I succesfully setup wifi on my Pi under Raspbian Wheezy. The internet over wifi works fine in the text mode but once I've started up X its very slow and unresponsive. If I ping a domain or IP on the internet it hangs for a while and then outputs a few pings and hangs again. Also when I type ifconfig its output hangs for a while before displaying it. Also tyring to load websites in a browser like midori takes ages too and most often times out with a resolve error. It works fine when using a wired connection (ofcourse I removed that cable when trying out wifi)
I've configured wlan manually by following this guide: http://www.raspberrypi-tutorials.co.uk/ ... s-network/
as a second attempt I started again with a fresh wheezy image and used wicd-curses to setup wlan which worked but has the same result of being unresponsive under X while working fine under text mode
I used three different USB dongles (ralink,realtek) but all give the same results. I use them via an Ultron UHN-710 7-port powered hub which is listed on the verified pheripherals list so it should work fine.
I really don't understand why the wlan starts to breakup after having loaded X. I hope someone recognizes the problem.
