hello world :-)
Location: England, in an insecure cloud, ie. The Interwebs
Contact: Website Yahoo Messenger AOL
Command to start Epiphany in an Incognito (private) instance
Sat Jun 18, 2016 9:00 am
Is there a command to start the Epiphany web browser in an Incognito (Private browsing) instance? According to man epiphany-browser it's
epiphany-browser --private-instance
but when trying that it just seems to open a normal window :(
I know Epiphany isn't the best browser, but Iceweasel uses way too much memory and is unbearably slow, and Midori suffers from serious memory leaks that need a reboot to fix, not ideal when you're also using your Pi as a LAN server. Dillo is for documentation, and nothing else. I've never even bothered with Netsurf.
I do moral support. Here: https://www.raspberrypi.org/forums/search.php?search_id=egosearch
I know I use too many parentheses. Problem?
Topics I have posted in: http://bit.ly/1NbDdr5
My topics: http://bit.ly/1ObnKqQ
All my posts: http://bit.ly/1OHzje7
gkreidl
Re: Command to start Epiphany in an Incognito (private) inst
Sat Jun 18, 2016 10:24 am
Private browsing just means that cache, history etc. are not saved between sessions. There doesn't have to be a difference in what the window looks like.
BTW, kweb uses private mode by default (it can be disabled with a command line option).
Minimal Kiosk Browser (kweb)
hello world :-)
Sat Jun 18, 2016 2:34 pm
gkreidl wrote:Private browsing just means that cache, history etc. are not saved between sessions. There doesn't have to be a difference in what the window looks like.
:roll: Seems normal as in it looks like a normal session, acts like a normal session and when I close it and open a new (normal) Epiphany window all the history/cache is still there.
Never tried kweb, what's it like? (How much RAM/how slow is it)
I can't try it right now, only 108.7MB space left on my only SD (might have to reinstall soon to get rid of all the junk left after manually installing/uninstalling stuff, but can't be bothered to install and configure everything again) :?
Peter Ryan
Mon Jun 20, 2016 10:37 pm
The answer to your question is here:
viewtopic.php?t=139968&p=927965
hello world :-)
Wed Jun 22, 2016 5:46 am
Peter Ryan wrote:The answer to your question is here:
Kudos.
Return to “Raspbian”
