Crash during compilation
Posted: Mon Jun 06, 2016 12:20 pm
by pmatos
I am trying to determine why my rpi3 keeps crashing (literally I need to unplug it and plug it again) while compiling gcc on it.
Is there a way to understand if this was:
  • Power : doubtful, this is connected to a pretty powerful electrical extension and using this raspberry pi charger:
    https://www.amazon.de/3000mAh-Netzteil- ... B01E75SB2C
  • Temperature ; make -j1 works, make -j2 fails so it could be temperature but I would find it quite strange since I am not even using all of the cores
  • any other possibilities?
Re: Crash during compilation
Posted: Mon Jun 06, 2016 12:27 pm
by RaTTuS
OOME ?
what is displayed on the screen when it dies ?
tail -f /var/log/syslog
on another terminal when compiling and what does it say when it dies.
do you get brown outs ?
flickering red LED ?
Posted: Mon Jun 06, 2016 1:03 pm
by pmatos
RaTTuS wrote:OOME ?
The problem is the temperature. It easily reaches 90C. That's not good.
The screen just stalls from whatever was being displayed. In my case, the compilation log. I probably need some heatsinks and an open case.
Posted: Mon Jun 06, 2016 1:40 pm
by dom
What does:
vcgencmd version
vcgencmd get_config int
uname -a
report?
Posted: Mon Jun 06, 2016 2:08 pm
by stderr
pmatos wrote:I am trying to determine why my rpi3 keeps crashing (literally I need to unplug it and plug it again) while compiling gcc on it.
Do you have swap enabled on it? When you have to use flash for this, I'd get a separate thumb drive and just put swap on it if possible.
Posted: Mon Jun 06, 2016 2:11 pm
by RaTTuS
put a heak sink on it and give it some airflow space
