Mortimer
mirrordirector.raspbian.org not responding or very slow
Fri Apr 08, 2016 8:28 am
I hadn't fired up my RPi3 for a couple of weeks, and prior to doing a little tinkering though I would run apt-get to do any updates.
At first "apt-get update" stalled at connecting to mirrordirector.raspbian.org, an example of the type of error is:
pi@raspberrypi:~ $ sudo apt-get update
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://archive.raspberrypi.org jessie/staging armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/staging Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie Release.gpg
  Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg  Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
When the command did successfully finish, the subsequent "apt-get upgrade" failed with pages of errors similar to the following:
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/s/srtp/libsrtp0_1.4.5~20130609~dfsg-1.1+deb8u1_armhf.deb  Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/r/ruby-defaults/ruby_2.1.5+deb8u2_all.deb  Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
Is this something wrong my end or is something happening at the far end which is stopping things working as I expect them too?
The purpose of a little toe is to ensure you keep your furniture in the right place.
Abe_Stew
Re: mirrordirector.raspbian.org not responding or very slow
Fri Apr 08, 2016 8:34 am
Not just you - I am experiencing the same issue. Also IsItDownRightNow shows it as off-line as well http://www.isitdownrightnow.com/mirrord ... n.org.html .
Mortimer
Fri Apr 08, 2016 8:43 am
That would explain it. I'll sit by and wait and see what happens then.
promod
Fri Apr 08, 2016 10:22 am
Still not working. Know anybody when it will start working?
cjan
Fri Apr 08, 2016 10:49 am
P-3 server burn on fire ??
Sat Apr 09, 2016 8:26 am
It's running OK right now.
Mortimer
Sat Apr 09, 2016 9:54 am
Yup! All seems normal now.
Return to “Raspberry Pi OS”
