Raspbian Jessie + Kodi +1080 videos
Posted: Fri Dec 18, 2015 6:00 pm
by ismael280373
Hi all.
I am unable to play 1080 resolution videos on my raspberry pi, on Kodi installed on a vanilla raspbian. I've purchased the codecs thinking that was the problem but once "installed" issue remains.
What I'm doing wrong??
Thanks in advance.
Regards.
Re: Raspbian Jessie + Kodi +1080 videos
Posted: Fri Dec 18, 2015 6:42 pm
by gkreidl
ismael280373 wrote:Hi all.
Thanks in advance.
Regards.
1) Set GPU memory to at least 160 MB.
2) Enable omxplayer in kodi (and for me disabling MMAL gives better results)
3) Some files/streams (TS TV HD) don't play well: use my latest 15.2 release based on popcornmix isenguard backports which fix these issues.
Posted: Fri Dec 18, 2015 7:02 pm
by expandables
Thanks in advance.
Regards.
Put this in your config file
gpu_freq=500
This will overclock the gpu and will let you play any 1080p file.
:twisted:
Posted: Sun Dec 20, 2015 12:40 pm
by ismael280373
Thanks in advance.
Regards.
gpu_freq=500
:twisted:
That did the trick. Thank you, mate.
