dudewheresmycode
initctl: command not found
Sun Aug 19, 2012 7:06 pm
I'm trying to write an upstart script for my node.js server. When i try to run
sudo start myserver
i get:
-bash: start: command not found
, in addition, can't find initctl either.
Ideas?
bredman
Re: initctl: command not found
Sun Aug 19, 2012 7:20 pm
Are you trying to follow some tutorial or instruction?
There is no "start" command as standard in Linux.
dudewheresmycode
Tue Aug 21, 2012 6:00 am
Sorry that's my Ubuntu bleeding through.. To be clear, I'm trying to create an upstart script in
/etc/init/
. In Ubuntu I would use
initctl
to start / stop the script.
rurwin
Tue Aug 21, 2012 6:34 am
. is not in $path
That is why "start" doesn't work. "sudo ./start myserver" should work.
As for initctl, I've never heard of it, but this is Debian, not Ubuntu. What is it supposed to do? When I was on Ubuntu, I don't think it existed (I may easily be wrong).
jojopi
Tue Aug 21, 2012 7:10 am
"start" and "initctl" and /etc/init are upstart-specific, and debian is using sysvinit by default. The sysvinit equivalent is to put a different kind of file in /etc/init.d and run "sudo service NAME start/stop".
"sudo apt-get install upstart" offers to install upstart and remove sysvinit, but it also warns that this is potentially harmful, so I am not going to try it.
Return to “Raspberry Pi OS”
