dpkg-query -l
to create a list of installed packages of each and did a comparison. I found one package which was not in minibian which solved a problem for me - this will be the subject of another post.
For the benefit of others considering the same issue here are the results, I hope it helps someone else.
Packages in both:
acl
adduser
apt
base-files
base-passwd
bash
bsdmainutils
bsdutils
ca-certificates
coreutils
cpio
cron
dash
dbus
debconf
debianutils
diffutils
dmsetup
dpkg
e2fslibs:armhf
e2fsprogs
fake-hwclock
findutils
gcc-4.9-base:armhf
gnupg
gpgv
grep
groff-base
gzip
hostname
ifupdown
init
init-system-helpers
initramfs-tools
initscripts
insserv
iproute2
iputils-ping
isc-dhcp-client
isc-dhcp-common
klibc-utils
kmod
less
libacl1:armhf
libapt-pkg4.12:armhf
libattr1:armhf
libaudit-common
libaudit1:armhf
libblkid1:armhf
libbsd0:armhf
libbz2-1.0:armhf
libc-bin
libc6:armhf
libcap-ng0:armhf
libcap2-bin
libcap2:armhf
libcomerr2:armhf
libcryptsetup4:armhf
libdb5.3:armhf
libdbus-1-3:armhf
libdebconfclient0:armhf
libdevmapper1.02.1:armhf
libdns-export100
libedit2:armhf
libestr0
libexpat1:armhf
libffi6:armhf
libgcc1:armhf
libgcrypt20:armhf
libgdbm3:armhf
libglib2.0-0:armhf
libgmp10:armhf
libgnutls-deb0-28:armhf
libgnutls-openssl27:armhf
libgpg-error0:armhf
libgssapi-krb5-2:armhf
libhogweed2:armhf
libicu52:armhf
libidn11:armhf
libirs-export91
libisc-export95
libisccfg-export90
libjson-c2:armhf
libk5crypto3:armhf
libkeyutils1:armhf
libklibc
libkmod2:armhf
libkrb5-3:armhf
libkrb5support0:armhf
liblogging-stdlog0:armhf
liblognorm1:armhf
liblzma5:armhf
libmount1:armhf
libncurses5:armhf
libncursesw5:armhf
libnettle4:armhf
libnih-dbus1
libnih1
libopts25:armhf
libp11-kit0:armhf
libpam-modules-bin
libpam-modules:armhf
libpam-runtime
libpam0g:armhf
libpcre3:armhf
libpipeline1:armhf
libprocps3:armhf
libpsl0:armhf
libraspberrypi-bin
libraspberrypi0
libreadline6:armhf
libselinux1:armhf
libsemanage-common
libsemanage1:armhf
libsepol1:armhf
libslang2:armhf
libsmartcols1:armhf
libss2:armhf
libssl1.0.0:armhf
libsystemd0:armhf
libtasn1-6:armhf
libtinfo5:armhf
libudev1:armhf
libusb-0.1-4:armhf
libustr-1.0-1:armhf
libuuid1:armhf
libwrap0:armhf
locales
login
lsb-base
man-db
mawk
mount
multiarch-support
ncurses-base
ncurses-bin
net-tools
netbase
ntp
openssh-client
openssh-server
openssh-sftp-server
openssl
passwd
perl-base
procps
raspberrypi-bootloader
raspbian-archive-keyring
readline-common
rsyslog
sed
sensible-utils
startpar
systemd
systemd-sysv
sysv-rc
sysvinit-utils
tar
tzdata
udev
util-linux
vim-common
vim-tiny
wget
zlib1g:armhf
cgmanager
cpufrequtils
dialog
libcgmanager0:armhf
libcpufreq0
libpam-systemd:armhf
libstdc++6:armhf
libuuid-perl
linux-base
linux-image-3.18.0-trunk-rpi2
systemd-shim
alsa-utils
apt-listchanges
apt-utils
aptitude
aptitude-common
avahi-daemon
bash-completion
bind9-host
binutils
bluez
bluez-firmware
build-essential
bzip2
cifs-utils
console-setup
console-setup-linux
cpp
cpp-4.9
crda
curl
dc
debconf-i18n
debconf-utils
device-tree-compiler
dhcpcd5
dmidecode
dosfstools
dphys-swapfile
dpkg-dev
ed
fakeroot
fbset
file
firmware-atheros
firmware-brcm80211
firmware-libertas
firmware-ralink
firmware-realtek
g++
g++-4.9
gcc
gcc-4.6-base:armhf
gcc-4.7-base:armhf
gcc-4.8-base:armhf
gcc-4.9
gdb
gdbserver
geoip-database
hardlink
info
install-info
iptables
iso-codes
iw
kbd
keyboard-configuration
libalgorithm-c3-perl
libalgorithm-diff-perl
libalgorithm-diff-xs-perl
libalgorithm-merge-perl
libapt-inst1.5:armhf
libarchive-extract-perl
libasan1:armhf
libasound2-data
libasound2:armhf
libatomic1:armhf
libavahi-common-data:armhf
libavahi-common3:armhf
libavahi-core7:armhf
libbind9-90
libboost-iostreams1.49.0
libboost-iostreams1.50.0
libboost-iostreams1.53.0
libboost-iostreams1.54.0:armhf
libboost-iostreams1.55.0:armhf
libc-dev-bin
libc6-dbg:armhf
libc6-dev:armhf
libcgi-fast-perl
libcgi-pm-perl
libclass-c3-perl
libclass-c3-xs-perl
libcloog-isl4:armhf
libcpan-meta-perl
libcurl3:armhf
libcwidget3:armhf
libdaemon0:armhf
libdata-optlist-perl
libdata-section-perl
libdns100
libdpkg-perl
libdrm2:armhf
libevent-2.0-5:armhf
libfakeroot:armhf
libfcgi-perl
libfile-fcntllock-perl
libfreetype6-dev
libfreetype6:armhf
libgcc-4.9-dev:armhf
libgeoip1:armhf
libglib2.0-data
libgomp1:armhf
libident
libisc95
libisccc90
libisccfg90
libisl10:armhf
libiw30:armhf
libjim0.75:armhf
libjpeg62-turbo:armhf
libldap-2.4-2:armhf
liblocale-gettext-perl
liblog-message-perl
liblog-message-simple-perl
libluajit-5.1-common
liblwres90
libmagic1:armhf
libmodule-build-perl
libmodule-pluggable-perl
libmodule-signature-perl
libmpc3:armhf
libmpfr4:armhf
libmro-compat-perl
libnewt0.52:armhf
libnfnetlink0:armhf
libnfsidmap2:armhf
libnl-3-200:armhf
libnl-genl-3-200:armhf
libnss-mdns:armhf
libpackage-constants-perl
libparams-util-perl
libparted2:armhf
libpcsclite1:armhf
libpng12-0:armhf
libpng12-dev:armhf
libpod-latex-perl
libpod-readme-perl
libpopt0:armhf
libpython-stdlib:armhf
libpython2.7-minimal:armhf
libpython2.7-stdlib:armhf
libpython2.7:armhf
libraspberrypi-dev
libraspberrypi-doc
libregexp-common-perl
librtmp1:armhf
libsamplerate0:armhf
libsasl2-2:armhf
libsasl2-modules-db:armhf
libsasl2-modules:armhf
libsigc++-1.2-5c2
libsigc++-2.0-0c2a:armhf
libsoftware-license-perl
libsqlite3-0:armhf
libssh2-1:armhf
libstdc++-4.9-dev:armhf
libstdc++6:armhf
libsub-exporter-perl
libsub-install-perl
libsysfs2:armhf
libtalloc2:armhf
libterm-ui-perl
libtext-charwidth-perl
libtext-iconv-perl
libtext-soundex-perl
libtext-template-perl
libtext-wrapi18n-perl
libtimedate-perl
libtirpc1:armhf
libubsan0:armhf
libudev0:armhf
libusb-1.0-0:armhf
libv4l-0:armhf
libv4l2rds0:armhf
libv4lconvert0:armhf
libwbclient0:armhf
libx11-6:armhf
libx11-data
libxapian22
libxau6:armhf
libxcb1:armhf
libxdmcp6:armhf
libxext6:armhf
libxml2:armhf
libxmuu1:armhf
libxtables10
linux-libc-dev:armhf
logrotate
lsb-release
lua5.1
luajit
make
makedev
manpages
manpages-dev
mime-support
module-init-tools
mountall
nano
ncdu
ncurses-term
netcat-openbsd
netcat-traditional
nfs-common
openresolv
parted
patch
perl
perl-modules
pi-bluetooth
pkg-config
plymouth
psmisc
python
python-apt
python-apt-common
python-minimal
python-rpi.gpio
python-support
python2.7
python2.7-minimal
raspberrypi-kernel
raspberrypi-sys-mods
raspi-config
raspi-copies-and-fills
rename
rpcbind
samba-common
sgml-base
shared-mime-info
ssh
strace
sudo
tasksel
tasksel-data
tcpd
traceroute
triggerhappy
ucf
unzip
usb-modeswitch
usb-modeswitch-data
usbutils
v4l-utils
whiptail
wireless-regdb
wireless-tools
wpasupplicant
xauth
xdg-user-dirs
xkb-data
xml-core
xz-utils
zlib1g-dev:armhf
