dukla2000
held broken packages, libjavascriptcoregtk-3.0-0
Thu Mar 24, 2016 9:32 am
Hi there
I am trying to install gthumb and it seems libjavascriptcoregtk-3.0-0 v2.4.9-1~deb8u1+rpi1 is needed, but only v1:2.4.1-1rpi53rpi1g is available. Is there a way to request v2.4.9?
TIA
sudo apt-get install libwebkit2gtk-3.0-25
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
 libwebkit2gtk-3.0-25 : Depends: libjavascriptcoregtk-3.0-0 (= 2.4.9-1~deb8u1+rpi1) but 1:2.4.1-1rpi53rpi1g is to be installed
E: Unable to correct problems, you have held broken packages.
uname -a
Linux dukla 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
Daily driver: Pi3B, 64GB Samsung Evo+ @100MHz, DVB-T, onboard WiFi for internet, BT/USB dongle for KB/mouse, 250GB HDD via USB for media, Raspbian Jessie Lite with Openbox desktop.
Museum: Pi B
Return to “Raspberry Pi OS”
