gulliverrr
Run script on first boot only
Sat Mar 05, 2016 1:02 am
Hello and congrats on the 4th year of this great toy!
I need to be running a shell script as root on the first boot only automatically without having to logo on to RasPi to run it manually. It is a script that expands the partitions of my SD card to cover the whole area.
What is the best method to do that? It needs to remove itself once its completed to avoid running again on a reboot.
Thanks!
r3d4
Re: Run script on first boot only
Sat Mar 05, 2016 7:00 pm
Apparently raspi-config.sh uses ( this : http://elinux.org/RPi_raspi-config#First-boot_activity ) method .
Another method to auto run a program after boot ...
nmcclain
Tue Aug 27, 2019 1:43 am
I ran into a similar requirement and created this lightly-modified version of Raspberian-light: https://github.com/nmcclain/raspberian-firstboot
If you create a /boot/firstboot.sh script on the image before flashing to an SD card, it will be executed when it's first booted on a Pi.
iandk
Mon Sep 23, 2019 10:52 pm
Would be awesome if this could be officially integrated.
Return to “Raspbian”
