sotris99
How can i setup my wifi card? TP-Link TL-WN822N
Tue Aug 21, 2012 8:07 am
Hello i have this card
http://www.getprice.com.au/images/uploa ... WN822N.jpg
How can i setup my card in that way to receive internet? I want then to use this internet connection and share it through the ethernet port, like the internet connection sharing of windows.
Ἓν οἶδα, ὅτι οὐδὲν οἶδα. (All I know is that I know nothing)
SirLagz
Re: How can i setup my wifi card? TP-Link TL-WN822N
Tue Aug 21, 2012 9:13 am
A picture does not help, however running
lsusb
while the card is plugged in will help us determine which chipset is in your card, and then from the chipset, which instructions for you to follow.
sotris99
Tue Aug 21, 2012 9:41 am
on a pc with backtrack linux it says atheros something.
when i go home i will tell you
sotris99
Tue Aug 21, 2012 6:20 pm
Bus 001 Device 004: ID 046d:c52e Logitech, Inc.
sotris99
Tue Aug 21, 2012 7:28 pm
pi@raspberrypi ~ $ lsusb
Bus 001 Device 005: ID 046d:c52e Logitech, Inc.
Bus 001 Device 006: ID 0cf3:1002 Atheros Communications, Inc. TP-Link TL-WN821N v2 802.11n [Atheros AR9170]
SirLagz
Wed Aug 22, 2012 1:50 am
I have not used one of those before so I can only give some general information.
You will need to use the carl9170 drivers for that device.
If you do an lsmod does it show up anything relating to carl9170 ?
If it does, then do an ifconfig -a and you should see an ath0 or something similar to that.
If you see that, then the wireless should be ready to use.
Use WICD or something similar for a graphic interface to setup your WiFi Card.
Otherwise you may need to get the firmware for the device.
Check apt-get to see if theres a firmware-atheros package. The name could be different as I can't check at the moment.
Otherwise, you can get the firmware from here
After the firmware is installed, try the lsmod again and see how you go.
prich
Sat Sep 01, 2012 11:27 am
I am also trying to setup one of these cards on a Raspberry Pi. My card is packaged as a TL-WN822N Ver 2.0 card but Raspbian reports the card (under lsusb) as:
0cf3:7015 Atheros Communications, Inc. TP-Link TL-WN821N v3 802.11n [Atheros AS7010-AR9287]
lsmod tells me that the driver and firmware for ath9k_htc has been loaded.
Checking other places on the internet seems to indicate that indicates that this is the correct driver and that support is included in the kernel.
The device is not started during boot and attempts to get an IP address via DHCP fail then wicd says that there are no wireless networks detected.
Any assistance would be greatly appreciated.
Thank you
SirLagz
Sat Sep 01, 2012 2:34 pm
use wpa_cli and try a scan in wpa_cli and see if it picks up anything ?
n_r_g
Sun Sep 29, 2013 12:40 pm
FYI - Trying to get a TP-WN821N wireless adaptor working under raspbian - no luck (adaptor blank issue), gave up.
Works automatically under raspbmc!
Return to “Raspberry Pi OS”
