Page 2 of 5
Re: SD card backup / copy: how to ?
Posted: Sun Dec 27, 2015 6:30 pm
by davenull
is that true that for the RPi there is no single backup-program or script or what ever which works out of the box?
e.g., choose target backup drive by commandline parameter or by menu (listing all available drives / just all USB drives)?
like e.g., most simple:
sudo ./backup /media/pi/usb120drv # usb120drv == drive name
In case something like that doesn't exist yet, then that would be really rediculous...
Posted: Sun Dec 27, 2015 11:20 pm
by SonOfAMotherlessGoat
davenull wrote:is that true that for the RPi there is no single backup-program or script or what ever which works out of the box?
Not one that fits the extremely narrow range of constraints that has been put on the problem...
Posted: Sat Jan 02, 2016 8:57 pm
by davenull
that cannot - that MUST not be true!
How long does Linux and Unix already exist?
And NO BACKUP PROGRAM to a plugged-in USB drive available ?!?
Posted: Sat Jan 02, 2016 10:12 pm
by asandford
davenull wrote:that cannot - that MUST not be true!
Of course there are, from free to $$$$. rsync has already been mentioned as has dd'ing the partions.
If you really want a one liner:
sudo tar --exclude=/media/* --exclude=/proc --exclude=/dev --exclude=/tmp --exclude=/run cvzf /media/pi/usb120drv/pibackup.tar.gz /
The position of the excludes depends on the version of tar. I've not tested the above as I use rsync...
Posted: Sat Jan 02, 2016 10:17 pm
by davenull
thank you!
neverless there is this error:
pi@raspberrypi:~ $ sudo tar --exclude=/media/* --exclude=/proc --exclude=/dev --exclude=/tmp --exclude=/run cvzf /media/pi/usb120drv/pibackup.tar.gz /
tar: Eine der Optionen „-Acdtrux“, „--delete“ oder „--test-label“ ist notwendig.
„tar --help“ oder „tar --usage“ gibt weitere Informationen.
ps,
I'm a complete beginner and my English is very poor, especially I don't understand sort of slang like dd'ing :-/
rsync appears extremely complicated, except there is 1 single install programm for the whole installation (like setup.exe for windows programs)
and just 1 command to start (like double-click on sort of "rsync.exe"
and adjust the settings (like target drive) interactively.
Posted: Sat Jan 02, 2016 10:26 pm
by davenull
ps,
all directories of /pi/ also should be backup-ed
and why exclude proc and dev?
Posted: Sat Jan 02, 2016 10:27 pm
by asandford
davenull wrote:thank you!
ps,
Well, I did say that may have the alter the position of the excludes, try:
tar cvzf /media/pi/usb120drv/pibackup.tar.gz / --exclude=/media/* --exclude=/proc --exclude=/dev --exclude=/tmp --exclude=/run
Seems to do something...I'll let you know when it finishes
Posted: Sat Jan 02, 2016 10:30 pm
by davenull
pi@raspberrypi:~ $ tar cvzf /media/pi/usb120drv/pibackup.tar.gz / --exclude=/media/* --exclude=/proc --exclude=/dev --exclude=/tmp --exclude=/run
tar: Entferne führende „/“ von Elementnamen
tar (child): /media/pi/usb120drv/pibackup.tar.gz: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
tar (child): Error is not recoverable: exiting now
/srv/
/etc/
/etc/gai.conf
/etc/polkit-1/
/etc/polkit-1/nullbackend.conf.d/
/etc/polkit-1/nullbackend.conf.d/50-nullbackend.conf
tar: /etc/polkit-1/localauthority: Funktion open fehlgeschlagen: Keine Berechtigung
/etc/polkit-1/localauthority.conf.d/
/etc/polkit-1/localauthority.conf.d/50-localauthority.conf
/etc/polkit-1/localauthority.conf.d/60-desktop-policy.conf
/etc/dhcpcd.duid
that looks better...
ps,
Posted: Sat Jan 02, 2016 10:32 pm
by davenull
no,...
did not find the USB target drive
nevertheless, the USB drive is plugged in and can be accessed via the file explorer
Posted: Sat Jan 02, 2016 10:50 pm
by asandford
They are psuedo-filesystems populated by the OS at runtime, they probably are empty on the SDcard (if they exist at all).
You exclude /media as you don't want it archiving the archive file...
davenull wrote:no,...
Try putting sudo in front of the tar command (as in my first example), or:
cd /media/pi/usb120drv/
sudo tar cvzf ./pibackup.tar.gz / --exclude=/media/* --exclude=/proc --exclude=/dev --exclude=/tmp --exclude=/run
Posted: Sat Jan 02, 2016 10:52 pm
by davenull
pi@raspberrypi:~ $ sudo tar cvzf /media/pi/usb120drv/pibackup.tar.gz / --exclude=/media/* --exclude=/proc --exclude=/dev --exclude=/tmp --exclude=/run
/srv/
/etc/
/etc/gai.conf
/etc/polkit-1/
/etc/polkit-1/localauthority/
/etc/polkit-1/localauthority/10-vendor.d/
/etc/polkit-1/localauthority/20-org.d/
/etc/polkit-1/localauthority/30-site.d/
/etc/polkit-1/localauthority/90-mandatory.d/
/etc/polkit-1/localauthority/50-local.d/
/etc/polkit-1/localauthority/50-local.d/55-storage.pkla
tar (child): /media/pi/usb120drv/pibackup.tar.gz: Funktion open fehlgeschlagen/etc/dhcpcd.duid
/etc/rpi-issue
/etc/protocols
/etc/udev/
/etc/udev/rules.d/
Posted: Sat Jan 02, 2016 10:53 pm
by davenull
but I don't find a tar file on my usb drv after that...
Google translate of error msgs:
tar (child): /media/pi/usb120drv/pibackup.tar.gz: fuction open failed
/etc/dhcpcd.duid/etc/rpi-issue no such file or directory
Posted: Sat Jan 02, 2016 11:13 pm
by asandford
davenull wrote:but I don't find a tar file on my usb drv after that...
Mine's just failed with
tar: Exiting with failure status due to previous errors
But there are no errors...
However, it did create a file:
-rw-r--r-- 1 root root 1473845343 Jan 2 22:52 pibackup.tar.gz
I'm running wheezy from a hdd with 135GB free, so it's not a space issue.
Best try rsync
sudo apt-get install rsync -y
mkdir -p /media/pi/usb120drv/pibackup
cd /media/pi/usb120drv/pibackup/
sudo rsync -avz --delete --exclude /sys --exclude /tmp --exclude /proc --exclude /run --exclude /media/* / .
The excludes can be written to a file if required.
Posted: Sat Jan 02, 2016 11:18 pm
by davenull
it does not find the target USB drv
pi@raspberrypi: $ cd /media
pi@raspberrypi:/media $ cd usb120drv
bash: cd: usb120drv: no such file or directory
Posted: Sat Jan 02, 2016 11:26 pm
by asandford
davenull wrote:it does not find the target USB drv
I was using you previous example:
If your drive is mounted to somewhere else, then use that (use df -h to find the mountpoint).
by davenull
pi@raspberrypi:~ $ sudo apt-get install rsync -y
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
rsync ist schon die neueste Version.
rsync wurde als manuell installiert festgelegt.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
pi@raspberrypi:~ $ mkdir -p /media/pi/usb120drv/pibackup
mkdir: das Verzeichnis „/media/pi/usb120drv“ kann nicht angelegt werden: Keine Berechtigung
pi@raspberrypi:~ $ cd /media/pi/usb120drv/pibackup/
bash: cd: /media/pi/usb120drv/pibackup/: Datei oder Verzeichnis nicht gefunden
pi@raspberrypi:~ $ sudo rsync -avz --delete --exclude /sys --exclude /tmp --exclude /proc --exclude /run --exclude /media/* / .
(hangs up)
Posted: Sat Jan 02, 2016 11:28 pm
by davenull
pi@raspberrypi:/media $ cd pi
pi@raspberrypi:/media/pi $ cd usb120drv
bash: cd: usb120drv: Datei oder Verzeichnis nicht gefunden
Posted: Sat Jan 02, 2016 11:29 pm
by davenull
what is "mounted" ?
I plug it in and it is opened in the file manager..
I can see the file tree
\media\pi\usb120drv
Posted: Sat Jan 02, 2016 11:32 pm
by asandford
davenull wrote:what is "mounted" ?
\media\pi\usb120drv
What does this command produce?
Posted: Sat Jan 02, 2016 11:33 pm
by davenull
pi@raspberrypi:/media/pi $ df -h
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
/dev/root 28G 3,5G 24G 14% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 463M 0 463M 0% /dev/shm
tmpfs 463M 6,4M 457M 2% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 463M 0 463M 0% /sys/fs/cgroup
/dev/mmcblk0p6 63M 20M 44M 31% /boot
tmpfs 93M 4,0K 93M 1% /run/user/1000
/dev/mmcblk0p5 30M 417K 28M 2% /media/pi/SETTINGS
/dev/sda1 112G 39G 74G 35% /media/pi/USB120DRV
Posted: Sat Jan 02, 2016 11:44 pm
by asandford
davenull wrote:pi@raspberrypi:/media/pi $ df -h
Unix systems are case sensitive (unlike windows), so /media/pi/USB120DRV is not the same as /media/pi/usb120drv
So, try
mkdir -p /media/pi/USB120DRV/pibackup
cd /media/pi/USB120DRV/pibackup/
Posted: Sat Jan 02, 2016 11:49 pm
by davenull
OMG ...
cd USB120DRV is fine
Posted: Sat Jan 02, 2016 11:52 pm
by davenull
pi@raspberrypi:/media/pi/USB120DRV $ sudo tar --exclude=/media/* --exclude=/proc --exclude=/dev --exclude=/tmp --exclude=/run cvzf /media/pi/USB120DRV/pibackup.tar.gz /
Posted: Sat Jan 02, 2016 11:53 pm
by davenull
how I LOVE Linux
Posted: Sat Jan 02, 2016 11:56 pm
by davenull
http://www.gnu.org/fun/jokes/unix-hoax.html
We actually thought of selling this to the Soviets to set their computer science
progress back 20 or more years.
yes.
definitely: yes.
