Cannot update raspbian. Please remove mirror mirror.nbtelecom.com.br from mirrordirector:
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfile-copy-recursive-perl all 0.38-1 403 Forbidden
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main openbsd-inetd armhf 0.20140418-2 500 Internal Server Error
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main telnetd armhf 0.17-36 500 Internal Server Error
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... -1_all.deb 403 Forbidden
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
http://mirror.nbtelecom.com.br/raspberr ... _armhf.deb
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, root@localhost and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/2.2.15 (CentOS) Server at mirror.nbtelecom.com.br Port 80
Re: Please remove mirror mirror.nbtelecom.com.br
I have no issues updating raspbian.Cannot update raspbian
sudo apt-get update
sudo apt-get upgrade
sudo reboot
pi@raspberrypi:~ $ sudo apt-get update
Get:1 http://archive.raspberrypi.org jessie InRelease [13.2 kB]
Get:2 http://mirrordirector.raspbian.org jessie InRelease [15.0 kB]
Get:3 http://archive.raspberrypi.org jessie/main armhf Packages [144 kB]
Get:4 http://mirrordirector.raspbian.org jessie/main armhf Packages [8,963 kB]
Get:5 http://archive.raspberrypi.org jessie/ui armhf Packages [8,311 B]
Hit http://archive.raspberrypi.org jessie/staging armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_US
Ign http://archive.raspberrypi.org jessie/staging Translation-en_US
Ign http://archive.raspberrypi.org jessie/ui Translation-en_US
Get:6 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [37.5 kB]
Get:7 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70.3 kB]
Get:8 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_US
Fetched 9,252 kB in 60s (152 kB/s)
Reading package lists... Done
pi@raspberrypi:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
pypy-upstream raspberrypi-ui-mods
The following packages will be upgraded:
gtk2-engines-clearlookspix libimlib2 lxpanel lxpanel-data nodered
raspberrypi-net-mods rc-gui
7 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Need to get 6,773 kB of archives.
After this operation, 84.0 kB disk space will be freed.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.org/debian/ jessie/ui gtk2-engines-clearlookspix armhf 1:2.20.3 [66.7 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libimlib2 armhf 1.4.6-2+deb8u1 [149 kB]
Get:3 http://archive.raspberrypi.org/debian/ jessie/ui lxpanel armhf 0.7.2-1+rpi6 [192 kB]
Get:4 http://archive.raspberrypi.org/debian/ jessie/ui lxpanel-data all 0.7.2-1+rpi6 [1,066 kB]
Get:5 http://archive.raspberrypi.org/debian/ jessie/main nodered armhf 0.13.4 [5,270 kB]
Get:6 http://archive.raspberrypi.org/debian/ jessie/ui rc-gui armhf 0.7-1 [27.4 kB]
Get:7 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-net-mods armhf 1.2.2 [2,358 B]
Fetched 6,773 kB in 21s (308 kB/s)
(Reading database ... 134748 files and directories currently installed.)
Preparing to unpack .../gtk2-engines-clearlookspix_1%3a2.20.3_armhf.deb ...
Unpacking gtk2-engines-clearlookspix:armhf (1:2.20.3) over (1:2.20.2-3+rpi1) ...
Preparing to unpack .../libimlib2_1.4.6-2+deb8u1_armhf.deb ...
Unpacking libimlib2 (1.4.6-2+deb8u1) over (1.4.6-2) ...
Preparing to unpack .../lxpanel_0.7.2-1+rpi6_armhf.deb ...
Unpacking lxpanel (0.7.2-1+rpi6) over (0.7.2-1+rpi4) ...
Preparing to unpack .../lxpanel-data_0.7.2-1+rpi6_all.deb ...
Unpacking lxpanel-data (0.7.2-1+rpi6) over (0.7.2-1+rpi4) ...
Preparing to unpack .../nodered_0.13.4_armhf.deb ...
Unpacking nodered (0.13.4) over (0.13.3) ...
Preparing to unpack .../rc-gui_0.7-1_armhf.deb ...
Unpacking rc-gui (0.7-1) over (0.6-1) ...
Preparing to unpack .../raspberrypi-net-mods_1.2.2_armhf.deb ...
Unpacking raspberrypi-net-mods (1.2.2) over (1.2.1) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for gnome-menus (3.13.3-6) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for gnome-icon-theme (3.12.0-1) ...
Setting up gtk2-engines-clearlookspix:armhf (1:2.20.3) ...
Setting up libimlib2 (1.4.6-2+deb8u1) ...
Setting up lxpanel-data (0.7.2-1+rpi6) ...
Setting up lxpanel (0.7.2-1+rpi6) ...
Setting up nodered (0.13.4) ...
Setting up rc-gui (0.7-1) ...
Setting up raspberrypi-net-mods (1.2.2) ...
Processing triggers for libc-bin (2.19-18+deb8u3) ...
pi@raspberrypi:~ $
DNPNWO
The problem is in one of the mirrors...
pi@raspberrypi24:~ $ sudo apt-get update
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
pi@raspberrypi24:~ $ sudo apt-get upgrade
git git-core git-man gtk2-engines-clearlookspix libavcodec56 libavformat56
libavresample2 libavutil54 libimlib2 libswscale3 libx264-142 lxpanel
lxpanel-data nodered raspberrypi-net-mods raspberrypi-sys-mods raspi-config
rc-gui
18 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Need to get 17.3 MB of archives.
After this operation, 9,170 kB of additional disk space will be used.
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavutil54 armhf 6:11.6-1~deb8u1+rpi1 [160 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavresample2 armhf 6:11.6-1~deb8u1+rpi1 [96.7 kB]
Get:4 http://archive.raspberrypi.org/debian/ jessie/ui lxpanel armhf 0.7.2-1+rpi6 [192 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libx264-142 armhf 2:0.142.2431+gita5831aa-1+rpi2 [763 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ jessie/main libx264-142 armhf 2:0.142.2431+gita5831aa-1+rpi2 [763 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ jessie/main libx264-142 armhf 2:0.142.2431+gita5831aa-1+rpi2 [763 kB]
Get:8 http://archive.raspberrypi.org/debian/ jessie/ui lxpanel-data all 0.7.2-1+rpi6 [1,066 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ jessie/main libx264-142 armhf 2:0.142.2431+gita5831aa-1+rpi2 [763 kB]
Get:10 http://mirrordirector.raspbian.org/raspbian/ jessie/main libx264-142 armhf 2:0.142.2431+gita5831aa-1+rpi2 [763 kB]
Get:11 http://mirrordirector.raspbian.org/raspbian/ jessie/main libx264-142 armhf 2:0.142.2431+gita5831aa-1+rpi2 [763 kB]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavcodec56 armhf 6:11.6-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavformat56 armhf 6:11.6-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libswscale3 armhf 6:11.6-1~deb8u1+rpi1
Get:12 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-man all 1:2.1.4-2.1+deb8u2 [1,267 kB]
Get:13 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-man all 1:2.1.4-2.1+deb8u2 [1,267 kB]
Get:14 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-man all 1:2.1.4-2.1+deb8u2 [1,267 kB]
Get:15 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-man all 1:2.1.4-2.1+deb8u2 [1,267 kB]
Get:16 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-man all 1:2.1.4-2.1+deb8u2 [1,267 kB]
Get:17 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-core all 1:2.1.4-2.1+deb8u2 [1,496 B]
Get:18 http://mirrordirector.raspbian.org/raspbian/ jessie/main git armhf 1:2.1.4-2.1+deb8u2 [2,725 kB]
Get:19 http://mirrordirector.raspbian.org/raspbian/ jessie/main git armhf 1:2.1.4-2.1+deb8u2 [2,725 kB]
Get:20 http://mirrordirector.raspbian.org/raspbian/ jessie/main git armhf 1:2.1.4-2.1+deb8u2 [2,725 kB]
Get:21 http://mirrordirector.raspbian.org/raspbian/ jessie/main libimlib2 armhf 1.4.6-2+deb8u1 [149 kB]
Get:22 http://archive.raspberrypi.org/debian/ jessie/main nodered armhf 0.13.4 [5,270 kB]
Get:23 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-sys-mods armhf 20160321+1 [4,462 B]
Get:24 http://archive.raspberrypi.org/debian/ jessie/main raspi-config all 20160322 [16.0 kB]
Get:25 http://archive.raspberrypi.org/debian/ jessie/ui rc-gui armhf 0.7-1 [27.4 kB]
Get:26 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-net-mods armhf 1.2.2 [2,358 B]
Fetched 11.5 MB in 14s (788 kB/s)
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb Hash Sum mismatch
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 500 Internal Server Error
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... u2_all.deb Hash Sum mismatch
rc-gui
