mcatto
Transmission gui don´t work on restart
Sun May 01, 2016 11:57 pm
Hi.
I have raspberry 3 and transmission in raspbian
The daemon is loadead and the torrents downloaded.
But when restart de raspberry the gui don't work. I need to stop the daemon and start again, and the gui works for my 192.168.1.103:9091 ip.
How i can solve this?
Sorry for my english
Peter Ryan
Re: Transmission gui don´t work on restart
Tue May 03, 2016 6:43 pm
If systemd is condifured to not start transmission at boot, checking it's status will show something like this:
[email protected]:~ $ systemctl status transmission-daemon.service
● transmission-daemon.service - Transmission BitTorrent Daemon
   Loaded: loaded (/lib/systemd/system/transmission-daemon.service; disabled)
   Active: inactive (dead)
If that's the case, then setting it to start at boot is easy:
[email protected]:~ $ systemctl enable transmission-daemon.service
If it's not that though... then I'm a bit short on ideas! You could try "reenable" instead of "enable" which is meant to disable and then enable to ensure the symlinks sytemd uses are correctly set up.
mcatto
Tue May 03, 2016 7:40 pm
I have this
[email protected]:~ $ [email protected]:~ $ systemctl status transmission-daemon.service
-bash: [email protected]:~: no se encontró la orden
[email protected]:~ $ ● transmission-daemon.service - Transmission BitTorrent Daemon
-bash: ●: no se encontró la orden
[email protected]:~ $ Loaded: loaded (/lib/systemd/system/transmission-daemon.service; enabled)
-bash: error sintáctico cerca del elemento inesperado `('
[email protected]:~ $ Active: active (running) since mar 2016-05-03 22:37:05 GMT-3; 1min 8s ago
[email protected]:~ $ Main PID: 592 (transmission-da)
[email protected]:~ $ Status: "Uploading 0.59 KBps, Downloading 0.53 KBps."
-bash: Status:: no se encontró la orden
[email protected]:~ $ CGroup: /system.slice/transmission-daemon.service
-bash: CGroup:: no se encontró la orden
[email protected]:~ $ └─592 /usr/bin/transmission-daemon -f --log-error
-bash: └─592: no se encontró la orden
[email protected]:~ $ clear
Active: active (running) since mar 2016-05-03 22:37:05 GMT-3; 1min 55s ago
Status: "Uploading 0.19 KBps, Downloading 0.68 KBps."
Return to “Raspbian”
