Superkikim
RPI3, internal wifi not associating with AP in specific case
Tue Mar 15, 2016 9:20 am
Hi there,
I've made a headless wifi install from my brand new RPI3 with Hifiberry DAC+Pro, based on Raspbian.
I installed Raspbian Lite from this link: https://downloads.raspberrypi.org/raspbian_lite_latest
I've beeing apt-get updating, apt-get upgrading and rpi-updating as well.
Added in the /boot/config.txt file:
dtoverlay=pi3-disable-bt
dtoverlay=hifiberry-dacplus
And commented onboard sound.
My setup is headless wifi using an open onboard Wifi.
As soon as I add dtoverlay=hifiberry-dacplus in the config.txt file and reboot, the wifi does not work anymore. It clearly does not associate with the AP anymore.
I've tried this with two different RPI3 in two different locations on two different AP and Wifi network.
The content of wpa_supplicant.conf is
update_config=1
network={
ssid="SpeedTouch6B5EF1"
key_mgmt=NONE
Below you have the syslog for the boot cycle. You will see that for any reason, the wifi cannot authenticate. Then, it seems the hifiberry is initializing but I'm not sure. If you can help analyzing this log and undertsand what is happening, would be helpful. If the overlay for hifiberry is commented, everything works fine.
You will find the syslog in two posts because the forum rules limits to 6000 caracters and ext txt is not allowed.
SYSLOG PART ONE:
Mar 14 23:55:19 raspberrypi systemd[1]: Started Synchronise Hardware Clock to System Clock.
Mar 14 23:55:19 raspberrypi systemd[1]: Deactivating swap /var/swap...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Bluetooth.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopped target Bluetooth.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping system-systemd\x2dfsck.slice.
Mar 14 23:55:19 raspberrypi systemd[1]: Removed slice system-systemd\x2dfsck.slice.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Bluetooth service...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Graphical Interface.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopped target Graphical Interface.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Multi-User System.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopped target Multi-User System.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping OpenBSD Secure Shell server...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Regular background program processing daemon...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Login Prompts.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopped target Login Prompts.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Getty on tty1...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Serial Getty on ttyS0...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Login Service...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping LSB: Autogenerate and use a swap file...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping LSB: Start NTP daemon...
Mar 14 23:55:19 raspberrypi bluetoothd[641]: Terminating
Mar 14 23:55:19 raspberrypi bluetoothd[641]: Stopping SDP server
Mar 14 23:55:19 raspberrypi bluetoothd[641]: Exit
Mar 14 23:55:19 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Mon Mar 14 23:55:49 2016 [try http://www.rsyslog.com/e/2007 ]
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping LSB: triggerhappy hotkey daemon...
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Mar 14 23:55:19 raspberrypi avahi-daemon[480]: Got SIGTERM, quitting.
Mar 14 23:55:19 raspberrypi avahi-daemon[480]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::ba27:ebff:fee2:1d08.
Mar 14 23:55:19 raspberrypi avahi-daemon[480]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.70.
Mar 14 23:55:19 raspberrypi avahi-daemon[480]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9a62:491f:6f70:d2fc.
Mar 14 23:55:19 raspberrypi avahi-daemon[480]: avahi-daemon 0.6.31 exiting.
Mar 14 23:55:19 raspberrypi systemd[1]: Stopping D-Bus System Message Bus...
Mar 14 23:55:19 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="538" x-info="http://www.rsyslog.com"] exiting on signal 15.
Mar 14 23:56:24 hifiberry rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="483" x-info="http://www.rsyslog.com"] start
Mar 14 23:56:24 hifiberry systemd[1]: Mounted Configuration File System.
Mar 14 23:56:24 hifiberry systemd[1]: Started Apply Kernel Variables.
Mar 14 23:56:24 hifiberry systemd[1]: Started Create Static Device Nodes in /dev.
Mar 14 23:56:24 hifiberry systemd[1]: Starting udev Kernel Device Manager...
Mar 14 23:56:24 hifiberry systemd[1]: Started udev Kernel Device Manager.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Copy rules generated while the root was ro...
Mar 14 23:56:24 hifiberry systemd[1]: Starting LSB: Set preliminary keymap...
Mar 14 23:56:24 hifiberry systemd[1]: Started Copy rules generated while the root was ro.
Mar 14 23:56:24 hifiberry systemd-fsck[72]: e2fsck 1.42.12 (29-Aug-2014)
Mar 14 23:56:24 hifiberry systemd-fsck[72]: /dev/mmcblk0p2: clean, 34710/948480 files, 311437/3911424 blocks
Mar 14 23:56:24 hifiberry fake-hwclock[75]: Mon 14 Mar 23:55:20 UTC 2016
Mar 14 23:56:24 hifiberry systemd[1]: Found device /dev/ttyAMA0.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Sound Card.
Mar 14 23:56:24 hifiberry systemd[1]: Reached target Sound Card.
Mar 14 23:56:24 hifiberry systemd[1]: Found device /dev/mmcblk0p1.
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Booting Linux on physical CPU 0x0
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Initializing cgroup subsys cpuset
Mar 14 23:56:24 hifiberry systemd[1]: Starting File System Check on /dev/mmcblk0p1...
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Initializing cgroup subsys cpuacct
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Linux version 4.1.19-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #853 SMP Wed Mar 9 18:09:16 GMT 2016
Mar 14 23:56:24 hifiberry keyboard-setup[108]: Setting preliminary keymap...done.
Mar 14 23:56:24 hifiberry kernel: [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Mar 14 23:56:24 hifiberry kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
Mar 14 23:56:24 hifiberry systemd[1]: Started LSB: Set preliminary keymap.
Mar 14 23:56:24 hifiberry kernel: [    0.000000] cma: Reserved 8 MiB at 0x3a400000
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Memory policy: Data cache writealloc
Mar 14 23:56:24 hifiberry kernel: [    0.000000] On node 0 totalpages: 241664
Mar 14 23:56:24 hifiberry kernel: [    0.000000] free_area_init_node: node 0, pgdat 80880fc0, node_mem_map b9bb4000
Mar 14 23:56:24 hifiberry systemd[1]: Started Show Plymouth Boot Screen.
Mar 14 23:56:24 hifiberry kernel: [    0.000000]   Normal zone: 2124 pages used for memmap
Mar 14 23:56:24 hifiberry kernel: [    0.000000]   Normal zone: 0 pages reserved
Mar 14 23:56:24 hifiberry systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Mar 14 23:56:24 hifiberry kernel: [    0.000000]   Normal zone: 241664 pages, LIFO batch:31
Mar 14 23:56:24 hifiberry kernel: [    0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
Mar 14 23:56:24 hifiberry kernel: [    0.000000] [bcm2709_smp_init_cpus] ncores=4
Mar 14 23:56:24 hifiberry kernel: [    0.000000] PERCPU: Embedded 12 pages/cpu @bafb0000 s20416 r8192 d20544 u49152
Mar 14 23:56:24 hifiberry systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
Mar 14 23:56:24 hifiberry kernel: [    0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
Mar 14 23:56:24 hifiberry kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
Mar 14 23:56:24 hifiberry systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xafb7485d smsc95xx.macaddr=B8:27:EB:B7:48:5D bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 14 23:56:24 hifiberry kernel: [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Mar 14 23:56:24 hifiberry systemd[1]: Starting Paths.
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Memory: 939376K/966656K available (6064K kernel code, 534K rwdata, 1664K rodata, 444K init, 757K bss, 19088K reserved, 8192K cma-reserved)
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Virtual kernel memory layout:
Mar 14 23:56:24 hifiberry kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Mar 14 23:56:24 hifiberry systemd[1]: Reached target Paths.
Mar 14 23:56:24 hifiberry kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Mar 14 23:56:24 hifiberry kernel: [    0.000000]     vmalloc : 0xbb800000 - 0xff000000   (1080 MB)
Mar 14 23:56:24 hifiberry kernel: [    0.000000]     lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
Mar 14 23:56:24 hifiberry systemd[1]: Starting Remount Root and Kernel File Systems...
Mar 14 23:56:24 hifiberry kernel: [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
Mar 14 23:56:24 hifiberry kernel: [    0.000000]       .text : 0x80008000 - 0x807945f0   (7730 kB)
Mar 14 23:56:24 hifiberry kernel: [    0.000000]       .init : 0x80795000 - 0x80804000   ( 444 kB)
Mar 14 23:56:24 hifiberry kernel: [    0.000000]       .data : 0x80804000 - 0x80889b10   ( 535 kB)
Mar 14 23:56:24 hifiberry systemd[1]: Started Remount Root and Kernel File Systems.
Mar 14 23:56:24 hifiberry kernel: [    0.000000]        .bss : 0x8088c000 - 0x809497dc   ( 758 kB)
Mar 14 23:56:24 hifiberry kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Hierarchical RCU implementation.
Mar 14 23:56:24 hifiberry systemd-fsck[171]: fsck.fat 3.0.27 (2014-11-12)
Mar 14 23:56:24 hifiberry kernel: [    0.000000]     Additional per-CPU info printed with stalls.
Mar 14 23:56:24 hifiberry kernel: [    0.000000] NR_IRQS:608
Mar 14 23:56:24 hifiberry kernel: [    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
Mar 14 23:56:24 hifiberry systemd-fsck[171]: /dev/mmcblk0p1: 87 files, 2552/7673 clusters
Mar 14 23:56:24 hifiberry kernel: [    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Mar 14 23:56:24 hifiberry kernel: [    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Mar 14 23:56:24 hifiberry kernel: [    0.000025] Switching to timer-based delay loop, resolution 52ns
Mar 14 23:56:24 hifiberry kernel: [    0.000245] Console: colour dummy device 80x30
Mar 14 23:56:24 hifiberry systemd[1]: Started File System Check on /dev/mmcblk0p1.
Mar 14 23:56:24 hifiberry kernel: [    0.001293] console [tty1] enabled
Mar 14 23:56:24 hifiberry kernel: [    0.001346] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Mar 14 23:56:24 hifiberry kernel: [    0.001414] pid_max: default: 32768 minimum: 301
Mar 14 23:56:24 hifiberry systemd[1]: Started Various fixups to make systemd work better on Debian.
Mar 14 23:56:24 hifiberry kernel: [    0.001730] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.001773] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.002770] Initializing cgroup subsys blkio
Mar 14 23:56:24 hifiberry kernel: [    0.002819] Initializing cgroup subsys memory
Mar 14 23:56:24 hifiberry systemd[1]: Starting Load/Save Random Seed...
Mar 14 23:56:24 hifiberry kernel: [    0.002867] Initializing cgroup subsys devices
Mar 14 23:56:24 hifiberry kernel: [    0.002911] Initializing cgroup subsys freezer
Mar 14 23:56:24 hifiberry kernel: [    0.002960] Initializing cgroup subsys net_cls
Mar 14 23:56:24 hifiberry kernel: [    0.003031] CPU: Testing write buffer coherency: ok
Mar 14 23:56:24 hifiberry systemd[1]: Starting Local File Systems (Pre).
Mar 14 23:56:24 hifiberry kernel: [    0.003117] ftrace: allocating 20313 entries in 60 pages
Mar 14 23:56:24 hifiberry kernel: [    0.048352] CPU0: update cpu_capacity 1024
Mar 14 23:56:24 hifiberry kernel: [    0.048417] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Mar 14 23:56:24 hifiberry systemd[1]: Reached target Local File Systems (Pre).
Mar 14 23:56:24 hifiberry kernel: [    0.048452] [bcm2709_smp_prepare_cpus] enter
Mar 14 23:56:24 hifiberry kernel: [    0.048605] Setting up static identity map for 0x8240 - 0x8274
Mar 14 23:56:24 hifiberry kernel: [    0.050372] [bcm2709_boot_secondary] cpu:1 started (0) 17
Mar 14 23:56:24 hifiberry systemd[1]: Mounting /boot...
Mar 14 23:56:24 hifiberry kernel: [    0.050576] [bcm2709_secondary_init] enter cpu:1
Mar 14 23:56:24 hifiberry kernel: [    0.050616] CPU1: update cpu_capacity 1024
Mar 14 23:56:24 hifiberry kernel: [    0.050623] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Mar 14 23:56:24 hifiberry systemd[1]: Started Load/Save Random Seed.
Mar 14 23:56:24 hifiberry kernel: [    0.051010] [bcm2709_boot_secondary] cpu:2 started (0) 18
Mar 14 23:56:24 hifiberry kernel: [    0.051175] [bcm2709_secondary_init] enter cpu:2
Mar 14 23:56:24 hifiberry kernel: [    0.051197] CPU2: update cpu_capacity 1024
Mar 14 23:56:24 hifiberry kernel: [    0.051203] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Mar 14 23:56:24 hifiberry systemd[1]: Starting system-systemd\x2drfkill.slice.
Mar 14 23:56:24 hifiberry kernel: [    0.051563] [bcm2709_boot_secondary] cpu:3 started (0) 18
Mar 14 23:56:24 hifiberry kernel: [    0.051694] [bcm2709_secondary_init] enter cpu:3
Mar 14 23:56:24 hifiberry kernel: [    0.051715] CPU3: update cpu_capacity 1024
Mar 14 23:56:24 hifiberry systemd[1]: Created slice system-systemd\x2drfkill.slice.
Mar 14 23:56:24 hifiberry kernel: [    0.051721] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Mar 14 23:56:24 hifiberry kernel: [    0.051783] Brought up 4 CPUs
Mar 14 23:56:24 hifiberry kernel: [    0.051882] SMP: Total of 4 processors activated (153.60 BogoMIPS).
Mar 14 23:56:24 hifiberry kernel: [    0.051911] CPU: All CPU(s) started in HYP mode.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Load/Save RF Kill Switch Status of rfkill0...
Mar 14 23:56:24 hifiberry kernel: [    0.051938] CPU: Virtualization extensions available.
Mar 14 23:56:24 hifiberry kernel: [    0.052635] devtmpfs: initialized
Mar 14 23:56:24 hifiberry kernel: [    0.071614] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Mar 14 23:56:24 hifiberry systemd[1]: Mounted /boot.
Mar 14 23:56:24 hifiberry kernel: [    0.071882] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mar 14 23:56:24 hifiberry kernel: [    0.072746] pinctrl core: initialized pinctrl subsystem
Mar 14 23:56:24 hifiberry systemd[1]: Starting Local File Systems.
Mar 14 23:56:24 hifiberry kernel: [    0.073297] NET: Registered protocol family 16
Mar 14 23:56:24 hifiberry kernel: [    0.078419] DMA: preallocated 4096 KiB pool for atomic coherent allocations
Mar 14 23:56:24 hifiberry kernel: [    0.079394] bcm2709.uart_clock = 48000000
Mar 14 23:56:24 hifiberry systemd[1]: Reached target Local File Systems.
Mar 14 23:56:24 hifiberry kernel: [    0.083824] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Mar 14 23:56:24 hifiberry kernel: [    0.083873] hw-breakpoint: maximum watchpoint size is 8 bytes.
Mar 14 23:56:24 hifiberry kernel: [    0.084054] Serial: AMBA PL011 UART driver
Mar 14 23:56:24 hifiberry systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Mar 14 23:56:24 hifiberry kernel: [    0.084118] uart-pl011 3f201000.uart: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
Mar 14 23:56:24 hifiberry kernel: [    0.084316] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Mar 14 23:56:24 hifiberry systemd[1]: Starting Create Volatile Files and Directories...
Mar 14 23:56:24 hifiberry kernel: [    0.149066] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
Mar 14 23:56:24 hifiberry kernel: [    0.149137] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
Mar 14 23:56:24 hifiberry kernel: [    0.149725] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
Mar 14 23:56:24 hifiberry systemd[1]: Starting LSB: Raise network interfaces....
Mar 14 23:56:24 hifiberry kernel: [    0.149761] bcm2708-dmaengine 3f007000.dma: dma_debug:0
Mar 14 23:56:24 hifiberry kernel: [    0.150346] SCSI subsystem initialized
Mar 14 23:56:24 hifiberry kernel: [    0.150549] usbcore: registered new interface driver usbfs
Mar 14 23:56:24 hifiberry systemd[1]: Starting Remote File Systems.
Mar 14 23:56:24 hifiberry kernel: [    0.150656] usbcore: registered new interface driver hub
Mar 14 23:56:24 hifiberry kernel: [    0.150776] usbcore: registered new device driver usb
Mar 14 23:56:24 hifiberry systemd[1]: Reached target Remote File Systems.
Mar 14 23:56:24 hifiberry kernel: [    0.151339] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-09 18:11
Mar 14 23:56:24 hifiberry kernel: [    0.178442] Switched to clocksource arch_sys_counter
Mar 14 23:56:24 hifiberry kernel: [    0.219778] FS-Cache: Loaded
Mar 14 23:56:24 hifiberry kernel: [    0.220058] CacheFiles: Loaded
Mar 14 23:56:24 hifiberry systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Mar 14 23:56:24 hifiberry kernel: [    0.229380] NET: Registered protocol family 2
Mar 14 23:56:24 hifiberry kernel: [    0.230337] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.230478] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Mar 14 23:56:24 hifiberry systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Mar 14 23:56:24 hifiberry kernel: [    0.230688] TCP: Hash tables configured (established 8192 bind 8192)
Mar 14 23:56:24 hifiberry kernel: [    0.230802] UDP hash table entries: 512 (order: 2, 16384 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.230870] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Mar 14 23:56:24 hifiberry systemd[1]: Starting LSB: Prepare console...
Mar 14 23:56:24 hifiberry kernel: [    0.231202] NET: Registered protocol family 1
Mar 14 23:56:24 hifiberry systemd[1]: Started Load/Save RF Kill Switch Status of rfkill0.
Mar 14 23:56:24 hifiberry kernel: [    0.231523] RPC: Registered named UNIX socket transport module.
Mar 14 23:56:24 hifiberry kernel: [    0.231556] RPC: Registered udp transport module.
Mar 14 23:56:24 hifiberry kernel: [    0.231584] RPC: Registered tcp transport module.
Mar 14 23:56:24 hifiberry kernel: [    0.231611] RPC: Registered tcp NFSv4.1 backchannel transport module.
Mar 14 23:56:24 hifiberry systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Mar 14 23:56:24 hifiberry kernel: [    0.232582] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Mar 14 23:56:24 hifiberry raspi-config[206]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Mar 14 23:56:24 hifiberry raspi-config[206]: No. Switching to ondemand scaling governor.
Mar 14 23:56:24 hifiberry systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Mar 14 23:56:24 hifiberry systemd[1]: Started Create Volatile Files and Directories.
Mar 14 23:56:24 hifiberry kbd[208]: Setting console screen modes.
Mar 14 23:56:24 hifiberry systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Mar 14 23:56:24 hifiberry systemd[1]: Started Update UTMP about System Boot/Shutdown.
Mar 14 23:56:24 hifiberry kbd[208]: setterm: $TERM is not defined.
Mar 14 23:56:24 hifiberry systemd[1]: Started LSB: Prepare console.
Mar 14 23:56:24 hifiberry systemd[1]: Starting LSB: Set console font and keymap...
Mar 14 23:56:24 hifiberry wpa_supplicant[298]: Successfully initialized wpa_supplicant
Mar 14 23:56:24 hifiberry console-setup[279]: Setting up console font and keymap...done.
Mar 14 23:56:24 hifiberry systemd[1]: Started LSB: Set console font and keymap.
Mar 14 23:56:24 hifiberry dhclient: Internet Systems Consortium DHCP Client 4.3.1
Mar 14 23:56:24 hifiberry dhclient: Copyright 2004-2014 Internet Systems Consortium.
Mar 14 23:56:24 hifiberry dhclient: All rights reserved.
Mar 14 23:56:24 hifiberry dhclient: For info, please visit https://www.isc.org/software/dhcp/
Mar 14 23:56:24 hifiberry networking[200]: Configuring network interfaces...Internet Systems Consortium DHCP Client 4.3.1
Mar 14 23:56:24 hifiberry networking[200]: Copyright 2004-2014 Internet Systems Consortium.
Mar 14 23:56:24 hifiberry kernel: [    0.233675] futex hash table entries: 1024 (order: 4, 65536 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.247084] VFS: Disk quotas dquot_6.6.0
Mar 14 23:56:24 hifiberry kernel: [    0.247418] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.249522] FS-Cache: Netfs 'nfs' registered for caching
Mar 14 23:56:24 hifiberry networking[200]: All rights reserved.
Mar 14 23:56:24 hifiberry kernel: [    0.250455] NFS: Registering the id_resolver key type
Mar 14 23:56:24 hifiberry kernel: [    0.250524] Key type id_resolver registered
Mar 14 23:56:24 hifiberry kernel: [    0.250552] Key type id_legacy registered
Mar 14 23:56:24 hifiberry kernel: [    0.252611] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Mar 14 23:56:24 hifiberry networking[200]: For info, please visit https://www.isc.org/software/dhcp/
Mar 14 23:56:24 hifiberry kernel: [    0.252773] io scheduler noop registered
Mar 14 23:56:24 hifiberry kernel: [    0.252813] io scheduler deadline registered (default)
Mar 14 23:56:24 hifiberry dhclient: Listening on LPF/wlan0/b8:27:eb:e2:1d:08
Mar 14 23:56:24 hifiberry kernel: [    0.253110] io scheduler cfq registered
Mar 14 23:56:24 hifiberry kernel: [    0.255410] BCM2708FB: allocated DMA memory fa800000
Mar 14 23:56:24 hifiberry kernel: [    0.255456] BCM2708FB: allocated DMA channel 0 @ f3007000
Mar 14 23:56:24 hifiberry kernel: [    0.260501] Console: switching to colour frame buffer device 82x26
Mar 14 23:56:24 hifiberry dhclient: Sending on   LPF/wlan0/b8:27:eb:e2:1d:08
Mar 14 23:56:24 hifiberry kernel: [    0.264876] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Mar 14 23:56:24 hifiberry kernel: [    0.267447] vc-cma: Videocore CMA driver
Mar 14 23:56:24 hifiberry dhclient: Sending on   Socket/fallback
Mar 14 23:56:24 hifiberry kernel: [    0.268902] vc-cma: vc_cma_base      = 0x00000000
Mar 14 23:56:24 hifiberry kernel: [    0.270320] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
Mar 14 23:56:24 hifiberry kernel: [    0.271686] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
Mar 14 23:56:24 hifiberry kernel: [    0.273157] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
Mar 14 23:56:24 hifiberry dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
Mar 14 23:56:24 hifiberry kernel: [    0.287215] brd: module loaded
Mar 14 23:56:24 hifiberry kernel: [    0.295520] loop: module loaded
Mar 14 23:56:24 hifiberry kernel: [    0.297547] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
Mar 14 23:56:24 hifiberry networking[200]: Listening on LPF/wlan0/b8:27:eb:e2:1d:08
Mar 14 23:56:24 hifiberry kernel: [    0.300359] Loading iSCSI transport class v2.0-870.
Mar 14 23:56:24 hifiberry kernel: [    0.302282] usbcore: registered new interface driver smsc95xx
Mar 14 23:56:24 hifiberry kernel: [    0.303642] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Mar 14 23:56:24 hifiberry networking[200]: Sending on   LPF/wlan0/b8:27:eb:e2:1d:08
Mar 14 23:56:24 hifiberry kernel: [    0.505215] Core Release: 2.80a
Mar 14 23:56:24 hifiberry kernel: [    0.506458] Setting default values for core params
Mar 14 23:56:24 hifiberry kernel: [    0.507737] Finished setting default values for core params
Mar 14 23:56:24 hifiberry kernel: [    0.709389] Using Buffer DMA mode
Mar 14 23:56:24 hifiberry networking[200]: Sending on   Socket/fallback
Mar 14 23:56:24 hifiberry kernel: [    0.710674] Periodic Transfer Interrupt Enhancement - disabled
Mar 14 23:56:24 hifiberry kernel: [    0.712001] Multiprocessor Interrupt Enhancement - disabled
Mar 14 23:56:24 hifiberry kernel: [    0.713361] OTG VER PARAM: 0, OTG VER FLAG: 0
Mar 14 23:56:24 hifiberry networking[200]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
Mar 14 23:56:24 hifiberry kernel: [    0.714697] Dedicated Tx FIFOs mode
Mar 14 23:56:24 hifiberry kernel: [    0.716272] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
Mar 14 23:56:24 hifiberry kernel: [    0.719014] FIQ FSM acceleration enabled for :
Mar 14 23:56:24 hifiberry kernel: [    0.719014] Non-periodic Split Transactions
Mar 14 23:56:24 hifiberry wpa_supplicant[328]: wlan0: Trying to associate with SSID 'SpeedTouch6B5EF1'
Mar 14 23:56:24 hifiberry kernel: [    0.719014] Periodic Split Transactions
Mar 14 23:56:24 hifiberry kernel: [    0.719014] High-Speed Isochronous Endpoints
Mar 14 23:56:24 hifiberry kernel: [    0.724542] dwc_otg: Microframe scheduler enabled
Mar 14 23:56:24 hifiberry wpa_supplicant[328]: wlan0: CTRL-EVENT-ASSOC-REJECT status_code=16
Mar 14 23:56:24 hifiberry kernel: [    0.724590] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80417288
Mar 14 23:56:24 hifiberry kernel: [    0.725983] WARN::hcd_init_fiq:413: FIQ ASM at 0x804175f8 length 36
Mar 14 23:56:24 hifiberry kernel: [    0.727389] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89c000
Mar 14 23:56:24 hifiberry kernel: [    0.728797] dwc_otg 3f980000.usb: DWC OTG Controller
Mar 14 23:56:24 hifiberry kernel: [    0.730166] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Mar 14 23:56:24 hifiberry kernel: [    0.731557] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
Mar 14 23:56:24 hifiberry kernel: [    0.732940] Init: Port Power? op_state=1
Mar 14 23:56:24 hifiberry kernel: [    0.734253] Init: Power Port (0)
Mar 14 23:56:24 hifiberry kernel: [    0.735719] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Mar 14 23:56:24 hifiberry dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
Mar 14 23:56:24 hifiberry kernel: [    0.737077] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 14 23:56:24 hifiberry kernel: [    0.738425] usb usb1: Product: DWC OTG Controller
Mar 14 23:56:24 hifiberry kernel: [    0.739766] usb usb1: Manufacturer: Linux 4.1.19-v7+ dwc_otg_hcd
Mar 14 23:56:24 hifiberry kernel: [    0.741094] usb usb1: SerialNumber: 3f980000.usb
Mar 14 23:56:24 hifiberry networking[200]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
Mar 14 23:56:24 hifiberry kernel: [    0.743046] hub 1-0:1.0: USB hub found
Mar 14 23:56:24 hifiberry kernel: [    0.744376] hub 1-0:1.0: 1 port detected
Mar 14 23:56:24 hifiberry kernel: [    0.745985] dwc_otg: FIQ enabled
Mar 14 23:56:24 hifiberry kernel: [    0.745995] dwc_otg: NAK holdoff enabled
Mar 14 23:56:24 hifiberry kernel: [    0.746003] dwc_otg: FIQ split-transaction FSM enabled
Mar 14 23:56:24 hifiberry kernel: [    0.746033] Module dwc_common_port init
Mar 14 23:56:24 hifiberry kernel: [    0.746299] usbcore: registered new interface driver usb-storage
Mar 14 23:56:24 hifiberry kernel: [    0.747713] mousedev: PS/2 mouse device common for all mice
Mar 14 23:56:24 hifiberry kernel: [    0.749650] bcm2835-cpufreq: min=600000 max=1200000
Mar 14 23:56:24 hifiberry kernel: [    0.751176] sdhci: Secure Digital Host Controller Interface driver
Mar 14 23:56:24 hifiberry kernel: [    0.752477] sdhci: Copyright(c) Pierre Ossman
Mar 14 23:56:24 hifiberry kernel: [    0.754050] sdhost: log_buf @ ba813000 (fa813000)
Mar 14 23:56:24 hifiberry kernel: [    0.828479] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Mar 14 23:56:24 hifiberry kernel: [    0.852250] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
Mar 14 23:56:24 hifiberry wpa_supplicant[328]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="SpeedTouch6B5EF1" auth_failures=1 duration=10 reason=CONN_FAILED
Mar 14 23:56:24 hifiberry kernel: [    0.853596] mmc-bcm2835 3f300000.mmc: DMA channel allocated
Mar 14 23:56:24 hifiberry kernel: [    0.888553] sdhci-pltfm: SDHCI platform and OF driver helper
Mar 14 23:56:24 hifiberry kernel: [    0.889365] mmc0: host does not support reading read-only switch, assuming write-enable
Mar 14 23:56:24 hifiberry dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 21
Mar 14 23:56:24 hifiberry kernel: [    0.892217] mmc0: new high speed SDHC card at address 59b4
Mar 14 23:56:24 hifiberry kernel: [    0.892616] mmcblk0: mmc0:59b4 USDU1 15.0 GiB
Mar 14 23:56:24 hifiberry kernel: [    0.893813]  mmcblk0: p1 p2
Mar 14 23:56:24 hifiberry kernel: [    0.896924] ledtrig-cpu: registered to indicate activity on CPUs
Mar 14 23:56:24 hifiberry networking[200]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 21
Mar 14 23:56:24 hifiberry kernel: [    0.898467] hidraw: raw HID events driver (C) Jiri Kosina
Mar 14 23:56:24 hifiberry kernel: [    0.900034] usbcore: registered new interface driver usbhid
Mar 14 23:56:24 hifiberry dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19
Mar 14 23:56:24 hifiberry kernel: [    0.901420] usbhid: USB HID core driver
Mar 14 23:56:24 hifiberry kernel: [    0.903202] Initializing XFRM netlink socket
Mar 14 23:56:24 hifiberry kernel: [    0.904625] NET: Registered protocol family 17
Mar 14 23:56:24 hifiberry kernel: [    0.906124] Key type dns_resolver registered
Mar 14 23:56:24 hifiberry networking[200]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19
Mar 14 23:56:24 hifiberry kernel: [    0.907903] Registering SWP/SWPB emulation handler
Mar 14 23:56:24 hifiberry kernel: [    0.909934] registered taskstats version 1
Mar 14 23:56:24 hifiberry kernel: [    0.910701] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Mar 14 23:56:24 hifiberry dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
Mar 14 23:56:24 hifiberry kernel: [    0.912266] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.913834] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.915300] vc-sm: Videocore shared memory driver
Mar 14 23:56:24 hifiberry networking[200]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
Mar 14 23:56:24 hifiberry kernel: [    0.916540] [vc_sm_connected_init]: start
Mar 14 23:56:24 hifiberry kernel: [    0.916635] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.919528] [vc_sm_connected_init]: end - returning 0
Mar 14 23:56:24 hifiberry kernel: [    0.921767] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
Mar 14 23:56:24 hifiberry dhclient: No DHCPOFFERS received.
Mar 14 23:56:24 hifiberry kernel: [    0.963099] Indeed it is in host mode hprt0 = 00021501
Mar 14 23:56:24 hifiberry kernel: [    1.008263] mmc1: new high speed SDIO card at address 0001
Mar 14 23:56:24 hifiberry kernel: [    1.138477] usb 1-1: new high-speed USB device number 2 using dwc_otg
Mar 14 23:56:24 hifiberry dhclient: No working leases in persistent database - sleeping.
Mar 14 23:56:24 hifiberry kernel: [    1.138605] Indeed it is in host mode hprt0 = 00001101
Mar 14 23:56:24 hifiberry kernel: [    1.328735] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Mar 14 23:56:24 hifiberry kernel: [    1.328744] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 14 23:56:24 hifiberry networking[200]: No DHCPOFFERS received.
Mar 14 23:56:24 hifiberry kernel: [    1.329378] hub 1-1:1.0: USB hub found
Mar 14 23:56:24 hifiberry kernel: [    1.329472] hub 1-1:1.0: 5 ports detected
Mar 14 23:56:24 hifiberry kernel: [    1.608472] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Mar 14 23:56:24 hifiberry kernel: [    1.708712] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Mar 14 23:56:24 hifiberry networking[200]: No working leases in persistent database - sleeping.
Mar 14 23:56:24 hifiberry kernel: [    1.708720] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 14 23:56:24 hifiberry kernel: [    1.711329] smsc95xx v1.0.4
Mar 14 23:56:24 hifiberry networking[200]: done.
Mar 14 23:56:24 hifiberry kernel: [    1.771675] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b7:48:5d
Superkikim
Re: RPI3 with HifiBerry, Wifi does not connect
Tue Mar 15, 2016 12:40 pm
SYSLOG PART 2:
Mar 14 23:56:24 hifiberry kernel: [    2.101713] console [ttyAMA0] enabled
Mar 14 23:56:24 hifiberry kernel: [    2.140475] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Mar 14 23:56:24 hifiberry kernel: [    2.151157] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Mar 14 23:56:24 hifiberry systemd[1]: Started LSB: Raise network interfaces..
Mar 14 23:56:24 hifiberry kernel: [    2.171006] devtmpfs: mounted
Mar 14 23:56:24 hifiberry kernel: [    2.175961] Freeing unused kernel memory: 444K (80795000 - 80804000)
Mar 14 23:56:24 hifiberry kernel: [    2.697228] random: systemd urandom read with 70 bits of entropy available
Mar 14 23:56:24 hifiberry systemd[1]: Starting System Initialization.
Mar 14 23:56:24 hifiberry kernel: [    2.847967] NET: Registered protocol family 10
Mar 14 23:56:24 hifiberry kernel: [    2.963988] uart-pl011 3f201000.uart: no DMA platform data
Mar 14 23:56:24 hifiberry systemd[1]: Reached target System Initialization.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Avahi mDNS/DNS-SD Stack Activation Socket.
Mar 14 23:56:24 hifiberry systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Mar 14 23:56:24 hifiberry systemd[1]: Starting D-Bus System Message Bus Socket.
Mar 14 23:56:24 hifiberry systemd[1]: Listening on D-Bus System Message Bus Socket.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Sockets.
Mar 14 23:56:24 hifiberry systemd[1]: Reached target Sockets.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Daily Cleanup of Temporary Directories.
Mar 14 23:56:24 hifiberry systemd[1]: Started Daily Cleanup of Temporary Directories.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Timers.
Mar 14 23:56:24 hifiberry systemd[1]: Reached target Timers.
Mar 14 23:56:24 hifiberry systemd[1]: Started Manage Sound Card State (restore and store).
Mar 14 23:56:24 hifiberry systemd[1]: Starting Restore Sound Card State...
Mar 14 23:56:24 hifiberry systemd[1]: Starting Basic System.
Mar 14 23:56:24 hifiberry systemd[1]: Reached target Basic System.
Mar 14 23:56:24 hifiberry systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Mar 14 23:56:24 hifiberry systemd[1]: Starting Regular background program processing daemon...
Mar 14 23:56:24 hifiberry systemd[1]: Started Regular background program processing daemon.
Mar 14 23:56:24 hifiberry systemd[1]: Starting dhcpcd on all interfaces...
Mar 14 23:56:24 hifiberry alsactl[413]: No state is present for card sndrpihifiberry
Mar 14 23:56:24 hifiberry systemd[1]: Started getty on tty2-tty6 if dbus and logind are not available.
Mar 14 23:56:24 hifiberry kernel: [    4.707615] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Mar 14 23:56:24 hifiberry kernel: [    4.910405] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
Mar 14 23:56:24 hifiberry kernel: [    4.910449] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry kernel: [    5.137791] cfg80211: Calling CRDA to update world regulatory domain
Mar 14 23:56:24 hifiberry systemd[1]: Starting Login Service...
Mar 14 23:56:24 hifiberry kernel: [    5.231274] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
Mar 14 23:56:24 hifiberry kernel: [    5.231340] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry alsactl[413]: Found hardware: "snd_rpi_hifiber" "" "" "" ""
Mar 14 23:56:24 hifiberry kernel: [    5.242275] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
Mar 14 23:56:24 hifiberry kernel: [    5.243277] usbcore: registered new interface driver brcmfmac
Mar 14 23:56:24 hifiberry kernel: [    5.244018] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
Mar 14 23:56:24 hifiberry kernel: [    5.244036] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry alsactl[413]: Hardware is initialized using a generic method
Mar 14 23:56:24 hifiberry kernel: [    5.292769] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Mar 14 23:56:24 hifiberry kernel: [    5.468060] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
Mar 14 23:56:24 hifiberry kernel: [    5.502828] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
Mar 14 23:56:24 hifiberry systemd[1]: Starting LSB: Autogenerate and use a swap file...
Mar 14 23:56:24 hifiberry kernel: [    5.566895] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
Mar 14 23:56:24 hifiberry kernel: [    5.566948] cfg80211: World regulatory domain updated:
Mar 14 23:56:24 hifiberry kernel: [    5.566961] cfg80211:  DFS Master region: unset
Mar 14 23:56:24 hifiberry kernel: [    5.566981] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Mar 14 23:56:24 hifiberry kernel: [    5.567007] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    5.567021] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    5.567034] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry cron[415]: (CRON) INFO (pidfile fd = 3)
Mar 14 23:56:24 hifiberry kernel: [    5.567050] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    5.567064] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Mar 14 23:56:24 hifiberry systemd[1]: Starting LSB: triggerhappy hotkey daemon...
Mar 14 23:56:24 hifiberry kernel: [    5.567077] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Mar 14 23:56:24 hifiberry kernel: [    5.567089] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    5.567102] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Mar 14 23:56:24 hifiberry systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Mar 14 23:56:24 hifiberry kernel: [    5.709779] bcm2835-rng 3f104000.rng: hwrng registered
Mar 14 23:56:24 hifiberry kernel: [    5.710141] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
Mar 14 23:56:24 hifiberry kernel: [    5.710165] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry kernel: [    5.710488] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
Mar 14 23:56:24 hifiberry systemd[1]: Starting D-Bus System Message Bus...
Mar 14 23:56:24 hifiberry kernel: [    5.710723] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
Mar 14 23:56:24 hifiberry kernel: [    5.710739] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry systemd[1]: Started D-Bus System Message Bus.
Mar 14 23:56:24 hifiberry kernel: [    5.714002] snd-rpi-hifiberry-dacplus sound: ASoC: CODEC DAI pcm512x-hifi not registered
Mar 14 23:56:24 hifiberry kernel: [    5.714035] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry kernel: [    5.862183] snd-rpi-hifiberry-dacplus sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
Mar 14 23:56:24 hifiberry kernel: [    6.261426] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
Mar 14 23:56:24 hifiberry cron[415]: (CRON) INFO (Running @reboot jobs)
Mar 14 23:56:24 hifiberry kernel: [    6.261450] brcmfmac: brcmf_add_if: ignore IF event
Mar 14 23:56:24 hifiberry kernel: [    6.266423] brcmfmac: power management disabled
Mar 14 23:56:24 hifiberry dhcpcd[416]: version 6.7.1 starting
Mar 14 23:56:24 hifiberry kernel: [   14.075714] random: nonblocking pool is initialized
Mar 14 23:56:24 hifiberry kernel: [   68.076109] Adding 102396k swap on /var/swap.  Priority:-1 extents:3 across:184320k SSFS
Mar 14 23:56:24 hifiberry dphys-swapfile[419]: Starting dphys-swapfile swapfile setup ...
Mar 14 23:56:24 hifiberry dhcpcd[416]: dev: loaded udev
Mar 14 23:56:24 hifiberry dhcpcd[416]: eth0: adding address fe80::9a62:491f:6f70:d2fc
Mar 14 23:56:24 hifiberry triggerhappy[420]: Error opening '/dev/input/event*': No such file or directory
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Found user 'avahi' (UID 105) and group 'avahi' (GID 110).
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Successfully dropped root privileges.
Mar 14 23:56:24 hifiberry avahi-daemon[421]: avahi-daemon 0.6.31 starting up.
Mar 14 23:56:24 hifiberry dphys-swapfile[419]: want /var/swap=100MByte, checking existing: keeping it
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Successfully called chroot().
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Successfully dropped remaining capabilities.
Mar 14 23:56:24 hifiberry avahi-daemon[421]: No service file found in /etc/avahi/services.
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::ba27:ebff:fee2:1d08.
Mar 14 23:56:24 hifiberry avahi-daemon[421]: New relevant interface wlan0.IPv6 for mDNS.
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Network interface enumeration completed.
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Registering new address record for fe80::ba27:ebff:fee2:1d08 on wlan0.*.
Mar 14 23:56:24 hifiberry dbus[423]: [system] Successfully activated service 'org.freedesktop.systemd1'
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Registering HINFO record with values 'ARMV7L'/'LINUX'.
Mar 14 23:56:24 hifiberry systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Mar 14 23:56:24 hifiberry systemd[1]: Starting System Logging Service...
Mar 14 23:56:24 hifiberry systemd[1]: Starting Permit User Sessions...
Mar 14 23:56:24 hifiberry systemd[1]: Started Restore Sound Card State.
Mar 14 23:56:24 hifiberry systemd[1]: Started LSB: triggerhappy hotkey daemon.
Mar 14 23:56:24 hifiberry systemd[1]: Started Permit User Sessions.
Mar 14 23:56:24 hifiberry dphys-swapfile[419]: done.
Mar 14 23:56:24 hifiberry systemd[1]: Started LSB: Autogenerate and use a swap file.
Mar 14 23:56:24 hifiberry systemd[1]: Started Login Service.
Mar 14 23:56:24 hifiberry systemd[1]: Started System Logging Service.
Mar 14 23:56:24 hifiberry dhcpcd[416]: eth0: waiting for carrier
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9a62:491f:6f70:d2fc.
Mar 14 23:56:24 hifiberry avahi-daemon[421]: New relevant interface eth0.IPv6 for mDNS.
Mar 14 23:56:24 hifiberry avahi-daemon[421]: Registering new address record for fe80::9a62:491f:6f70:d2fc on eth0.*.
Mar 14 23:56:24 hifiberry dhcpcd[416]: wlan0: waiting for carrier
Mar 14 23:56:24 hifiberry kernel: [   68.240644] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Mar 14 23:56:24 hifiberry kernel: [   68.240857] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Mar 14 23:56:25 hifiberry avahi-daemon[421]: Server startup complete. Host name is hifiberry.local. Local service cookie is 2270718608.
Mar 14 23:56:53 hifiberry hciattach[414]: Initialization timed out.
Mar 14 23:56:53 hifiberry hciattach[414]: bcm43xx_init
Mar 14 23:56:53 hifiberry systemd[1]: hciuart.service: control process exited, code=exited status=1
Mar 14 23:56:53 hifiberry systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
Mar 14 23:56:53 hifiberry systemd[1]: Unit hciuart.service entered failed state.
Mar 14 23:56:54 hifiberry dhcpcd[416]: timed out
Mar 14 23:56:54 hifiberry dhcpcd[416]: forked to background, child pid 533
Mar 14 23:56:54 hifiberry systemd[1]: Started dhcpcd on all interfaces.
Mar 14 23:56:54 hifiberry systemd[1]: Starting Network.
Mar 14 23:56:54 hifiberry systemd[1]: Reached target Network.
Mar 14 23:56:54 hifiberry systemd[1]: Starting OpenBSD Secure Shell server...
Mar 14 23:56:54 hifiberry systemd[1]: Started OpenBSD Secure Shell server.
Mar 14 23:56:54 hifiberry systemd[1]: Starting /etc/rc.local Compatibility...
Mar 14 23:56:54 hifiberry systemd[1]: Starting Network is Online.
Mar 14 23:56:54 hifiberry systemd[1]: Reached target Network is Online.
Mar 14 23:56:54 hifiberry systemd[1]: Starting LSB: Start NTP daemon...
Mar 14 23:56:54 hifiberry systemd[1]: Started /etc/rc.local Compatibility.
Mar 14 23:56:54 hifiberry systemd[1]: Starting Wait for Plymouth Boot Screen to Quit...
Mar 14 23:56:54 hifiberry systemd[1]: Starting Terminate Plymouth Boot Screen...
Mar 14 23:56:54 hifiberry systemd[1]: Started Wait for Plymouth Boot Screen to Quit.
Mar 14 23:56:54 hifiberry systemd[1]: Started Terminate Plymouth Boot Screen.
Mar 14 23:56:54 hifiberry systemd[1]: Starting Getty on tty1...
Mar 14 23:56:54 hifiberry systemd[1]: Started Getty on tty1.
Mar 14 23:56:54 hifiberry systemd[1]: Starting Serial Getty on ttyAMA0...
Mar 14 23:56:54 hifiberry systemd[1]: Started Serial Getty on ttyAMA0.
Mar 14 23:56:54 hifiberry systemd[1]: Starting Login Prompts.
Mar 14 23:56:54 hifiberry systemd[1]: Reached target Login Prompts.
Mar 14 23:56:54 hifiberry ntpd[549]: ntpd [email protected] Mon Nov  2 04:29:47 UTC 2015 (1)
Mar 14 23:56:54 hifiberry ntp[536]: Starting NTP server: ntpd.
Mar 14 23:56:54 hifiberry ntpd[552]: proto: precision = 1.145 usec
Mar 14 23:56:54 hifiberry ntpd[552]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Mar 14 23:56:54 hifiberry systemd[1]: Started LSB: Start NTP daemon.
Mar 14 23:56:54 hifiberry systemd[1]: Starting Multi-User System.
Mar 14 23:56:54 hifiberry systemd[1]: Reached target Multi-User System.
Mar 14 23:56:54 hifiberry systemd[1]: Starting Graphical Interface.
Mar 14 23:56:54 hifiberry systemd[1]: Reached target Graphical Interface.
Mar 14 23:56:54 hifiberry systemd[1]: Starting Update UTMP about System Runlevel Changes...
Mar 14 23:56:54 hifiberry ntpd[552]: Listen and drop on 1 v6wildcard :: UDP 123
Mar 14 23:56:54 hifiberry ntpd[552]: Listen normally on 2 lo 127.0.0.1 UDP 123
Mar 14 23:56:54 hifiberry ntpd[552]: Listen normally on 3 lo ::1 UDP 123
Mar 14 23:56:54 hifiberry ntpd[552]: Listen normally on 4 wlan0 fe80::ba27:ebff:fee2:1d08 UDP 123
Mar 14 23:56:54 hifiberry ntpd[552]: peers refreshed
Mar 14 23:56:54 hifiberry ntpd[552]: Listening on routing socket on fd #21 for interface updates
Mar 14 23:56:54 hifiberry ntpd[552]: Deferring DNS for 0.debian.pool.ntp.org 1
Mar 14 23:56:54 hifiberry ntpd[552]: Deferring DNS for 1.debian.pool.ntp.org 1
Mar 14 23:56:54 hifiberry ntpd[552]: Deferring DNS for 2.debian.pool.ntp.org 1
Mar 14 23:56:54 hifiberry ntpd[552]: Deferring DNS for 3.debian.pool.ntp.org 1
Mar 14 23:56:54 hifiberry ntpd[556]: signal_no_reset: signal 17 had flags 4000000
Mar 14 23:56:54 hifiberry systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 14 23:56:54 hifiberry systemd[1]: Startup finished in 2.637s (kernel) + 1min 35.810s (userspace) = 1min 38.448s.
Mar 14 23:56:56 hifiberry ntpd_intres[556]: host name not found: 0.debian.pool.ntp.org
Mar 14 23:56:56 hifiberry ntpd_intres[556]: host name not found: 1.debian.pool.ntp.org
Mar 14 23:56:56 hifiberry ntpd_intres[556]: host name not found: 2.debian.pool.ntp.org
Mar 14 23:56:56 hifiberry ntpd_intres[556]: host name not found: 3.debian.pool.ntp.org
Mar 14 23:56:24 hifiberry rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="488" x-info="http://www.rsyslog.com"] start
Mar 14 23:56:24 hifiberry kernel: [    0.000026] Switching to timer-based delay loop, resolution 52ns
Mar 14 23:56:24 hifiberry kernel: [    0.000240] Console: colour dummy device 80x30
Mar 14 23:56:24 hifiberry kernel: [    0.001287] console [tty1] enabled
Mar 14 23:56:24 hifiberry kernel: [    0.001339] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Mar 14 23:56:24 hifiberry kernel: [    0.001408] pid_max: default: 32768 minimum: 301
Mar 14 23:56:24 hifiberry kernel: [    0.002786] Initializing cgroup subsys blkio
Mar 14 23:56:24 hifiberry kernel: [    0.002835] Initializing cgroup subsys memory
Mar 14 23:56:24 hifiberry kernel: [    0.002882] Initializing cgroup subsys devices
Mar 14 23:56:24 hifiberry kernel: [    0.002925] Initializing cgroup subsys freezer
Mar 14 23:56:24 hifiberry kernel: [    0.002974] Initializing cgroup subsys net_cls
Mar 14 23:56:24 hifiberry kernel: [    0.003046] CPU: Testing write buffer coherency: ok
Mar 14 23:56:24 hifiberry kernel: [    0.003135] ftrace: allocating 20313 entries in 60 pages
Mar 14 23:56:24 hifiberry kernel: [    0.048694] CPU0: update cpu_capacity 1024
Mar 14 23:56:24 hifiberry kernel: [    0.048757] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Mar 14 23:56:24 hifiberry kernel: [    0.048793] [bcm2709_smp_prepare_cpus] enter
Mar 14 23:56:24 hifiberry kernel: [    0.048942] Setting up static identity map for 0x8240 - 0x8274
Mar 14 23:56:24 hifiberry kernel: [    0.050697] [bcm2709_boot_secondary] cpu:1 started (0) 17
Mar 14 23:56:24 hifiberry kernel: [    0.050916] [bcm2709_secondary_init] enter cpu:1
Mar 14 23:56:24 hifiberry kernel: [    0.050958] CPU1: update cpu_capacity 1024
Mar 14 23:56:24 hifiberry kernel: [    0.050964] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Mar 14 23:56:24 hifiberry kernel: [    0.051342] [bcm2709_boot_secondary] cpu:2 started (0) 17
Mar 14 23:56:24 hifiberry kernel: [    0.051508] [bcm2709_secondary_init] enter cpu:2
Mar 14 23:56:24 hifiberry kernel: [    0.051530] CPU2: update cpu_capacity 1024
Mar 14 23:56:24 hifiberry kernel: [    0.051536] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Mar 14 23:56:24 hifiberry kernel: [    0.051902] [bcm2709_boot_secondary] cpu:3 started (0) 18
Mar 14 23:56:24 hifiberry kernel: [    0.052032] [bcm2709_secondary_init] enter cpu:3
Mar 14 23:56:24 hifiberry kernel: [    0.052052] CPU3: update cpu_capacity 1024
Mar 14 23:56:24 hifiberry kernel: [    0.052059] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Mar 14 23:56:24 hifiberry kernel: [    0.052121] Brought up 4 CPUs
Mar 14 23:56:24 hifiberry kernel: [    0.052219] SMP: Total of 4 processors activated (153.60 BogoMIPS).
Mar 14 23:56:24 hifiberry kernel: [    0.052248] CPU: All CPU(s) started in HYP mode.
Mar 14 23:56:24 hifiberry kernel: [    0.052274] CPU: Virtualization extensions available.
Mar 14 23:56:24 hifiberry kernel: [    0.052989] devtmpfs: initialized
Mar 14 23:56:24 hifiberry kernel: [    0.071939] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Mar 14 23:56:24 hifiberry kernel: [    0.072210] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mar 14 23:56:24 hifiberry kernel: [    0.073072] pinctrl core: initialized pinctrl subsystem
Mar 14 23:56:24 hifiberry kernel: [    0.073623] NET: Registered protocol family 16
Mar 14 23:56:24 hifiberry kernel: [    0.078744] DMA: preallocated 4096 KiB pool for atomic coherent allocations
Mar 14 23:56:24 hifiberry kernel: [    0.079718] bcm2709.uart_clock = 48000000
Mar 14 23:56:24 hifiberry kernel: [    0.084150] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Mar 14 23:56:24 hifiberry kernel: [    0.084199] hw-breakpoint: maximum watchpoint size is 8 bytes.
Mar 14 23:56:24 hifiberry kernel: [    0.084379] Serial: AMBA PL011 UART driver
Mar 14 23:56:24 hifiberry kernel: [    0.084444] uart-pl011 3f201000.uart: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
Mar 14 23:56:24 hifiberry kernel: [    0.084643] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Mar 14 23:56:24 hifiberry kernel: [    0.149409] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
Mar 14 23:56:24 hifiberry kernel: [    0.149480] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
Mar 14 23:56:24 hifiberry kernel: [    0.150068] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
Mar 14 23:56:24 hifiberry kernel: [    0.150106] bcm2708-dmaengine 3f007000.dma: dma_debug:0
Mar 14 23:56:24 hifiberry kernel: [    0.150695] SCSI subsystem initialized
Mar 14 23:56:24 hifiberry kernel: [    0.150899] usbcore: registered new interface driver usbfs
Mar 14 23:56:24 hifiberry kernel: [    0.151007] usbcore: registered new interface driver hub
Mar 14 23:56:24 hifiberry kernel: [    0.151126] usbcore: registered new device driver usb
Mar 14 23:56:24 hifiberry kernel: [    0.151689] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-09 18:11
Mar 14 23:56:24 hifiberry kernel: [    0.178790] Switched to clocksource arch_sys_counter
Mar 14 23:56:24 hifiberry kernel: [    0.220098] FS-Cache: Loaded
Mar 14 23:56:24 hifiberry kernel: [    0.220379] CacheFiles: Loaded
Mar 14 23:56:24 hifiberry kernel: [    0.229683] NET: Registered protocol family 2
Mar 14 23:56:24 hifiberry kernel: [    0.230642] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.230783] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.230994] TCP: Hash tables configured (established 8192 bind 8192)
Mar 14 23:56:24 hifiberry kernel: [    0.231107] UDP hash table entries: 512 (order: 2, 16384 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.231176] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.231506] NET: Registered protocol family 1
Mar 14 23:56:24 hifiberry kernel: [    0.231825] RPC: Registered named UNIX socket transport module.
Mar 14 23:56:24 hifiberry kernel: [    0.231858] RPC: Registered udp transport module.
Mar 14 23:56:24 hifiberry kernel: [    0.231885] RPC: Registered tcp transport module.
Mar 14 23:56:24 hifiberry kernel: [    0.231912] RPC: Registered tcp NFSv4.1 backchannel transport module.
Mar 14 23:56:24 hifiberry kernel: [    0.232883] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Mar 14 23:56:24 hifiberry systemd-fsck[72]: /dev/mmcblk0p2: clean, 34710/948480 files, 311465/3911424 blocks
Mar 14 23:56:24 hifiberry kernel: [    0.233975] futex hash table entries: 1024 (order: 4, 65536 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.247421] VFS: Disk quotas dquot_6.6.0
Mar 14 23:56:24 hifiberry kernel: [    0.247754] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.249856] FS-Cache: Netfs 'nfs' registered for caching
Mar 14 23:56:24 hifiberry kernel: [    0.250790] NFS: Registering the id_resolver key type
Mar 14 23:56:24 hifiberry kernel: [    0.250854] Key type id_resolver registered
Mar 14 23:56:24 hifiberry kernel: [    0.250883] Key type id_legacy registered
Mar 14 23:56:24 hifiberry kernel: [    0.252942] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Mar 14 23:56:24 hifiberry kernel: [    0.253116] io scheduler noop registered
Mar 14 23:56:24 hifiberry kernel: [    0.253156] io scheduler deadline registered (default)
Mar 14 23:56:24 hifiberry kernel: [    0.253453] io scheduler cfq registered
Mar 14 23:56:24 hifiberry kernel: [    0.255752] BCM2708FB: allocated DMA memory fa800000
Mar 14 23:56:24 hifiberry kernel: [    0.255799] BCM2708FB: allocated DMA channel 0 @ f3007000
Mar 14 23:56:24 hifiberry kernel: [    0.260810] Console: switching to colour frame buffer device 82x26
Mar 14 23:56:24 hifiberry kernel: [    0.265171] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Mar 14 23:56:24 hifiberry kernel: [    0.267743] vc-cma: Videocore CMA driver
Mar 14 23:56:24 hifiberry kernel: [    0.269198] vc-cma: vc_cma_base      = 0x00000000
Mar 14 23:56:24 hifiberry kernel: [    0.270617] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
Mar 14 23:56:24 hifiberry kernel: [    0.271985] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
Mar 14 23:56:24 hifiberry kernel: [    0.273456] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
Mar 14 23:56:24 hifiberry kernel: [    0.287521] brd: module loaded
Mar 14 23:56:24 hifiberry kernel: [    0.295807] loop: module loaded
Mar 14 23:56:24 hifiberry kernel: [    0.297834] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
Mar 14 23:56:24 hifiberry kernel: [    0.300651] Loading iSCSI transport class v2.0-870.
Mar 14 23:56:24 hifiberry kernel: [    0.302576] usbcore: registered new interface driver smsc95xx
Mar 14 23:56:24 hifiberry kernel: [    0.303936] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Mar 14 23:56:24 hifiberry kernel: [    0.505510] Core Release: 2.80a
Mar 14 23:56:24 hifiberry kernel: [    0.506753] Setting default values for core params
Mar 14 23:56:24 hifiberry kernel: [    0.508033] Finished setting default values for core params
Mar 14 23:56:24 hifiberry kernel: [    0.709684] Using Buffer DMA mode
Mar 14 23:56:24 hifiberry kernel: [    0.710970] Periodic Transfer Interrupt Enhancement - disabled
Mar 14 23:56:24 hifiberry kernel: [    0.712298] Multiprocessor Interrupt Enhancement - disabled
Mar 14 23:56:24 hifiberry kernel: [    0.713655] OTG VER PARAM: 0, OTG VER FLAG: 0
Mar 14 23:56:24 hifiberry kernel: [    0.714991] Dedicated Tx FIFOs mode
Mar 14 23:56:24 hifiberry kernel: [    0.716567] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
Mar 14 23:56:24 hifiberry kernel: [    0.719310] FIQ FSM acceleration enabled for :
Mar 14 23:56:24 hifiberry kernel: [    0.719310] Non-periodic Split Transactions
Mar 14 23:56:24 hifiberry kernel: [    0.719310] Periodic Split Transactions
Mar 14 23:56:24 hifiberry kernel: [    0.719310] High-Speed Isochronous Endpoints
Mar 14 23:56:24 hifiberry kernel: [    0.724834] dwc_otg: Microframe scheduler enabled
Mar 14 23:56:24 hifiberry kernel: [    0.724882] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80417288
Mar 14 23:56:24 hifiberry kernel: [    0.726274] WARN::hcd_init_fiq:413: FIQ ASM at 0x804175f8 length 36
Mar 14 23:56:24 hifiberry kernel: [    0.727679] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89c000
Mar 14 23:56:24 hifiberry systemd-fsck[177]: fsck.fat 3.0.27 (2014-11-12)
Mar 14 23:56:24 hifiberry kernel: [    0.729088] dwc_otg 3f980000.usb: DWC OTG Controller
Mar 14 23:56:24 hifiberry kernel: [    0.730455] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Mar 14 23:56:24 hifiberry kernel: [    0.731846] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
Mar 14 23:56:24 hifiberry kernel: [    0.733229] Init: Port Power? op_state=1
Mar 14 23:56:24 hifiberry systemd-fsck[177]: 0x25: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Mar 14 23:56:24 hifiberry kernel: [    0.734542] Init: Power Port (0)
Mar 14 23:56:24 hifiberry kernel: [    0.736005] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Mar 14 23:56:24 hifiberry kernel: [    0.737363] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 14 23:56:24 hifiberry systemd-fsck[177]: Automatically removing dirty bit.
Mar 14 23:56:24 hifiberry kernel: [    0.738711] usb usb1: Product: DWC OTG Controller
Mar 14 23:56:24 hifiberry kernel: [    0.740053] usb usb1: Manufacturer: Linux 4.1.19-v7+ dwc_otg_hcd
Mar 14 23:56:24 hifiberry kernel: [    0.741385] usb usb1: SerialNumber: 3f980000.usb
Mar 14 23:56:24 hifiberry systemd-fsck[177]: Performing changes.
Mar 14 23:56:24 hifiberry kernel: [    0.743333] hub 1-0:1.0: USB hub found
Mar 14 23:56:24 hifiberry kernel: [    0.744663] hub 1-0:1.0: 1 port detected
Mar 14 23:56:24 hifiberry kernel: [    0.746270] dwc_otg: FIQ enabled
Mar 14 23:56:24 hifiberry kernel: [    0.746280] dwc_otg: NAK holdoff enabled
Mar 14 23:56:24 hifiberry systemd-fsck[177]: /dev/mmcblk0p1: 87 files, 2552/7673 clusters
Mar 14 23:56:24 hifiberry kernel: [    0.746287] dwc_otg: FIQ split-transaction FSM enabled
Mar 14 23:56:24 hifiberry kernel: [    0.746319] Module dwc_common_port init
Mar 14 23:56:24 hifiberry kernel: [    0.746583] usbcore: registered new interface driver usb-storage
Mar 14 23:56:24 hifiberry kernel: [    0.747999] mousedev: PS/2 mouse device common for all mice
Mar 14 23:56:24 hifiberry kernel: [    0.749937] bcm2835-cpufreq: min=600000 max=1200000
Mar 14 23:56:24 hifiberry kernel: [    0.751470] sdhci: Secure Digital Host Controller Interface driver
Mar 14 23:56:24 hifiberry kernel: [    0.752772] sdhci: Copyright(c) Pierre Ossman
Mar 14 23:56:24 hifiberry kernel: [    0.754346] sdhost: log_buf @ ba813000 (fa813000)
Mar 14 23:56:24 hifiberry kernel: [    0.828825] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Mar 14 23:56:24 hifiberry kernel: [    0.852599] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
Mar 14 23:56:24 hifiberry kernel: [    0.853943] mmc-bcm2835 3f300000.mmc: DMA channel allocated
Mar 14 23:56:24 hifiberry kernel: [    0.888899] sdhci-pltfm: SDHCI platform and OF driver helper
Mar 14 23:56:24 hifiberry kernel: [    0.889708] mmc0: host does not support reading read-only switch, assuming write-enable
Mar 14 23:56:24 hifiberry kernel: [    0.892561] mmc0: new high speed SDHC card at address 59b4
Mar 14 23:56:24 hifiberry kernel: [    0.892960] mmcblk0: mmc0:59b4 USDU1 15.0 GiB
Mar 14 23:56:24 hifiberry kernel: [    0.894160]  mmcblk0: p1 p2
Mar 14 23:56:24 hifiberry kernel: [    0.897255] ledtrig-cpu: registered to indicate activity on CPUs
Mar 14 23:56:24 hifiberry kernel: [    0.898765] hidraw: raw HID events driver (C) Jiri Kosina
Mar 14 23:56:24 hifiberry kernel: [    0.900359] usbcore: registered new interface driver usbhid
Mar 14 23:56:24 hifiberry kernel: [    0.901742] usbhid: USB HID core driver
Mar 14 23:56:24 hifiberry kernel: [    0.903519] Initializing XFRM netlink socket
Mar 14 23:56:24 hifiberry kernel: [    0.904937] NET: Registered protocol family 17
Mar 14 23:56:24 hifiberry kernel: [    0.906417] Key type dns_resolver registered
Mar 14 23:56:24 hifiberry kernel: [    0.908192] Registering SWP/SWPB emulation handler
Mar 14 23:56:24 hifiberry kernel: [    0.910212] registered taskstats version 1
Mar 14 23:56:24 hifiberry kernel: [    0.911053] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.912616] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.914184] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.914310] vc-sm: Videocore shared memory driver
Mar 14 23:56:24 hifiberry kernel: [    0.914319] [vc_sm_connected_init]: start
Mar 14 23:56:24 hifiberry kernel: [    0.915736] [vc_sm_connected_init]: end - returning 0
Mar 14 23:56:24 hifiberry kernel: [    0.916725] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
Mar 14 23:56:24 hifiberry kernel: [    0.924289] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Mar 14 23:56:24 hifiberry kernel: [    0.960361] Indeed it is in host mode hprt0 = 00021501
Mar 14 23:56:24 hifiberry kernel: [    1.014859] mmc1: new high speed SDIO card at address 0001
Mar 14 23:56:24 hifiberry kernel: [    1.138826] usb 1-1: new high-speed USB device number 2 using dwc_otg
Mar 14 23:56:24 hifiberry kernel: [    1.138955] Indeed it is in host mode hprt0 = 00001101
Mar 14 23:56:24 hifiberry kernel: [    1.329082] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Mar 14 23:56:24 hifiberry kernel: [    1.329092] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 14 23:56:24 hifiberry kernel: [    1.329729] hub 1-1:1.0: USB hub found
Mar 14 23:56:24 hifiberry kernel: [    1.329828] hub 1-1:1.0: 5 ports detected
Mar 14 23:56:24 hifiberry kernel: [    1.608820] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Mar 14 23:56:24 hifiberry raspi-config[199]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Mar 14 23:56:24 hifiberry raspi-config[199]: No. Switching to ondemand scaling governor.
Mar 14 23:56:24 hifiberry kbd[201]: Setting console screen modes.
Mar 14 23:56:24 hifiberry kbd[201]: setterm: $TERM is not defined.
Mar 14 23:56:24 hifiberry wpa_supplicant[305]: Successfully initialized wpa_supplicant
Mar 14 23:56:24 hifiberry console-setup[273]: Setting up console font and keymap...done.
Mar 14 23:56:24 hifiberry networking[196]: Configuring network interfaces...Internet Systems Consortium DHCP Client 4.3.1
Mar 14 23:56:24 hifiberry networking[196]: Copyright 2004-2014 Internet Systems Consortium.
Mar 14 23:56:24 hifiberry networking[196]: All rights reserved.
Mar 14 23:56:24 hifiberry networking[196]: For info, please visit https://www.isc.org/software/dhcp/
Mar 14 23:56:24 hifiberry kernel: [    1.709059] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Mar 14 23:56:24 hifiberry kernel: [    1.709068] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 14 23:56:24 hifiberry kernel: [    1.711674] smsc95xx v1.0.4
Mar 14 23:56:24 hifiberry kernel: [    1.772016] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b7:48:5d
Mar 14 23:56:24 hifiberry kernel: [    2.092051] console [ttyAMA0] enabled
Mar 14 23:56:24 hifiberry kernel: [    2.100923] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Mar 14 23:56:24 hifiberry kernel: [    2.109530] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Mar 14 23:56:24 hifiberry kernel: [    2.511234] EXT4-fs (mmcblk0p2): recovery complete
Mar 14 23:56:24 hifiberry kernel: [    2.550973] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Mar 14 23:56:24 hifiberry networking[196]: Listening on LPF/wlan0/b8:27:eb:e2:1d:08
Mar 14 23:56:24 hifiberry kernel: [    2.561568] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Mar 14 23:56:24 hifiberry kernel: [    2.582598] devtmpfs: mounted
Mar 14 23:56:24 hifiberry kernel: [    2.587549] Freeing unused kernel memory: 444K (80795000 - 80804000)
Mar 14 23:56:24 hifiberry networking[196]: Sending on   LPF/wlan0/b8:27:eb:e2:1d:08
Mar 14 23:56:24 hifiberry kernel: [    3.105127] random: systemd urandom read with 72 bits of entropy available
Mar 14 23:56:24 hifiberry kernel: [    3.266168] NET: Registered protocol family 10
Mar 14 23:56:24 hifiberry kernel: [    3.390885] uart-pl011 3f201000.uart: no DMA platform data
Mar 14 23:56:24 hifiberry networking[196]: Sending on   Socket/fallback
Mar 14 23:56:24 hifiberry networking[196]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
Mar 14 23:56:24 hifiberry networking[196]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
Mar 14 23:56:24 hifiberry networking[196]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 21
Mar 14 23:56:24 hifiberry networking[196]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19
Mar 14 23:56:24 hifiberry networking[196]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
Mar 14 23:56:24 hifiberry networking[196]: No DHCPOFFERS received.
Mar 14 23:56:24 hifiberry kernel: [    5.077758] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Mar 14 23:56:24 hifiberry kernel: [    5.640431] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
Mar 14 23:56:24 hifiberry networking[196]: No working leases in persistent database - sleeping.
Mar 14 23:56:24 hifiberry kernel: [    5.640472] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry kernel: [    6.062885] bcm2835-rng 3f104000.rng: hwrng registered
Mar 14 23:56:24 hifiberry kernel: [    6.063212] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
Mar 14 23:56:24 hifiberry kernel: [    6.063228] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry networking[196]: done.
Mar 14 23:56:24 hifiberry kernel: [    6.063562] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
Mar 14 23:56:24 hifiberry kernel: [    6.063729] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
Mar 14 23:56:24 hifiberry kernel: [    6.063744] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry kernel: [    6.064509] snd-rpi-hifiberry-dacplus sound: ASoC: CODEC DAI pcm512x-hifi not registered
Mar 14 23:56:24 hifiberry kernel: [    6.064526] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Mar 14 23:56:24 hifiberry kernel: [    6.181480] cfg80211: Calling CRDA to update world regulatory domain
Mar 14 23:56:24 hifiberry kernel: [    6.202855] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Mar 14 23:56:24 hifiberry kernel: [    6.266059] snd-rpi-hifiberry-dacplus sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
Mar 14 23:56:24 hifiberry kernel: [    6.266361] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
Mar 14 23:56:24 hifiberry kernel: [    6.267047] usbcore: registered new interface driver brcmfmac
Mar 14 23:56:24 hifiberry kernel: [    6.479946] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
Mar 14 23:56:24 hifiberry kernel: [    6.544164] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
Mar 14 23:56:24 hifiberry kernel: [    6.654143] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
Mar 14 23:56:24 hifiberry kernel: [    6.654161] cfg80211: World regulatory domain updated:
Mar 14 23:56:24 hifiberry kernel: [    6.654166] cfg80211:  DFS Master region: unset
Mar 14 23:56:24 hifiberry kernel: [    6.654171] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Mar 14 23:56:24 hifiberry kernel: [    6.654178] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    6.654185] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    6.654191] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    6.654198] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    6.654206] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Mar 14 23:56:24 hifiberry kernel: [    6.654212] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Mar 14 23:56:24 hifiberry kernel: [    6.654218] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    6.654224] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Mar 14 23:56:24 hifiberry kernel: [    6.947332] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
Mar 14 23:56:24 hifiberry kernel: [    6.947347] brcmfmac: brcmf_add_if: ignore IF event
Mar 14 23:56:24 hifiberry kernel: [    6.951341] brcmfmac: power management disabled
Mar 14 23:56:24 hifiberry kernel: [   10.819498] random: nonblocking pool is initialized
Mar 14 23:56:24 hifiberry kernel: [   68.349784] Adding 102396k swap on /var/swap.  Priority:-1 extents:3 across:184320k SSFS
Mar 14 23:56:24 hifiberry alsactl[412]: No state is present for card sndrpihifiberry
Mar 14 23:56:24 hifiberry alsactl[412]: Found hardware: "snd_rpi_hifiber" "" "" "" ""
Mar 14 23:56:24 hifiberry alsactl[412]: Hardware is initialized using a generic method
Mar 14 23:56:24 hifiberry cron[414]: (CRON) INFO (pidfile fd = 3)
Mar 14 23:56:24 hifiberry dhcpcd[415]: version 6.7.1 starting
Mar 14 23:56:24 hifiberry cron[414]: (CRON) INFO (Running @reboot jobs)
Mar 14 23:56:24 hifiberry dphys-swapfile[418]: Starting dphys-swapfile swapfile setup ...
Mar 14 23:56:24 hifiberry triggerhappy[419]: Error opening '/dev/input/event*': No such file or directory
Mar 14 23:56:24 hifiberry dhcpcd[415]: dev: loaded udev
Mar 14 23:56:24 hifiberry dhcpcd[415]: eth0: adding address fe80::9a62:491f:6f70:d2fc
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Found user 'avahi' (UID 105) and group 'avahi' (GID 110).
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Successfully dropped root privileges.
Mar 14 23:56:24 hifiberry avahi-daemon[420]: avahi-daemon 0.6.31 starting up.
Mar 14 23:56:24 hifiberry dphys-swapfile[418]: want /var/swap=100MByte, checking existing: keeping it
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Successfully called chroot().
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Successfully dropped remaining capabilities.
Mar 14 23:56:24 hifiberry dphys-swapfile[418]: done.
Mar 14 23:56:24 hifiberry dbus[422]: [system] Successfully activated service 'org.freedesktop.systemd1'
Mar 14 23:56:24 hifiberry avahi-daemon[420]: No service file found in /etc/avahi/services.
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::ba27:ebff:fee2:1d08.
Mar 14 23:56:24 hifiberry avahi-daemon[420]: New relevant interface wlan0.IPv6 for mDNS.
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Network interface enumeration completed.
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Registering new address record for fe80::ba27:ebff:fee2:1d08 on wlan0.*.
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Registering HINFO record with values 'ARMV7L'/'LINUX'.
Mar 14 23:56:24 hifiberry dhcpcd[415]: eth0: waiting for carrier
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9a62:491f:6f70:d2fc.
Mar 14 23:56:24 hifiberry avahi-daemon[420]: New relevant interface eth0.IPv6 for mDNS.
Mar 14 23:56:24 hifiberry avahi-daemon[420]: Registering new address record for fe80::9a62:491f:6f70:d2fc on eth0.*.
Mar 14 23:56:24 hifiberry dhcpcd[415]: wlan0: waiting for carrier
Mar 14 23:56:24 hifiberry kernel: [   68.479948] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Mar 14 23:56:24 hifiberry kernel: [   68.480095] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Mar 14 23:56:25 hifiberry avahi-daemon[420]: Server startup complete. Host name is hifiberry.local. Local service cookie is 2080461289.
Mar 14 23:56:53 hifiberry hciattach[413]: Initialization timed out.
Mar 14 23:56:53 hifiberry hciattach[413]: bcm43xx_init
Mar 14 23:56:54 hifiberry dhcpcd[415]: timed out
Superkikim
Tue Mar 15, 2016 12:41 pm
SYSLOG PART 3
Mar 14 23:56:54 hifiberry dhcpcd[415]: forked to background, child pid 532
Mar 14 23:56:54 hifiberry ntpd[547]: ntpd [email protected] Mon Nov  2 04:29:47 UTC 2015 (1)
Mar 14 23:56:54 hifiberry ntpd[551]: proto: precision = 0.573 usec
Mar 14 23:56:54 hifiberry ntpd[551]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Mar 14 23:56:54 hifiberry ntpd[551]: Listen and drop on 1 v6wildcard :: UDP 123
Mar 14 23:56:54 hifiberry ntpd[551]: Listen normally on 2 lo 127.0.0.1 UDP 123
Mar 14 23:56:54 hifiberry ntpd[551]: Listen normally on 3 lo ::1 UDP 123
Mar 14 23:56:54 hifiberry ntpd[551]: Listen normally on 4 wlan0 fe80::ba27:ebff:fee2:1d08 UDP 123
Mar 14 23:56:54 hifiberry ntpd[551]: peers refreshed
Mar 14 23:56:54 hifiberry ntpd[551]: Listening on routing socket on fd #21 for interface updates
Mar 14 23:56:54 hifiberry ntp[535]: Starting NTP server: ntpd.
Mar 14 23:56:54 hifiberry systemd[1]: Startup finished in 3.045s (kernel) + 1min 35.554s (userspace) = 1min 38.599s.
Mar 14 23:56:54 hifiberry ntpd[551]: Deferring DNS for 0.debian.pool.ntp.org 1
Mar 14 23:56:54 hifiberry ntpd[551]: Deferring DNS for 1.debian.pool.ntp.org 1
Mar 14 23:56:54 hifiberry ntpd[551]: Deferring DNS for 2.debian.pool.ntp.org 1
Mar 14 23:56:54 hifiberry ntpd[551]: Deferring DNS for 3.debian.pool.ntp.org 1
Mar 14 23:56:54 hifiberry ntpd[558]: signal_no_reset: signal 17 had flags 4000000
Mar 14 23:56:56 hifiberry ntpd_intres[558]: host name not found: 0.debian.pool.ntp.org
Mar 14 23:56:56 hifiberry ntpd_intres[558]: host name not found: 1.debian.pool.ntp.org
Mar 14 23:56:56 hifiberry ntpd_intres[558]: host name not found: 2.debian.pool.ntp.org
Mar 14 23:56:56 hifiberry ntpd_intres[558]: host name not found: 3.debian.pool.ntp.org
Superkikim
Tue Mar 15, 2016 8:39 pm
Hey guys.
No one to look at the syslog and give me an idea ?
Hifiberry said it could be a driver bug. I'm no dev so hard fo me to debug that by myself....
Any help welcome
dchao99
Re: RPI3, internal wifi not associating with AP in specific
Wed Mar 16, 2016 5:59 pm
My case is not that dissimilar to yours. I am running RPi3 as a NAS server. As soon as I connect the USB Hard Drive to the USB port, the WiFI stops working. (My USB HD has it's own power supply). The WiFi is slightly more stable if I use the official RPi2 supply (still waiting for my RPi3 supply to arrive). As soon as I disconnect the External hard drive, I can see all the AP's.
I think there could be a local power issue on the brcm43438 chipset.
Superkikim
Wed Mar 16, 2016 6:06 pm
Yes I thought it might be a power issue. I have a 2.5V 5.1A power supply. According to all what I've read, it shouldn't be a problem. If it is, maybe there is a weakness in the design ? unless the HiFiBerry is draining too much.
Note that I've also deactivated BT, and it doesn't help.
In your case, it's even worse. I mean, I don't have a separate power supply for the DAC, but you have one for the drive... So if the RPI3 is not able to power the USB ports, there's definitely a problem somewhere.
Whould be great to have someone geeker then I am to help troubleshooting. I'm willing to make tests, debug dumps, anything that might help to find out where the problem is.
davidcoton
Wed Mar 16, 2016 8:03 pm
Superkikim wrote:Yes I thought it might be a power issue. I have a 2.5V 5.1A power supply.
That would be a problem, but I think you mean 5.1V 2.5A which should be OK -- if the PSU delivers what it says, and if the cable is thick enough to deliver the current without losing volts.
Signature retired
Superkikim
Wed Mar 16, 2016 8:22 pm
woops yes, obviously I mismatched V and A.
I'm still struggling with this. How can I debug this ? any idea ?
Superkikim
Wed Mar 16, 2016 9:39 pm
The issue has just been resolved !!!
Run rpi-update and get version 4.1.19-v7+
Now, my wifi works with the HiFiBerry. however, the wifi does not connect at boot time I need to troubleshoot that now.
dchao99
Wed Mar 16, 2016 10:49 pm
Superkikim wrote:The issue has just been resolved !!!
I am already running 4.1.19. It simply turns off WiFi power management permanently, without it, the WiFi won't work at all.
Superkikim
Wed Mar 16, 2016 10:59 pm
ok then. I think now I'm at the same stage you are. The wifi works only when I do ifdown wlan0;ifup wlan0... Wasn't working with power management on. However I still had to force power management off.
At boot, it doesn't hook to the AP.
Still even with ifdown/ifup, now it hook to the wifi, however sometimes the DHCP times out. I have to try to increase the delay.
Time to sleep. I'll continue at the end of the week. I'll keep you posted if I progress.
dchao99
Thu Mar 24, 2016 4:43 pm
WiFi still running slow, copying files between RPi3 and My Mac is extremely slow.
Using official Raspberry 12W PSU. No USB devices.
$ uname -a
Linux raspberryp3 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
I'm beginning to suspect it could be something else. What AP are you using? I am on Apple TimeCapsule.
I would also like to go back to my old Edimax dongle, but I couldn't find a way to disable the onboard WiFi.
Anyone knows how to disable the onboard WiFi module?
Superkikim
Thu Mar 24, 2016 10:37 pm
APs, I have tried with a SpeedTouch, an AirCard and my HTC M8.
Same problem on all. In my case, remember it works perfectly as long as the HiFiBerry is not powered. I wouldn't imagine an external problem.
Note that on the HifiBerry forum, a second user came with exactly the same behavior. Therefore the combination HifiBerry RPI3 is more and more suspect. On another hand, HifiBerry team says it work on their setup. I might send them my HifiBerry next time I'm home (in switzerland) for the weekend. Currently working in Belgium.
I've also ordered an IQaudIO DAC+ to test.
dchao99
Fri Mar 25, 2016 6:42 pm
I think I've cracked it.
It was tracked down to the country setting again.
I have my country set to US.
My dmsg reports:
[    7.111257] cfg80211: Calling CRDA for country: US
[    7.124548] cfg80211: Regulatory domain changed to country: US
[    7.124563] cfg80211:  DFS Master region: FCC
[    7.124568] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    7.124576] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[    7.124584] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[    7.124591] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[    7.124597] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[    7.124604] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
I checked my router, and my router was set to channel 11, so I changed it to channel 6, and bingo, my WiFi speed was back to RPi-2 speed.
It looks like the driver has problem with channel 11 for the US. I haven't tried channel 1 yet.
Superkikim
Fri Mar 25, 2016 10:25 pm
Good you found the problem on your side. Definitely not the same issue as I have then :)
dchao99
Sat Mar 26, 2016 12:43 am
Superkikim wrote:Good you found the problem on your side. Definitely not the same issue as I have then :)
Have you tried changing the channel. I was surprised that the driver is able to set channel to 11, but it was very unstable. The Edimax dongle and other computers around my house have no problem with channel 11.
Superkikim
Sat Mar 26, 2016 11:17 am
The router here uses channel 6. Therefore, no problem for any country.
I've been now trying with the full Raspbian. And problem is the same. This is definitly related to HiFiBerry DAC. I'll see with HifiBerry team how I can send them the device. Can't do it before quite some time thou.
dchao99
Sat Mar 26, 2016 5:38 pm
Updates:
Unforfunately, as soon as I added the USB SSD back to RPi3, WiFi connection failed again.
RPi2+Edimax channel 11+USB SSD: No problem (No problem with other PC's on the same 2.4GHz 802.11bgn network)
RPi3+WiFi channel 11: Marginal WiFi performance , sometimes lost connection
RPi3+WiFi channel 6: Good WiFi performance
RPi3+WiFi channel 6+USB SSD: Poor WiFi performance
Something very fishy about the SDIO interface or the Boardcom 43430 module power rails.
Firmware: 4.1.19-v7+, power management disabled
Official raspberry 12w PSU
Superkikim
Sat Mar 26, 2016 5:56 pm
Sounds like there might be something wrong with the RPI3 with HAT after all.
firstamistur
Sun Oct 02, 2016 7:53 am
I just got my Dac+ Pro with a Raspberry 3 and I have the same issue, as soon as I set dtoverlay=hifiberry-dacplus in the /boot/config.txt, wifi does not work anymore. the wlan0 stay with No-Carrier
any idea to fix this ?
thanks for your help
Best regards
Yoann
Superkikim
Sun Oct 02, 2016 1:00 pm
I ended up using Max2Play. Works like a charm.
Return to “Raspbian”
