RonR
Raspbian Jessie find command
Wed Apr 13, 2016 6:42 pm
Is there a known problem with the find command under 2016-03-18-raspbian-jessie-lite.img? The first time find is run after a reboot (logging in via SSH), it almost always fails to find a file that's then found on subsequent attempts:
Last login: Wed Apr 13 12:15:53 2016 from gigabyte
[email protected]:~# find / -name res_xmpp.c
/usr/src/asterisk-13.8.0/res/res_xmpp.c
The net result is that you always have to run find twice to be sure the results are accurate.
This does not occur under 2015-05-05-raspbian-wheezy.img.
Douglas6
Re: Raspbian Jessie find command
Wed Apr 13, 2016 6:47 pm
I've noticed the same thing.
jojopi
Wed Apr 13, 2016 9:12 pm
I cannot conveniently reboot any of my Pies at the moment, and I am not using the lite image, and I do not have FreePBX or asterisk installed.
I do have a diagnostic suggestion:
sudo apt-get update && sudo apt-get install strace
sudo reboot
sudo sysctl -w kernel.randomize_va_space=0
strace -o TRY1 find / -name res_xmpp.c
strace -o TRY2 find / -name res_xmpp.c
diff -u TRY1 TRY2 |less
strace records all the system calls issued by the commands. Disabling kernel address space layout randomization reduces the differences to just those involving timestamps, process ids, or actual logic changes. The results from diff may then give some clue as to why the output from the second run differs.
(One thing that might break find is improper use of inotify by an unrelated process.)
Douglas6
Wed Apr 13, 2016 9:56 pm
jojopi wrote:I cannot conveniently reboot any of my Pies at the moment, and I am not using the lite image, and I do not have FreePBX or asterisk installed.
It's not related to Jessie Lite, or FreePBX or asterisk. I first posted about it here, viewtopic.php?p=917227#p917227, on a fairly fresh full Jessie install (searching for bluetoothd).
RonR
Thu Apr 14, 2016 7:23 am
jojopi wrote:The results from diff may then give some clue as to why the output from the second run differs.
I ran your diagnostic suggestion, but the text file output of diff is over 7 megabytes! It compresses to only 187,954 bytes, but the attachment limit is 64KB. The attached ZIP file contains the first 2,793,673 bytes of it.
I'll have to rely on your analysis as it's over my head at this point.
Thanks for your help!
test.zip
(58.1 KiB) Downloaded 35 times
RaTTuS
Contact: Twitter YouTube
Thu Apr 14, 2016 7:56 am
RonR wrote:...p!
see
http://pastebin.com/
Covfefe
RonR
Thu Apr 14, 2016 6:51 pm
RaTTuS wrote:see
pastebin.com has a 500KB limit unless you purchase a PRO account.
RonR
Thu Apr 14, 2016 7:42 pm
jojopi wrote:(One thing that might break find is improper use of inotify by an unrelated process.)
I just tried it on a virgin copy of 2016-03-18-raspbian-jessie-lite.img:
Last login: Thu Apr 14 19:11:29 2016 from gigabyte
[email protected]:~ $ sudo find / -name messages
/var/log/messages
The problem does not occur on a virgin copy of 2016-03-18-raspbian-jessie.img:
Last login: Thu Apr 14 19:36:14 2016
/media/pi/eda95d8a-9cdd-4224-96d0-890b4791600c/var/log/messages
/var/log/messages
The problem appears to be limited to the lite image.
jojopi
Thu Apr 14, 2016 8:19 pm
The diff is so big because the last 41740 lines (of the 45720 lines you were able to post) happen only on the second run. Prior to this huge difference I do not spot a significant change in the results from getdents64 ("get directory entries").
So I wonder if the first run is simply crashing before it completes. "tail TRY1" should help to confirm this. (Is the first attempt faster than the second? Normally it should be slower, because some of the disk accesses will be cached on the second run.)
It seems that both you and Douglas6 in the other thread are running the find under sudo. A side effect of that is to suppress shell diagnostics such as "Segmentation fault" if the escalated process receives a fatal signal.
Do you see the same problem when using neither sudo nor strace? I have still not been able to reproduce this issue myself.
RonR
Fri Apr 15, 2016 2:07 am
jojopi wrote:So I wonder if the first run is simply crashing before it completes. "tail TRY1" should help to confirm this. (Is the first attempt faster than the second?.
The first attempt that fails is faster than the second attempt that succeeds:
-rw-r--r-- 1 root root 5154466 Apr 14 20:58 TRY1
-rw-r--r-- 1 root root 9299393 Apr 14 20:58 TRY2
[email protected]:~# tail TRY1
close(5) = 0
open("..", O_RDONLY|O_NOCTTY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY|O_NOFOLLOW) = 5
fstat64(5, {st_mode=S_IFDIR|0700, st_size=0, ...}) = 0
close(5) = 0
fchdir(4) = 0
close(4) = 0
close(1) = 0
close(2) = 0
exit_group(0) = ?
+++ exited with 0 +++
jojopi wrote:It seems that both you and Douglas6 in the other thread are running the find under sudo. A side effect of that is to suppress shell diagnostics such as "Segmentation fault" if the escalated process receives a fatal signal.
I run as root without sudo. Your diagnostic suggestion was run as root without sudo. I didn't have strace installed until this discussion.
fruit-uk
Fri Apr 15, 2016 5:44 am
I have had a vaguely similar problem running locate, with a message that database is 8 days old.
sudo updatedb would hang.
A reinstall of locate and mlocate seems to have cured it
This is on a jessie upgraded wheezy system so not the light version.
edo1
Fri Apr 15, 2016 8:52 am
[email protected]:~# find / >flist1
[email protected]:~# find / >flist2
[email protected]:~# egrep "^/[a-z]+$" flist1
/proc
/lib
/sys
[email protected]:~# egrep "^/[a-z]+$" flist2
/proc
/lib
/sys
/bin
/usr
/media
/srv
/dev
/tmp
/root
/home
/opt
/run
/etc
/sbin
/boot
/var
/mnt
awesome
Return to “Raspbian”
