leshekb
Ajenti @Raspbian Jessie
Sat Apr 02, 2016 11:32 am
I bought Raspberry 2 and discovered that latest Raspbian not includes this useful tool in distro and repo.
I managed to install it using Ajenti support link but some issue still remains. Panel is looking like on attached screenshot, so no Network control between Nameservers and Packages. I have Cubieboard @Cubian and Ajenti has Network item there. What the problem with Raspberry?
QMax
Re: Ajenti @Raspbian Jessie
Fri Jan 13, 2017 3:00 pm
Is there some news about ?
I just trying the same on my Pi.
Just donwloaded and installed/upgraded Jessie Lite.
Installed LAMP, WordPress and lot of plugins. All works fine, but I'm still in trouble trying to install Ajenti.
I've found a lot of guides and tutorials, but all are very old, and none of this worked for me.
Is there someting updated available ?
RottenRonnie
Tue Mar 07, 2017 1:49 am
I used this thread to partially install ajenti:
http://support.ajenti.org/topics/1119-i ... -raspbian/
Until I got to this line where it threw out some error messages.
pip install greenlet==dev
I then got "Invalid URL" after accepting the certificate when attempting to browse to https://127.0.0.1:8000
I found this thread that solved the issue:
https://github.com/ajenti/ajenti/issues/1002
For the line pip install greenlet==dev use this instead method instead
sudo apt-get install python-setuptools python-dev gcc
sudo easy_install -U gevent==1.1b3
Return to “Raspberry Pi OS”
