Trouble with sharing my wireless internet connection.
Posted: Tue Aug 07, 2012 7:00 am
by OMightyBuggy
I am using a laptop with Windows 7 to share my internet connection with my Raspberry Pi. It was working with the old wheezy image plug and play and no config. Now with Raspbian R1 and R3 I can't seem to get it working again.
My setup is wireless set to shared via lan on my Windows laptop. I am using a crossover cable to my Raspberry Pi. I have messed with every network thing I can think of..., because I am still learning Debian (I am used to CentOS, dang school...) I am unsure of what to do.
I have tried the things on this site http://wiki.debian.org/NetworkConfiguration and not much help. I try apt-get update && dist-upgrade and all I get is errors all the way down.
I have tried deleting all the lines from 70-persistent-net.rules and I tried deleting the file. I also tried sudo vi etc/network/interfaces and added auto eth0 blah blah blah.
Soooooooo ya I need some help with either the Windows side or Raspbian anybody that can help would be awesome. :)
Edit: Also tried the change eth0 to eth1 and still the same problem...
Re: Trouble with sharing my wireless internet connection.
Posted: Tue Aug 07, 2012 8:35 am
by Gwyn400
Have you tried a different cable? I had a similar problem and it turned out the cable just wasnt working even though it worked fine with everything else before I tried it in my Pi.
Posted: Tue Aug 07, 2012 12:23 pm
by OMightyBuggy
No I haven't tried that yet as I don't have another crossover cable. I don't really think I could of ruined it but their is always that possibility. I am just trying to narrow down what it could be. I see all the leds blink on my PC's lan and Raspberry Pi so I am just gonna assume it has a connection, but either my PC or the Pi is messing it up.
I just know it worked on the older image and not on this one.
I am gonna try your idea though just need to buy another cord.
Posted: Tue Aug 07, 2012 12:51 pm
by bredman
You don't need a crossover cable. The NIC on the RPi (and most modern computers) is auto-sensing, therefore you can use straight or crossover cables.
Posted: Tue Aug 07, 2012 12:57 pm
by OMightyBuggy
Never heard of that before, but you learn something new everyday. :) Well I can try it, I have other normal lan cables. I will post here if it works or doesn't.
Posted: Tue Aug 07, 2012 1:08 pm
by OMightyBuggy
Nope nothing, just a long wait then errors when I try apt-get anything...
Posted: Tue Aug 07, 2012 1:21 pm
by bredman
Try the following commands and post the result
hostname -I
ifconfig
route
ping 8.8.8.8
Posted: Tue Aug 07, 2012 1:39 pm
by OMightyBuggy
hostname -I
192.168.xxx.xxx
ifconfig
Not sure what you want me to post but it shows the address, bcast, and mask. RX packets 68 TX packets 64 everything else is 0.
route
Shows default and my ip address nothing else.
ping 8.8.8.8
64 bytes from 8.8.8.8 thats all.
Posted: Tue Aug 07, 2012 1:53 pm
by bredman
You seem to be getting a valid IP address from somewhere.
It is not clear which gateway you are using. Are you sure that ifconfig does not show a gateway address?
Apologies for the questions, but it is very difficult working blind.
Posted: Tue Aug 07, 2012 1:55 pm
by bredman
Try the commands
sudo ifdown eth0
sudo ifup eth0
After the ifup command, you should see DHCPDISCOVER and DHCPOFFER messages. Post the contents of the DHCPOFFER messages.
Posted: Tue Aug 07, 2012 2:01 pm
by OMightyBuggy
The gateway shows up as my ip address of the laptop.
Contents of the DHCPOFFER messages is my laptops ip address.
It acts as if its connected but I fail to get anything from the internet...
Posted: Tue Aug 07, 2012 2:14 pm
by bredman
Try the command
ping 8.8.8.8
It was very unclear from your answer above if this succeeded or failed.
Try pinging your laptop, let us know if this succeeds or fails.
Please post exactly the response to the route command.
Posted: Tue Aug 07, 2012 2:15 pm
by OMightyBuggy
Well I feel like an idiot/noob now... WINDOWS TURNED THE FIREWALL BACK ON!!!
I didn't even think to check that...
Thank you everybody who tried to help me.
