DoyleChris
Mount Flash Drive
Sat Mar 26, 2016 3:28 am
I am having problems mounting a flash drive.
If i let raspbian do plug and play it puts it into /media/********.
But i want to make it a permanent mount point /mnt/32.
but when i do i haft to use sudo to run the command, which when its all done it is controlled by root not pi.
In fstab this is the line i have in there.
/dev/sda1 /mnt/32 auto rw,defaults 0 0
I cant figure out how to give pi access to the drive.
JimmyN
Re: Mount Flash Drive
Sat Mar 26, 2016 9:26 am
Add a user id and group id
"/dev/sda1 /mnt/32 auto rw,defaults,uid=pi,gid=pi 0 0
DoyleChris
Sat Mar 26, 2016 4:46 pm
So i have tried everything i can to get this to work all the way to reloading Raspbian.
Last thing i did was removed the Stick, removed the lines from /etc/fstab.
If anybody has a way to do it, none of the things i have found are working.
This is what i have.
Raspberry PI 2
Raspbian Jessie Updated and Upgraded
32GB flash stick formated to NTFS plugged into USB on the PI
I would like the stick mounted in a way that the pi user can install programs onto it.
All methods i have found do not give me access to create folders or install files.
Sat Mar 26, 2016 9:26 pm
Option 1: reformat the stick as ext4
Option 2: install ntfs-3g
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
dchao99
Sun Mar 27, 2016 10:18 pm
DoyleChris wrote: 32GB flash stick formated to NTFS plugged into USB on the PI
Use FAT or exFAT. Much faster.
Just make sure "uid=1000, gid=1000" is in fstab
If you want the stick to be accessible to the PC, don't use EXT-4.
Return to “Raspbian”
