daveake
Serial port missing - latest Jessie after update/upgrade
Tue May 17, 2016 4:08 pm
Pi B+. New SD with Jessie Lite dated May 10th.
Disable serial port getty/logging via raspi-config. Reboot, and /dev/ttyAMA0 is there and works.
Run sudo apt-get update and upgrade. Reboot. /dev/ttyAMA0 is now missing. No ttys0 either. As far as I can see, the serial port is gone completely.
Ideas?
grub
Re: Serial port missing - latest Jessie after update/upgrade
Wed May 18, 2016 9:22 pm
I'm experiencing exactly the same issue. I applied the latest upgrades to raspbian jessie lite dated 2016-05-10 and once the packages libraspberrypi, libraspberrypi0 and libraspberrypi-bootloader are updated from version 1.20160506-1 to version 1.20160512-1 the device /dev/ttyAMA0 is missing after reboot.
daveake
Fri May 20, 2016 5:21 am
I have a solution; whether or not it's the "correct" solution I don't know but so far it's worked for me:
1 - Use raspi-config to enable serial port login/logging
2 - Disable getty on tthat port with:
systemctl mask serial-getty@ttyAMA0.service
I read elsewhere on the forum just now about adding "enable_uart=1" to config.txt. I've not tried that and I don't know how that setting would interact with what I've suggested above.
As some people will actually want the serial port pins to be free, my suggestion is that raspi-config has 3 options not the 2:
1 - Enable logging / login
2 - Disable those but keep the port in /dev
3 - Completely disable serial port allowing the Tx/Rx free use for I/O
Either that or have Raspbian behave as it used to.
Dave
grub
Fri May 20, 2016 8:14 am
I disabled serial console with raspi-config and enabled uart by adding/changing
enable_uart=1
in /boot/config.txt according to this thread viewtopic.php?t=148713&p=978725. After reboot /dev/ttyAMA0 was back and my applications using the serial port worked again.
I completely would support Dave's proposal to add another options to raspi-config to differentiate between disable console output and disable complete uart. That would have saved me some hours of investigation. It's annoying that simple update/upgrade w/o any notice disables the serial port though there might be good reasons for this change. However, this should be avoided since beginners could loose patience while struggling with this kind of issues.
Grub
Chris_G_Miller
Wed Jun 01, 2016 11:02 pm
I was having terrible trouble with a serial peripheral attached via a USB to serial device, which I eventually tracked down to "odd" characters turning up in the serial stream my C program was sending to it.
It turns out that Jessie (and possibly other distros) ships with something called ModemManager which scampers round anything which looks like a serial port and prods it with the classic modem "hello" sequence, namely AT followed by carriage return.
It seems to do this a few times a few seconds apart after system startup, then shuts up (making it very difficult to detect what is happening).
To me, this is unhelpful - it has taken me almost half a day to work out this is what was going on :? . - thank goodness for tcpdump + usbmon giving me the ability to sniff the USB bus :) .
The cure is simple issue the following command as root:
systemctl disable ModemManager.service
nl3prc
Fri Aug 05, 2016 10:32 am
I also have a problem in my old linux i used /dev/ptyq0 and /dev/ttyq0
these psuedo ports are no longer in jessie PI
what can i use instead
cblackburn1099
Wed Aug 17, 2016 12:24 am
as far as the pty's go, you have to use /dev/ptmx, it will give you a pty to use, it's a much cleaner system than before
man ptmx
as far as the serial ports go, doesn't AMA now point to the bluetooth stuff and ttyS0 point to the original hardware uart? I beleive that's the case on my PI-3
Charlie
cirrusd
Fri Feb 17, 2017 10:13 pm
Thanks to daveake... Your suggestion works great. :D
Been trying to get this to work for hours...
Return to “Raspberry Pi OS”
