sander2
FYI: Docker 1.10 on Raspbian on Raspi 2
Fri Feb 26, 2016 7:45 pm
FYI & FWIW:
This is how I installed Docker 1.10 on Raspbian on Raspi 2, which I got working thanks to:
http://blog.hypriot.com/downloads/ (for the docker deb)
http://bridge360blog.com/2016/02/12/a-f ... nd-docker/ (to solve the "Failed to restart docker.service: Unit docker.service is masked.")
[email protected]:~ $ wget https://downloads.hypriot.com/docker-hypriot_1.10.2-1_armhf.deb
[email protected]:~ $ sudo dpkg -i docker-hypriot_1.10.2-1_armhf.deb
[email protected]:~ $ sudo service docker restart
[email protected]:~ $ sudo systemctl unmask docker.service
Removed symlink /etc/systemd/system/docker.service.
[email protected]:~ $ sudo systemctl unmask docker.socket
Removed symlink /etc/systemd/system/docker.socket.
[email protected]:~ $ ps -ef | grep -i docker
root      3132     1  9 20:12 ?        00:00:00 /usr/bin/docker daemon -H fd:// --storage-driver=overlay -D
sander    3191  1010  0 20:12 pts/0    00:00:00 grep --color=auto -i docker
[email protected]:~ $ sudo docker version
Client:
 Version:      1.10.2
 API version:  1.22
 Go version:   go1.4.3
 Git commit:   c3959b1
 Built:        Wed Feb 24 09:51:38 2016
 OS/Arch:      linux/arm
Server:
 Version:      1.10.2
 API version:  1.22
 Go version:   go1.4.3
 Git commit:   c3959b1
 OS/Arch:      linux/arm
OK, done. Let's run Ubuntu:
[email protected]:~ $ sudo docker run -it armv7/armhf-ubuntu /bin/bash
[email protected]:/# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=15.10
DISTRIB_CODENAME=wily
DISTRIB_DESCRIPTION="Ubuntu 15.10"
[email protected]:/# exit
exit
Search containter images:
[email protected]:~ $ sudo docker search armhf-
NAME                                  DESCRIPTION                                     STARS     OFFICIAL   AUTOMATED
armv7/armhf-ubuntu                    'official' Ubuntu Docker images for the AR...   20
armv7/armhf-archlinux                 archlinux arm Docker image for the ARMv7(a...   10
ioft/armhf-ubuntu                     [ABR] Ubuntu Docker images for the ARMv7(a...   9                    [OK]
container4armhf/armhf-alpine          Automatically built base images of Alpine ...   7                    [OK]
mazzolino/armhf-debian                Debian Wheezy base image for armhf devices      6
mazzolino/armhf-ubuntu                Ubuntu-Core images for armhf (ARMv7) devices    6
armv7/armhf-ubuntu_core               Ubuntu Core Docker images for the ARMv7(ar...   4
moul/armhf-busybox        2                    [OK]
armhf/python                          Python is an interpreted, interactive, obj...   1
cburki/armhf-dev                      Armhf (Raspberry Pi) cross development wit...   1                    [OK]
ioft/armhf-debian                     Debian Docker images for the ARMv7(armhf) ...   1                    [OK]
werwolfby/armhf-alpine-transmission   Minimal alpine docker image for transmissi...   1                    [OK]
werwolfby/armhf-alpine-nginx          ARM hf compatible Docker Image with a mini...   1                    [OK]
werwolfby/armhf-alpine-gogs           ARM hf compatible Docker Image with a mini...   1                    [OK]
mjschultz/ubuntu-armhf        0                    [OK]
msvb/armhf-iotempire                  Collection of software packages to accompa...   0                    [OK]
flisboac/docker-armhf-phabricator                                                     0                    [OK]
wontfix/gecko-armhf-dev               Linux/armhf cross build environment for Gecko   0                    [OK]
fish/alpine-armhf-dumb-init           alpine-armhf-docker image with "dumb-init"...   0                    [OK]
mathewpeterson/armhf-php7             This image extends the official armhf php ...   0                    [OK]
armhf/ubuntu                          Ubuntu is a Debian-based Linux operating s...   0
armv7/armhf-ubuntu_automated-build    This repo has moved to https://registry.hu...   0                    [OK]
container4armhf/armhf-busybox         Automated build of Busybox for armhf devic...   0                    [OK]
lalyos/armhf-syncthing                http://docs.syncthing.net in a container f...   0                    [OK]
armhf/debian                          Debian is a Linux distribution that's comp...   0
[email protected]:~ $ sudo docker search armv7
armv7/armhf-debian                   Debian Docker images for the ARMv7(armhf) ...   5
armv7/armhf-fedora                   fedora 22, 21, 20 Docker images for the AR...   5
thewtex/cross-compiler-linux-armv7   Linux ARMv7 cross compiler toolchain            3                    [OK]
armv7/armhf-openhab                  openHAB ARMv7 port of tdeckers/openhab          2
daozhao/armv7-toolchain              ARMv7 develper environment image                1                    [OK]
armv7/armhf-baseimage                Ubuntu Docker images for the ARMv7(armhf) ...   1
oysteinjakobsen/armv7-oracle-java8   Debian Wheezy ARMv7hf image with Oracle Ja...   1
jpizarrom/armv7hf-java-dockerhub     armv7hf-java-dockerhub                          0                    [OK]
mscook/rethinkdb-armv7               RethinkDB 2.1.0 build on armv7 (Raspberry ...   0
oysteinjakobsen/armv7-neo4j          ARMv7hf image with Neo4j, meant for use on...   0
shyiko/armv7-archlinux               Arch Linux ARMv7 (built on Raspberry Pi 2)      0
andrewpsuedonym/armv7-hadoop         Hadoop for armv7/armhf architecture             0
shyiko/armv7-redis                   Redis running on Arch Linux ARMv7 (built o...   0
romlinch/btsync-armv7        0
nghiant2710/armv7-bbb        0
janeczku/docker-proxy-armv7          Docker proxy (TCP => Linux socket) for arm...   0
nghiant2710/armv7-rpi        0
janeczku/etcd-armv7                  etcd for armhf/ARMv7 (RPi / Scaleway C1)        0
kaffepanna/alpine-armv7-qemu         Docker image based on armbuild/alpine incl...   0                    [OK]
knjcode/rpi-node-armv7               RPi-compatible Docker base image with Node...   0
jonatanschlag/debian-jessie-armv7    Debian Jessie images, build on my Odroid-X...   0
asandford
Re: FYI: Docker 1.10 on Raspbian on Raspi 2
Fri Feb 26, 2016 8:44 pm
Thanks for the info, been meaning to have a play with Docker for a while.
Return to “Raspbian”
