I am trying to use Mbrola, a TTS software and I have a surprising behavior :
I can see help files with '-h' argument, the software complains well if arguments are not corrects, but crashes with a 'segmentation fault' when I try to use it.
The most surprising is that it works well with the Debian image from 17/02/2012.
Does anybody have an idea ? Thanks
If the strace could help:
execve("/usr/bin/mbrola", ["mbrola", "/usr/share/mbrola/voices/fr1", "bonjour.ph
o", "test.wav"], [/* 17 vars */]) = 0
brk(0) = 0x3ff000
uname({sys="Linux", node="raspberrypi", ...}) = 0
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40
008000
access("/etc/ld.so.preload", R_OK) = 0
open("/etc/ld.so.preload", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=44, ...}) = 0
mmap2(NULL, 44, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0x400ff000
close(3) = 0
open("/usr/lib/arm-linux-gnueabihf/libcofi_rpi.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\10\4\0\0004\0\0\0"..., 5
12) = 512
lseek(3, 3456, SEEK_SET) = 3456
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1
240) = 1240
lseek(3, 2537, SEEK_SET) = 2537
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\24\1\25"..., 47)
= 47
fstat64(3, {st_mode=S_IFREG|0755, st_size=7332, ...}) = 0
mmap2(NULL, 35276, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x401
3b000
mprotect(0x4013c000, 28672, PROT_NONE) = 0
mmap2(0x40143000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRIT
E, 3, 0) = 0x40143000
close(3) = 0
munmap(0x400ff000, 44) = 0
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=39707, ...}) = 0
mmap2(NULL, 39707, PROT_READ, MAP_PRIVATE, 3, 0) = 0x4009c000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\3201\0\0004\0\0\0"..., 5
12) = 512
lseek(3, 426468, SEEK_SET) = 426468
160) = 1160
lseek(3, 426136, SEEK_SET) = 426136
read(3, "A0\0\0\0aeabi\0\1&\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\24\1\25"..., 49)
= 49
fstat64(3, {st_mode=S_IFREG|0644, st_size=427628, ...}) = 0
mmap2(NULL, 458912, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x40
144000
mprotect(0x401ac000, 28672, PROT_NONE) = 0
mmap2(0x401b3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRIT
E, 3, 0x67) = 0x401b3000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\230y\1\0004\0\0\0"..., 5
12) = 512
lseek(3, 1190688, SEEK_SET) = 1190688
360) = 1360
lseek(3, 1190252, SEEK_SET) = 1190252
= 47
fstat64(3, {st_mode=S_IFREG|0755, st_size=1192048, ...}) = 0
mmap2(NULL, 1201448, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x4
01b5000
mmap2(0x402d5000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRI
TE, 3, 0x120) = 0x402d5000
mmap2(0x402d8000, 9512, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOU
S, -1, 0) = 0x402d8000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40
0b8000
set_tls(0x400b84c0, 0x400b8b98, 0x400fb048, 0x400b84c0, 0x400fb048) = 0
mprotect(0x402d5000, 8192, PROT_READ) = 0
mprotect(0x401b3000, 4096, PROT_READ) = 0
mprotect(0x400fa000, 4096, PROT_READ) = 0
munmap(0x4009c000, 39707) = 0
brk(0) = 0x3ff000
brk(0x420000) = 0x420000
open("/usr/share/mbrola/voices/fr1", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=5080000, ...}) = 0
049000
read(3, "MBROLA2.060\20\5\0\0\361O\0\0\200AM\0\200>x\1a\0a\0d"..., 4096) = 4096
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
