reltek
How to autostart a program on Raspbian?
Thu Jan 14, 2016 5:28 pm
I want to autostart a program on Raspbian and having difficulty accomplishing that. How does one go about doing that.
TheRadziu
Re: How to autostart a program on Raspbian?
Thu Jan 14, 2016 5:46 pm
there are at least 3 ways to do so:
- by editing /etc/rc.local in my case the line I added looks like this:
su - pi -c kodi
for autostarting kodi
- by creating new init.d file, here is some info about it http://unix.stackexchange.com/questions ... rt-at-boot
- by creating .desktop file somewhere but honestly I do not remember how to do it, try searching .desktop file autostart
I am using all the listed ways for different programs.
gordon77
Thu Jan 14, 2016 6:36 pm
Try putting the relevant command in ~/.config/lxsession/LXDE-pi/autostart
Eg. To run a python script use...
@sudo /usr/bin/python /home/pi/filename.py
To Make the file executable with sudo chmod +x filename.py
It will run after the gui starts.
reltek
Thu Jan 14, 2016 7:44 pm
I was able to edit rc.local for autostarting my program as follows by simply adding a line.
./home/pi/myprogram/viewdata
That worked. Viewdata started up at boot, but Viewdata doesn't know it's working folder. ViewData complains that it can't access it properties or setting, because working folder is where they are located and Viewdata program also in the same folder. So, how do you let my program viewdata know what is its working folder?
TrianP
Wed Feb 17, 2016 3:02 am
Adding the entry to the autostart file worked for me -- except I run into a problem with the sudo password. If I've executed a command with sudo rights before I start the desktop, my application starts up just fine. However, if I start the desktop after bootup without running a sudo command, the system hangs with a blank screen. I'm sure it's because the system is looking for the user password.
Can you insert the password into the autostart file? Is there another way to avoid this problem?
Thanks!
brekee12
Wed Feb 17, 2016 7:57 am
For these problems:
- make sure user rigths is set correctly. Are you sure your program needs root privileges? Could not you run with another user?
- your python program should contain the full path for files or the PATH with your needs should be set before your program runs
Brekee12
on a Raspberry B+ with whezzy, two Zero with Jessie Light
rurwin
Wed Feb 17, 2016 9:01 am
There are ways around the program not starting with the correct directory current. For example you could write a new program that sets the working directory and then starts the program you want.
But the correct way to do it is for the program to have a confguration file with the directory specified in it.
RaTTuS
Contact: Twitter YouTube
Wed Feb 17, 2016 9:15 am
Covfefe
TrianP
Wed Feb 17, 2016 1:48 pm
I think the program is starting in the right directory - I've specified it completely, and if I've run a command using sudo rights that stay in effect, startx loads correctly and the application starts. Therefore, I think the problem is with the need for a password.
I think Brekee12 is on the right track with sudo rights. My program accesses the GPIO ports, and as far as I can tell, it only runs with sudo rights. I always get permission errors if I try to run it without sudo rights.
It might be as simple as giving the account permanent sudo rights. I'm very much a Linux newbie, so I'm a bit in the dark. Is there an easy way to do this? Is the default pi account a sudo account? I could try the program there if that's the case.
Thanks for the replies.
brekee12
Wed Feb 17, 2016 2:39 pm
I can't remember what topic I have read that GPIOs needs sudo rigths. I use PIGPIO library programming the ios and only the pigpiod needs sudo right to start. To be honest I have put it into init.d and any time anyway I can use the GPIOs. Maybe, it makes sense to see joan's PIGPIO library which is much more than just io subrutins and does not requires sudorigth for the user.
Brekee12
TrianP
Fri Feb 19, 2016 5:17 pm
Thanks for the reply - I'll try that library this weekend.
However, the problem will likely remain. I'm using some one-wire sensors and a magnetometer. It's likely that at least one of the libraries for those devices will need sudo rights. Hopefully not!
But it's still an interesting question: is there a way to insert a python script that needs sudo rights into the autostart file? I'd like to know for future projects even if not for this one.
Thanks!
JimmyN
Fri Feb 19, 2016 6:14 pm
TrianP wrote: But it's still an interesting question: is there a way to insert a python script that needs sudo rights into the autostart file? I'd like to know for future projects even if not for this one.
Thanks!
Just precede it with sudo
@sudo python /path/to/script/something.py
That shouldn't ask for a password unless you've changed the sudoers file to require a password when sudo is used.
EDIT: added last line
TrianP
Fri Feb 19, 2016 10:36 pm
Success! The reply about the sudoers file led me to look at that file. I saw that the pi account was set to not ask for a password (pi ALL=(ALL) NOPASSWD:ALL). However, I've been working in a different account. I added a matching line to the file for my account using the visudo command, and the system no longer asks for a password. Consequently, the application starts up when the desktop starts.
Thanks very much JimmyN and everyone else for your help!
reltek
Tue May 10, 2016 7:27 pm
Sadly none of the suggested answers helped. The only way I was able to get my program to run at boot with correct work path folder is writing a mini program, which runs at boot, started myprogram.
RaTTuS
Wed May 11, 2016 8:51 am
reltek wrote:Sadly none of the suggested answers helped. The only way I was able to get my program to run at boot with correct work path folder is writing a mini program, which runs at boot, started myprogram.
probably because you have done it worng
Covfefe
aporeg
Fri Jun 16, 2017 2:18 pm
First of all Hello to all
Thanks @TheRadziu
This worked for me
su - pi -c kodi
This is how is should look like after edit
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
su - pi -c kodi
exit 0
pvklink
Wed Dec 20, 2017 7:25 pm
Hi my autostart (raspbian stretch + pico menu) still does executing the menu instead of my webbrowser
i tried sudo nano /etc/xdg/lxsession/LXDE/autostart
and i tried sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
I commented out all the old existing lines with #
my file is:
# start boot default
#@lxpanel --profile LXDE-pi
#@pcmanfm --desktop --profile LXDE-pi
#@xscreensaver -no-splash
#@point-rpi
# end boot default
# Auto run the browser
@xset s off
@xset -dpms
@xset s noblank
@apropos chromium
@chromium-browser --start-fullscreen http://www.nu.nl
#end pvk
Trash_Can_Man
Sat Dec 23, 2017 5:42 pm
There are several lxde autostart files on different places, the one that works for me on the "oficial" raspbian with pixel is:
/home/pi/.config/lxsession/LXDE-pi/autostart
edit it with:
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
this totally works for me, i used it for a while starting kodi on desktop start...
raspisnagger
Wed Jan 24, 2018 2:52 pm
I wrote "@sudo /usr/bin/python /home/pi/Desktop/Filename.py" but on startup nothing happens. Where did I go wrong? We know the path works when executed through the console.
klricks
Wed Jan 24, 2018 6:11 pm
Try:
@lxterminal -e python /home/pi/Desktop/Filename.py
also since autostart is in home/pi you should not use sudo to edit the file.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
viktor6
Sun Feb 11, 2018 9:44 pm
Thanks @TheRadziu
This worked for me
su - pi -c kodi
if [ "$_IP" ]; then
fi
su - pi -c kodi
exit 0
There is no restart in the menu, and the rest
Zakhar
Sat Oct 19, 2019 12:46 pm
So here is how it works!
First, in the Linux spirit, your question is incomplete. Bear in mind Linux has always been made for servers and is multi-users by default, unlike another more widespread proprietary O.S.
So the question is, do you want to "autostart" something for:
  • the whole machine (commonly called "a service")
  • only for the current user in session
For the former, ie starting a service, you would add a service to systemd or something in rc.local.
Your service will be started as root, because you are in a phase where there is not yet any user logged in, and the service would be accessible to whatever user logs in the machine later.
Also, remember that at this point you might NOT have a graphical environment, so no graphical program should be put here.
A typical use case would be starting a web proxy (like Squid) that all users would use for their browsing sessions.
For the later, you want the session to be started, and you want the program to be launched with the user account, and not with root, otherwise there is a misunderstanding of basic security!
So here, you use the LXDE autostart described above.
Programs here are launched with the account on the user, and within the desktop environment that is started. So a graphical program is suitable here.
But there is a nasty trick!
If you read carefully the documentation, it says that if there is a user's local autostart, this one is executed instead of the "global" one.
This means that you cannot just create an autostart and put your command in it, because then only your command would run and not what was in the "global" autostart that is responsible for showing your desktop.
As a result you would end up with a black screen with a mouse pointer and you program running.
So the correct way to do things is:
First, copy the "global" autostart to your config directory
cp /etc/xdg/lxsession/LXDE-pi/autostart ~/.config/lxsession/LXDE-pi
Then add your command after the standard ones, which in my example reads like that:
cat ~/.config/lxsession/LXDE-pi/autostart
my_program
That way, you still have your desktop showing, plus "my_program" will run once.
Note on Kodi
If the program you want to run is kodi, know that kodi has 2 modes.
The standard mode of Kodi (aka "standalone") is that it does NOT need a DE (Desktop Environment), but only a basic graphic stack (I don't know exactly but things like Mesa/X11).
The other mode is known as "full screen" and is made to run on top of a graphical environement, like Openbox/LXDE in the case of classic Raspbian.
So if you intended to run Kodi "standalone" you are very mistaken using Raspbian, because the DE in this case is useless and a nuisance to Kodi. If this is your intention, you'd better use something like LibreElec which is exactly that: minimal stuff to run Kodi.
So if you intend to run Kodi on Raspbian, and want it autostart, the right command is
kodi -fs
That will run Kodi "full-screen" on top of LXDE. Should you decide that you want to exit Kodi and do usual desktop stuff, you just need to click on "exit" and you are back to LXDE... which does not work on "standalone" mode!
Return to “Raspbian”
