delebre
Network Manager GUI or OpenVPN front end?
Sun Jul 29, 2012 6:09 am
I would like to run OpenVPN on my Raspbian "Wheezy" build.
I cannot seem to find a GUI interface I can use to easily install my certificate and import my .ovpn files.
There is no network-manager link available in LXDE as far as I could see.
I installed:
network-manager
network-manager-openvpn
I tried to run
/etc/init.d/network-manager start
But it is already running.
Any help is greatly appreciated! :)
rantanplan
Re: Network Manager GUI or OpenVPN front end?
Mon Sep 03, 2012 8:27 am
you can install network-manager-gnome. Afterward the GUI can be started using the command "nm-applet".
Kind regards,
Christian
pi3g
Authorised Reseller
Authorised Reseller
Wicd
Tue Jul 23, 2013 4:32 pm
I suggest to use Wicd
aptitude install wicd wicd-gtk wicd-curses
Here's an article in German we published just now:
http://blog.pi3g.com/2013/07/funknetzwe ... verwalten/
It has some screenshots, so you'll get the idea probably.
(Note: the gnome network manager suggested in this post did not work for me, so I searched and found wicd)
picockpit.com - tools to make your life with the Pi a little bit easier
Siamak
Fri Feb 24, 2017 4:29 pm
Hi Every one,
I have managed to set-up an OpenVPN server using one of my RasPi's.
I am using windoze to connect to my Server, using .OVBN file which I have copied from the RasPi Server, I nevertheless have a question for you, how can I make my other Raspberry Pi to connect as Client to this server, please advise, I have been trying many things but non of them is working.
I would appreciate if you would help.
Many thanks in advance.
Siamak
CharlesWil
Sun Apr 16, 2017 3:27 pm
Even though I never tried it on my Pi, QuantumGuard probably does the job. https://www.nt-shield.com/downloads/quantumguard
Open-Source, cross-platform, quantum resistant cryptography.
Let me know if it worked on your pi.
Return to “Raspberry Pi OS”
