andig2
Minimal image broken or weird SD card issue?
Fri May 13, 2016 6:43 am
I've just installed a Pi2 with the latest minimal raspbian image. Updated software plus firmware and then went about installing software when the problems started:
[email protected]:~/vzlogger $ sudo apt-get install cmake
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  ax25-node libax25 libc-ares2 libfile-copy-recursive-perl libv8-3.14.5 openbsd-inetd update-inetd
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  cmake-data libarchive13 liblzo2-2
Suggested packages:
  codeblocks eclipse ninja-build lrzip
The following NEW packages will be installed:
  cmake cmake-data libarchive13 liblzo2-2
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,076 kB of archives.
After this operation, 15.1 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main cmake-data all 3.0.2-1 [929 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main liblzo2-2 armhf 2.08-1.2 [47.6 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libarchive13 armhf 3.1.2-11 [230 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main cmake armhf 3.0.2-1 [1,870 kB]
Fetched 3,076 kB in 1s (2,188 kB/s)
Selecting previously unselected package cmake-data.
(Reading database ... 31242 files and directories currently installed.)
Preparing to unpack .../cmake-data_3.0.2-1_all.deb ...
Unpacking cmake-data (3.0.2-1) ...
dpkg: error processing archive /var/cache/apt/archives/cmake-data_3.0.2-1_all.deb (--unpack):
 unable to clean up mess surrounding `./usr/share/cmake-3.0/Modules/FindPostgreSQL.cmake' before installing another version: Read-only file system
dpkg: error while cleaning up:
 unable to remove newly-extracted version of `/usr/share/cmake-3.0/Modules/FindPNG.cmake': Read-only file system
[email protected]:~/vzlogger $ df
-bash: df: command not found
[email protected]:~/vzlogger $ ls
-bash: ls: command not found
[email protected]:~ $ shutdown -rF now
Code should not be reached 'Unhandled option' at ../src/systemctl/systemctl.c:6316, function shutdown_parse_argv(). Aborting.
Aborted
[email protected]:~ $ shutdown -r now
Failed to execute operation: The name org.freedesktop.PolicyKit1 was not provided by any .service files
Must be root.
Now, every time the apt-get error occurs, no more shell commands work- only a reboot. If I fix the dpkg error using force it installs fine but a similar error will appear when installing the next package- again disabling the shell commands. The error messages on shutdown look _very_ strange to me. I've rebootet after touching /forcefsck, no change.
Is it possible that these are issues are anyway connected to the minimal image? If SD card what else could I do to diagnose?
RaTTuS
Re: Minimal image broken or weird SD card issue?
Fri May 13, 2016 7:01 am
is it a fake card ?
did you expand the Fs before upgrading ?
try with another Sdcard
Covfefe
Return to “Raspbian”
