Page 4 of 4
Re: Wlan Stick with RTL8192EU Chipset
Posted: Thu Jan 11, 2018 8:48 pm
by MrEngman
appalcrumble wrote:
Thu Jan 11, 2018 7:20 pm
Thanks so much!!!
Commands worked perfectly.
However, I am still not seeing the stick. Any thoughts?
[edit: I downloaded this version off the website: 8192eu-4.14.13-v7-1077.tar.gz]
When I run lsusb, all I see is:
Bus 001 Device 004: ID 2357:0109 *blank*
Running iwconfig gives me:
eth0 no wireless extensions
lo no wireless extensions
And typing sudo iwlist wlan0 scan, returns:
wlan0 Interface doesn't support scanning
I currently have installed a fresh version of Raspbian stretch. Kernel is 4.9.59-v7+.
/etc/network/interfaces and wpa_supplicant is blank.
Thanks again, appreciate any ideas.
Why did you download 8192eu-4.14.13-v7-1077.tar.gz? I said download the driver file that uses the kernel version used by the Pi shown by command uname -a
You say you have kernel 4.9.59-v7+ so you will need to download the driver file 8192eu-4.9.59-v7-1047.tar.gz.
Once you have installed the driver you will need to configure the wifi to connect to your network, although the scan command should show up nearby networks before you have configured the network set up. Edit file /etc/wpa_supplicant/wpa_supplicant.conf and add the following section to the end of the file
network={
	ssid="network-name"
	psk="network-password"
	key_mgmt=WPA-PSK
Also change the country code from country=GB to the code used by the country where you are.
File /etc/wpa_supplicant/wpa_supplicant.conf should then look something like
country=GB
update_config=1
network={
	ssid="network-name"
	key_mgmt=WPA-PSK
Do not edit file /etc/network/interfaces
Posted: Thu Jan 11, 2018 9:35 pm
by appalcrumble
Ah, thank you! Sorry that was a stupid error on my part!
Working great now. Thank you thank you thank you!!!!!
Posted: Mon Jan 15, 2018 8:22 pm
by coys3000
As everyone else has said, first of all thank you so much for help! It's greatly appreciated.
I have used your install-wifi script and it correctly installed 8192eu.ko but it's still not picking up the usb device.
lsusb
Bus 001 Device 005: ID 2357:0109
Bus 001 Device 004: ID 03f0:0024 Hewlett-Packard KU-0316 Keyboard
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
If i do ifconfig, iwconfig or lshw -c network all are showing the device as working with the driver rtl8192. I'm trying to follow this tutorial https://pimylifeup.com/raspberry-pi-wifi-extender/ to create a wifi network and everything seems to be in order but I am not creating a network.
Do you know if the TP-Link TL-WN823N is capable of sending signal in addition to receiving? Or is it just not installed correctly? Thanks!
Posted: Mon Jan 15, 2018 10:13 pm
by MrEngman
lsusb
Command lsusb is showing the wifi device. It is Bus 001 Device 005: ID 2357:0109. Just because there is no description does not mean it is not being found. There are quite a few wifi devices that only show the USB ID and nothing else.
I cannot access the tutorial as the antivirus software on my laptop is reporting a malicious web site when I try to access it so am unable to see what you are doing to set it up.
Posted: Tue Jan 16, 2018 3:45 am
by coys3000
lsusb
Oh thats strange, the site has been fine on all the computers I've used it on. I can give a quick run down. But I guess my main concern is that I can't use the dongle to broadcast instead of just receive, do you have any information on this? Anyway just in case you might be able to help with tutorial.
first sudo apt-get install hostapd dnsmasq
in /etc/dhcpcd.conf
interface wlan1
static ip_address=192.168.220.1/24
static routers=192.168.220.0
then sudo service dhcpcd restart
in /etc/hostapad/hostapd.conf
interface=wlan1
driver=nl80211
hw_mode=g
channel=6
ieee80211n=1
wmm_enabled=1
ht_capab=[HT40][SHORT-GI-20][DSSS_CCK-40]
macaddr_acl=0
ignore_broadcast_ssid=0
auth_algs=1
wpa=2
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
ssid=Pi3-Extender
wpa_passphrase=raspberry
I have a feeling the driver might be the problem? I have tried rtl8192eu, 8192eu, 8192eu.ko and possibly some more than I can't remember
in /etc/default/hostapd updated #DAEMON_CONF="" to DAEMON_CONF="/etc/hostapd/hostapd.conf"
in /etc/init.d/hostapd updated #DAEMON_CONF="" to DAEMON_CONF=/etc/hostapd/hostapd.conf
create a brand new dnsmasq.conf at /etc/dnsmasq.conf with
interface=wlan1       # Use interface wlan1
listen-address=192.168.220.1   # Specify the address to listen on
bind-interfaces      # Bind to the interface
server=8.8.8.8       # Use Google DNS
domain-needed        # Don't forward short names
bogus-priv           # Drop the non-routed address spaces.
dhcp-range=192.168.220.50,192.168.220.150,12h # IP range and lease time
then in /etc/sysctl.conf uncomment #net.ipv4.ip_forward=1
then
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
update iptables
sudo iptables -t nat -A POSTROUTING -o wlan0 -j MASQUERADE
sudo iptables -A FORWARD -i wlan0 -o wlan1 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i wlan1 -o wlan0 -j ACCEPT
save iptables rules
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
in /etc/rc.local
iptables-restore < /etc/iptables.ipv4.nat
above exit 0
then finally
sudo service hostapd start
sudo service dnsmasq start
In theory I should have a network running at this point, but I don't. Any thoughts?
Posted: Sun Jan 21, 2018 10:34 pm
by MrEngman
Hi coys3000,
Sorry for the delay in responding. Been tied up with a house full of guests over the last week.
Regarding the malware, the pimylifeup.com site itself appears OK, it's a site, trck.me ip 64(dot)91(dot)234(dot)169, that is accessed from that site from which images appear to be downloaded that is the problem. However, for whatever reason my web browser will not show the info from pimylifeup.com.
I have tried the 8192eu driver operating as an AP and it works fine using a TP-Link TL-WN822N v4. I have an SD card set up as a router. It was using a TP-Link TL-WN725N using the 8188eu driver. I tried it on a Pi 2B and installed the 8192eu driver and replaced the WN725N with the TL-WN822N v4 and it worked fine so the 8192eu driver works OK as an AP. I'm not 100% sure what site I used for getting the info for setting up the router but I think it was probably http://daveconroy.com/using-your-raspbe ... eb-server/
I also tried setting up an AP using data from https://www.raspberrypi.org/documentati ... -point.md and that appeared to work as well on a Pi 2B.
I did try on a Pi 3B and there it did not work. I think that was due in some way to the fact it also had the built in wifi so maybe needs setting up differently as it essentially had two wifi modules which appeared to mess things up.
You could also look here https://github.com/SurferTim/documentat ... s-point.md as @SurferTim looks to be well up on configuring various wifi set ups and provides many useful responses on the forum to people having wifi problems.
Posted: Wed Jan 31, 2018 5:18 pm
by coys3000
Hi coys3000,
No problem, I had some guests last week so I understand the feeling. I got it to work with a 3B. I ended up running the hostapd service manually
sudo hostapd -d /etc/hostapd/hostapd.conf
In this case it showed me if the driver was working or not so and I had to use the original one from the tutorial, nl80211
Posted: Sun Mar 25, 2018 6:17 pm
by eltrasimaco
Downloaded this 8192eu thingy, edited wpa_supplicant with the wifi config and now the tp-link dongle is working line a charm in five minutes of work (well, ten minutes if post reading is to be considered) :D
Thanks loads!
Posted: Sat Nov 24, 2018 7:37 pm
by Eingehirner
Dear MrEngman,
this is just so great! After searching for a solution for DAYS I came back to this thread (which I ignored at first because it started 2016) and wham, in a matter of seconds my WiFi stick worked perfectly. Woohoooo! A big THANK YOU for your great work!
It might be a good thing though to somehow post this information in the first post so that others can find it. Just something like "It's November 2018 and this still works". There's great confusion because the manufacturer actually provides a driver but nobody (besides you) seems to know how or care how to adapt it to an RPi.
Best regards,
Eingehirner
