Cael
running a Program at startup? (Jessie)
Sat Mar 19, 2016 1:48 am
i'm allset on my Pi2 about to use it for a web radio except for one thing "How to run pianobar on Automatic Login" i know leaving an entry in .bashrc will do if i'm manually logging in but im setting this Pi up for a "Plugin > wait for boot up > and Wifi connect and Play." deal.
i have no idea how to do it w/ systemd, any pointers?
edit: at worst if i haveto is install xorg and a WM and start pianobar thatway on startup. but im not exactly free on SD Space.. its just a spare 4GB MicroSD using RetroPie 3.6 (which uses still Jessie as a base) since the Normal SD Image in Downloads right now is a lil too big for this MicroSD (for the purpose i dont need anything fancy im not really using my Pi2 for Emulation or anything else BUT pianobar to be an Pandora Radio Player. )
Riquez
Re: running a Program at startup? (Jessie)
Sat Mar 19, 2016 5:44 am
Not sure if this is what you are looking for ... Desktop Autostart files will run programs automatically on boot.
viewtopic.php?t=18968 in the first reply here by penguintutor.
binaryhermit
Sat Mar 19, 2016 11:50 am
If it's a command line program, using screen and the @reboot parameter in cron might do what you want.
Copied and pasted from the editor opened by "crontab -e"
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
# m h  dom mon dow   command
@reboot   screen -d -m -S irssi irssi
Runs irssi in a detached screen session titled irssi at boot. The "-d -m" part is necessary to start a screen session detached, the "-S irssi" sets the session name to irssi and isn't necessary.
Return to “Raspberry Pi OS”
