie (.mov) and converted with a video converter to .mp4 but it couldnt play on omxplayer its show like this.
Output mode 31: [email protected] :1f
ntsc_freq:0
Video codec omx-h264 width 1920 height 1080 profile 122 fps 25.000000
Audio codec aac channels 2 samplerate 48000 bitspersample 16
Subtitle count: 0, state: off, index: 1, delay: 0
Stopped at: 00:00:00
Someone please help me to fix this>
Thank you.
ztealmax
Sat Dec 09, 2017 9:51 pm
Hi there you could just try this: viewtopic.php?f=66&t=199545
and use chromium as your videoplayer, it plays full hd without lag :)
tvjon
Mon Dec 11, 2017 6:26 pm
"I tried to play a video that i made with iMovie (.mov)"
Readers here able to help, can't do so without some basic information, which is easy for anyone to provide.
The following lines starting with
are console (terminal) commands you need to type. The text below the command lines is a typical response to the command.
$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
$ uname -a
Linux s3 4.9.67-v7+ #1061 SMP Tue Dec 5 17:17:24 GMT 2017 armv7l GNU/Linux
$ vcgencmd version
Dec 1 2017 16:20:32
Copyright (c) 2012 Broadcom
version 38ac72569d7fbd7cf75754d9f14c2495416aaee7 (clean) (release)
$ omxplayer -v
omxplayer - Commandline multimedia player for the Raspberry Pi
Build date: Wed, 05 Jul 2017 16:40:39 +0100
Version : 5a25a57 [debian]
Repository: [email protected]:XECDesign/omxplayer.git
$ sudo apt-get install mediainfo
$ mediainfo "my imovie file.mov"
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2005.03 (qt )
File size : 11.0 MiB
Duration : 3 min 48 s
Overall bit rate mode : Variable
Overall bit rate : 403 kb/s
Encoded date : UTC 2009-05-10 08:08:36
Tagged date : UTC 2009-05-10 08:08:37
Writing library : Apple QuickTime
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 280 kb/s
Maximum bit rate : 759 kb/s
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (29970/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.122
Stream size : 7.61 MiB (69%)
Encoded date : UTC 2008-04-17 06:44:48
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Bit rate mode : Variable
Bit rate : 120 kb/s
Maximum bit rate : 138 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 spf)
Compression mode : Lossy
Stream size : 3.27 MiB (30%)
Tagged date
ksharindam
Wed Dec 13, 2017 11:27 am
The video encoding is AVC1 , I think this is not supported by OMXPLAYER.
Though you have given all infos, it will be helpful if you give output of the command...
omxplayer -i video_name.mov
gkreidl
Wed Dec 13, 2017 12:05 pm
AVC is supported.
Minimal Kiosk Browser (kweb)
Return to “Raspberry Pi OS”
