Graymalk
having trouble contacting mirrors
Wed Mar 23, 2016 3:43 am
I've been trying to install some software via apt-get and it chokes when it tries to contact mirrordirector.raspbian.org/ . On one Pi (a Pi B), it just eventually gives up and errors out. On another (Pi 2B), it waits a super long time but eventually installs. I've done apt-get clean several times. Is there anything else I can try? Can I manually download the package somehow, save, and install? I'm trying to install samba. Should I give up and try to find code somewhere that I can compile? Can I somehow grab the package off the one that succeeded and give it to the other (as in, do they get saved in a nice package form somewhere that I can copy from)?
heatfanjohn
Re: having trouble contacting mirrors
Wed Mar 23, 2016 3:56 am
I get "unable to connect to mirrordirector.raspbian.org:http:" errors also. See below:
[email protected] ~ $ sudo apt-get update -o Acquire::ForceIPv4=true
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main Sources
Hit http://archive.raspberrypi.org jessie/ui Sources
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie Release.gpg
  Unable to connect to mirrordirector.raspbian.org:http:
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg  Unable to connect to mirrordirector.raspbian.org:http:
W: Some index files failed to download. They have been ignored, or old ones used instead.
Graymalk
Wed Mar 23, 2016 4:10 am
Well then. I fixed it by changing mirrors. Except I had to go pretty far down the list of Raspbian mirrors before I found one that worked, which is a little surprising.
Rhodan
Wed Mar 23, 2016 8:12 pm
Same here. Which mirror did you find that worked?
mstrick96
Sun Mar 27, 2016 6:44 pm
I've been having the same problem. Am still learning Linux.
How can I change the mirror I use?
Return to “Raspbian”
