ceving wrote:dom wrote:4.7 doesn't support the experimental GL driver yet - it's only been out a few days and it at -rc1 stage (very early).
If you want a tested kernel then 4.4 is recommended.
What means tested. I have read on the net that many people have problems with OpenGL on Raspi 3.
Is there a reproduce able procedure which works reliably? Like
Take Jessy
run apt-get update, apt-get dist-upgrade
run rpi-update
enable OpenGL
reboot
run glxgears
What I did is not much different and I end with a black screen.
I would really like to know how the test case looks like, which gives 60 fps in glxgears on a Raspi 3.
i'm running
uname -a
Linux raspberrypi 4.4.13-v7+ #893 SMP Wed Jun 8 14:39:18 BST 2016 armv7l GNU/Linux
just did
run rpi-update
enable OpenGL
reboot
run glxgears
and i get 60 fps in a small window and @25 in full screen (1080x1920).
but in the browser i get less than 1 fps.
if i disable opengl is the opposite, i get under 1 fps in glxgears in 25 in the browser. Chromium and Epiphany
Are not all the pis created equal?
However. I am intrigued that omxplayer is working in full hd with no missing frame and very little CPU.
