CaptSunset
Change notes mention SD card cloning
Mon May 23, 2016 4:20 pm
Hi guys,
I noticed that a new feature in the 2016-05-10 version of Jessie is the ability to do a backup of it's own SD card, or so I read it from the release notes...
* SD Card Copier added (can be used to duplicate or back up the Pi)
Any fuller explanation around here somewhere? Is it part of NOOBS too?
Re: Change notes mention SD card cloning
Mon May 23, 2016 4:25 pm
CaptSunset wrote:Hi guys,
It was mentioned in the Raspbian Update Blog
https://www.raspberrypi.org/blog/anothe ... e-raspbian
CaptSunset
Mon May 23, 2016 6:24 pm
Thanks, FotL- that is quite some discussion; I'll have to go to the Blog more. So many posts, so little time!
gordon77
Mon May 23, 2016 6:58 pm
From the blog....." It has been designed to work with Raspbian and NOOBS images" so l would assume it's part of both.
Works well when l've used it, even copies to smaller cards, assuming your files will fit :D
CaptSunset
Mon May 23, 2016 10:25 pm
Thanks Gordon,
I prob'ly will feel dumb :roll: about asking this question, but why is 1.9.1 NOOBS only 1 gig, whereas just the straight Raspian OS is over 1.3 gigs?
I ask because with the easier clone/backup now in place, I'm unclear about whether to stay with dual booting Raspian/Kodi or separate cards for each; this would affect 3 Pi2s and 2 Pi3s... the 'ancestry' of an SD card would stay clearer in my mind (I also have the lil 2.8 PiTFT's software hack to consider).
procount
Mon May 23, 2016 10:43 pm
The raspbian image in NOOBS is the same but it is compressed using xz which results in a smaller size
Return to “Raspbian”
