planteg
Raspberry Pi 3, can't connect to my Router
Sat Apr 30, 2016 11:54 pm
Hi all,
brand new to Raspberry world, not so proficient with Linux, but may years in IT, under Windows.
My router does not broadcast the SSID, so I need, as far as I can see, to manually configure my connection. I googled a lot, tried a few procedures, but none worked :oops: .
My router is setup this way:
Security mode: WPA2-Personal
Channel width: auto
Channel: auto
Network: Mixed
Frequency: 2.4G and 5G
Here is my actual configuration:
interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
#allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
wpa_replicant.conf
CSPuntry=CA
update_config=1
network={
	ssid="ingp"
	psk="GP4490CSP3059"
iwconfig responds this
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=1496 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
ifcong responds this
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:ad:3b:fa
          inet adr:169.254.9.133  Bcast:169.254.255.255  Masque:255.255.0.0
          adr inet6: fe80::ba27:ebff:fead:3bfa/64 Scope:Lien
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:242 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:1000
          RX bytes:0 (0.0 B)  TX bytes:83758 (81.7 KiB)
sudo ifdown wlan0 answers this:
ifdown: interface wlan0 not configured
Not configured :?: If I hover over the network icon on the top bar, I het "wlan0 configured 169.xxx.xxx.xxx". Now if I "sudo iwlist wlan0 scan", I get a list of the nearby networks. Just what am I doing wrong ???
If i connect with a cable on eth0, I get connoted instantly - I write that post using my raspberry !
Why is that so complicated !
Thanks a lot
DirkS
Re: Raspberry Pi 3, can't connect to my Router
Sun May 01, 2016 12:18 am
First of all get /etc/network/interfaces back to its original state.
In most cases no changes are needed.
auto lo
auto eth0
allow-hotplug wlan0
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
Then change the 'network' block in /etc/wpa_supplicant/wpa_supplicant.conf as described in viewtopic.php?f=91&t=143814&p=950573#p949957
Sun May 01, 2016 8:28 am
If you un-hide the SSID things will be a million times easier. You can use the GUI widget to connect to a visible network. To do it with the SSID hidden is a pain in the tail. Hiding the SSID doesn't add anything to security, it simply adds a layer of inconvenience.
planteg
Sun May 01, 2016 9:49 pm
Hi DirkS and DougieLawson,
Thanks for your posts.
I tried to bring back to original content both interfaces and wpa_supplicant.conf and modifying network block, but that didn't work.
So first I booted again, hold Shift and re-installed Raspbian. Second I enabled SSID broadcasting, my SSID was discovered so I typed the password, and voilà I was connected. Third, I disabled the SSID broadcast, rebooted the Raspberry, and after a few seconds it connected back to my router :) .
I then had a look at wpa_supplicant.conf, it looked this way:
update_config=1
country=CA
network={
	ssid="my_SSID"
	psk="my_password"
	key_mgmt=WPA-PSK
country=CA was changed by Rasbian preferences, the network block was added by the Raspbian WiFi app.
So my advise to those who have a router that do not broadcast the SSID: have it broadcast for the time needed to connect your Raspberry and then turn off broadcasting.
I wonder if editing wpa_supplicant.conf is fully documented somewhere on Internet I googled but found only partial information here and there.
Happy Raspberry to all !
Sun May 01, 2016 9:56 pm
planteg wrote: So my advise [sic] to those who have a router that do not broadcast the SSID: have it always broadcast for the time needed to connect your Raspberry and then turn off leave it broadcasting.
FTFY, you're welcome.
Return to “Raspberry Pi OS”
