greenhead01
update problem
Sat Mar 05, 2016 9:25 pm
So I haven't been using my pi for sometime. I wanted to do the usual update and upgrade and this happened:
Any suggestions on how to fix it.
sudo apt-get update
Err http://raspberrypi.collabora.com wheezy Release.gpg
  Temporary failure resolving 'raspberrypi.collabora.com'
Err http://archive.raspberrypi.org wheezy Release.gpg
  Temporary failure resolving 'archive.raspberrypi.org'
Err http://repository.wolfram.com stable Release.gpg
  Temporary failure resolving 'repository.wolfram.com'
Err http://mirrordirector.raspbian.org wheezy Release.gpg
  Temporary failure resolving 'mirrordirector.raspbian.org'
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/Release.gpg  Temporary failure resolving 'mirrordirector.raspbian.org'
W: Failed to fetch http://raspberrypi.collabora.com/dists/wheezy/Release.gpg  Temporary failure resolving 'raspberrypi.collabora.com'
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/wheezy/Release.gpg  Temporary failure resolving 'archive.raspberrypi.org'
W: Failed to fetch http://repository.wolfram.com/raspbian/dists/stable/Release.gpg  Temporary failure resolving 'repository.wolfram.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
gonsy
Re: update problem
Sat Mar 05, 2016 9:38 pm
My first guess is to double check your network connection. Try to ping the server/google
ShiftPlusOne
Re: update problem
Mon Mar 07, 2016 8:02 am
A number of problems here.
Yes, it looks like there's a network problem, if it couldn't resolve the raspbian.org repo. Collabora repo hasn't been included in the standard image for quite a long time. You can safely remove it.
Unrelated to your problem, but consider switching to jessie. Wheezy is no longer supported (by us).
aoakley
Re: update problem
Mon Mar 07, 2016 11:14 am
Long term solution is indeed to move to Jessie.
In the mean time, the terminal incantation:
sudo mv /etc/apt/sources.list.d/collabora.list /etc/apt/sources.list.d/collabora.list.disabled
...will allow Wheezy updates to continue. For example, python-imaging recently received an update on Wheezy.
The Collabora repo was for LibreOffice, I believe. I think this is now in the mainstream repo anyway, even on Wheezy, so disabling the Collabora repo on Wheezy should make no difference. However if someone with more time than me could check, that would be much appreciated.
Andrew Oakley - Cotswold Raspberry Jam, Gloucestershire - http://www.cotswoldjam.org
DavidMS
Re: update problem
Mon Mar 07, 2016 12:25 pm
I had the same problem on Saturday, ignored it ran upgrade and ended up with a dead system - just the green led flashing a few times in sequence. I did not spend time investigating just reformatted and installed the lasted Jessie. Probably also had it on another Pi a couple of weeks ago but there were some other problems so did not recognize the significance.
I would suggest the strong advice here is that if you have a working Wheezy leave alone don't try to update unless you have everything backed up
http://meanderingpi.wordpress.com/
11 Raspberry Pi's and counting....
Return to “Raspbian”
