ragnarjensen
Re: USB Displaylink
Thu Feb 06, 2014 7:27 pm
You have to rebuild the Linux kernel, or at least build a kernel module to enable DisplayLink frame buffer support.
make menuconfig DisplayLink support
I had to build a custom kernel in both 3.6 and 3.10.
Ragnar
ragnarjensen
Re: USB Displaylink
Thu Feb 27, 2014 8:15 pm
Triple play :D
Section "Device"
# RPi builtin video, framebuffer 0
        Identifier      "RPi"
        #Driver         "fbdev"
        Driver          "fbturbo"
        Option          "fbdev"                 "/dev/fb0"
        Option          "SwapbuffersWait"       "true"
        Option          "ShadowFB"              "off"
EndSection
Section "Device"
# USB DisplayLink video, framebuffer 1
        Identifier      "uga"
        #Driver         "fbdev"
        Driver          "fbturbo"
        Option          "fbdev"                 "/dev/fb1"
EndSection
Section "Device"
# USB DisplayLink video, framebuffer 2
        Identifier      "uga2"
        #Driver         "fbdev"
        Driver          "fbturbo"
        Option          "fbdev"                 "/dev/fb2"
EndSection
Section "Monitor"
# Center monitor. HP 1680x1050
        Identifier      "HP"
EndSection
Section "Monitor"
# Right monitor. Dell 1280x1024
        Identifier      "Dell"
EndSection
Section "Monitor"
# Left monitor. LG 1280x1024
        Identifier      "LG"
EndSection
Section "Screen"
        Identifier      "Secondary"
        Device          "RPi"
        Monitor         "HP"
EndSection
Section "Screen"
        Identifier      "Tertiary"
        Device          "uga"
        Monitor         "Dell"
EndSection
Section "Screen"
        Identifier      "Primary"
        Device          "uga2"
        Monitor         "LG"
        #DefaultDepth    24
EndSection
Section "ServerLayout"
        Identifier      "Default"
# The LG and Dell monitors are 1024 pixels high, 26 pixels less than the HP. Place their top-left corners
# 26 pixels below HP monitor's, in order to align monitors along the bottom edge.
        Screen 0        "Primary"               0 26
        Screen 1        "Secondary"             1280 0
        Screen 2        "Tertiary"              2960 26
        Option          "Xinerama"              "true"  # Enable XINERAMA extension to get one desktop over all monitors.
EndSection
One Pi, three screens.
Ragnar
Shovelhead
Re: USB Displaylink
Mon Apr 21, 2014 5:55 pm
I am having having a hard time following your instructions. Is the only requirement is to change the xorg.conf file? Can you simplify? Thanks
ragnarjensen
Re: USB Displaylink
Mon Apr 21, 2014 6:32 pm
No, first you have to get a kernel with drivers for UDL. The stock kernel from the Foundation doesn't have the drivers.
So, you'll have to compile a new kernel from source and there's no simple way to explain how to do that. http://elinux.org/RPi_Kernel_Compilation
If you don't feel up to compiling a kernel, you can try one of these:
I have made an image of Raspbian (for another purpose) that has the UDL drivers.
http://www.element14.com/community/mess ... oad#106822
That is a complete Raspbian distribution that you flash to the SD card.
As an alternative, I have made an archive of just the kernel, that is meant to go on top of an existing Raspbian installation:
http://www.element14.com/community/mess ... oad#107186
When you have a working kernel, it's time to change the xorg.conf file.
Ragnar
Shovelhead
Re: USB Displaylink
Mon Apr 21, 2014 7:04 pm
Thank you for the help Ragnar! I will try to reflash the sd card later today. Then work on the xorg.conf file.
Shovelhead
Re: USB Displaylink
Tue Apr 22, 2014 1:19 am
Ragnar,
I was able to download your file and flash the card.
I will have to work on the config on Wednesday afternoon.
Thanks Ken
Shovelhead
Re: USB Displaylink
Wed Apr 23, 2014 9:30 pm
Ragnar,
I want to make sure I am doing this correctly.
Is this how the xconfig should look? (This is what you posted)
Section "Device"
Identifier "uga0"
driver "fbdev"
Screen 0 <---
EndSection
Section "Device"
Identifier "uga1"
driver "fbdev"
Screen 1 <--- This one says "I have two monitors on the DisplayLink. Use the second."
EndSection
ragnarjensen
Re: USB Displaylink
Thu Apr 24, 2014 7:45 am
No, that one is wrong. In that post I'm pointing out where the errors are in his config.
Try this one out:
Section "Device"
  Identifier "rpi"
  driver "fbdev"
EndSection
Section "Device"
  Identifier "uga"
  driver "fbdev"
EndSection
Section "Monitor"
# Primary monitor.
  Identifier "PrimaryMonitor"
EndSection
Section "Monitor"
# Secondary monitor.
  Identifier "SecondaryMonitor"
EndSection
Section "Screen"
  Identifier "primary"
  Device "rpi"
  Monitor "PrimaryMonitor"
EndSection
Section "Screen"
  Identifier "secondary"
  Device "uga"
  Monitor "SecondaryMonitor"
EndSection
  Identifier "default"
  Screen 0 "primary" 0 0
  Screen 1 "secondary" RightOf "primary"
  Option   "Xinerama" "1"  # enable XINERAMA extension.  Default is disabled.
EndSection
It's a generic config with no bells and whistles. The secondary monitor to the right of the primary.
Ragnar
Henry_Jones
Re: USB Displaylink
Mon Feb 16, 2015 1:48 pm
Even the thread is quiet old and maybe a lot of things changed in the meantime, I'd like to ask if (there is / you can make one up) a how-to for dual Monitor Setup on the raspberry.
I already have the tbtft Driver running together with an Adafruit TFT, From the post in http://www.raspberrypi.org/forums/viewt ... dc035a554a I've copied the xorg-conf contents.
But I always get the X Server start on fb0 regardless of the Option "OneDesk" or "TwoDesk" I use. If I start X with FRAMEBUFFER=/dev/fbx it goes to the correct one.
I guess I'm missing important here, maybe you can point me in the right direction. I also downloaded the image mentioned in this thread, but did not try it yet, fearing that I'll loose the tbtft driver, as they also mention to be working only with a kernel different from the original Rasperian one.
ragnarjensen
Re: USB Displaylink
Mon Feb 16, 2015 9:16 pm
Several things can go wrong if you take my xorg.conf and don't adapt it for your setup.
It's hardcoded for a resolution of 1680x1050 on the HDMI monitor. If yours is different the placement of the physical screens on the virtual desktop will go awry.
A simple
startx
without arguments should start X on /dev/fb1.
startx -- -layout HDMI
should start X on /dev/fb0. Note the double dashes, they're important.
Both "OneDesk" and "TwoDesk" drive both monitors simultaneously. Furthermore, "TwoDesk" requires the ~/.config/autostart/10-desktopmgr-autostart.desktop and ~/bin/desktopmgr.sh scripts I show in the post you refer to.
You could try the very simple xorg.conf I show two posts above just to test that both monitors are alive.
If you need more help, please post the entire /var/log/Xorg.0.log file.
EDIT: Don't use my image or kernel linked to earlier in this thread. They don't have the fbtft drivers .
Ragnar
Henry_Jones
Re: USB Displaylink
Thu Feb 19, 2015 9:13 pm
Ok, I'll try to adapt (and understand) your xorg.conf script better next week ;)
without arguments it always starts on fb0. But the script from this thread works perfect. Both Monitors share one Desktop. That's more than I'd hoped for after two days trying.
Both Monitors (TFT and HDMI) have their own touch inputs which both cover the whole screen instead of only their own range.
So there is still something left to learn, when I'm back in the office next week. If it's more than the common Windows developer can understand, I'll ask again ;)
Thanks for your help.
vedranius
Re: USB Displaylink
Wed Mar 02, 2016 5:35 pm
I know this is an old thread.
But, did anyone ever got working Samsung UbiSync7 display and how?
Thank you! :)
zigzag930
Re: USB Displaylink
Wed Jul 05, 2017 7:17 pm
Would love to see this working, but I've tried it with newest Rabsbian, etc on Rpi3 and when turning on the Xinerama I lose my HDMI.
Without Xinerma, I get HDMI + USB (DisplayLink) monitors both working as independent workstations. Trying to get extended desktop, but no luck.
Have tried the fbdev driver as well as the fbturbo driver. All s/w updated to latest available.
Does anyone have this working on Pi3 with new version of Raspbian (or any other flavor of ARM O/S)?
lordaker
Re: USB Displaylink
Mon Nov 13, 2017 3:03 pm
I have two monitors (Philips Brilliance 220SW), an usb DisplayLink Certified Kensingston K33907 and a raspberry pi 3 model B V1.2
with the OS Ubuntu Mate installed. I install the last kernel 4.9.60-v7+ with the displaylink drivers for ubuntu. But only the monitor who is connected at the adapter work. The monitor connected by HDMI display anything, just the command prompt after the raspberry have
finish to boot.
For my xorg.conf file, I used this process: https://www.novaspirit.com/2015/12/31/l ... pberry-pi/
Do you know how can I do for have my two monitor who work ?
And extended the display from the hdmi ouput to the usb adapter displaylink ?
Which config for my xorg.conf ?
Thank a lot...
lordaker
Re: USB Displaylink
Wed Nov 15, 2017 2:48 pm
I follow this proceed:
After I download the driver from DisplayLink:
http://www.displaylink.com/downloads/ubuntu
I install it and update the Xorg packages too.
This is what I have in my file xorg.conf (/etc/X11/xorg.conf)
Section "Device"
# RPI HDMI Monitor, framebuffer 0
	Identifier "rpi"
	Driver "fbdev"
EndSection
Section "Device"
# USB DisplayLink Adapter Video, framebuffer 1
	Identifier "uga"
	Driver "fbdev"
EndSection
Section "Monitor"
	Identifier "Philips"
EndSection
Section "Monitor"
EndSection
Section "Screen"
	Device "rpi"
	Monitor "Philips"
EndSection
Section "Screen"
Device "uga"
Monitor "Philips"
EndSection
Screen 1 "secondary" LeftOf "primary"
EndSection
The two monitors (Philips) are power on, but my keyboard and my mouse don't work. How can I do to resolve that ?
lordaker
Re: USB Displaylink
Wed Jan 10, 2018 9:12 am
Hello everyone,
I try to connect a second monitor at my Raspberry Pi 3 Model B V1.2 by the usb adapter DisplayLink Kensington. I connect the first monitor to the hdmi port. I update the kernel, configurate the xorg.conf by following this procceed (https://www.novaspirit.com/2015/12/31/l ... pberry-pi/). My two monitors are Philips Brilliance 220SW.
This is what I have when the adapter is not connected.
This is what I have when I connect the adapter to the Rasberry.
Do you known what I could do to resolve that ?
OS: Raspbian Stretch 9.2
ragnarjensen
Re: USB Displaylink
Mon Jan 29, 2018 9:58 am
I think the USB Displaylink driver is included in Raspbian nowadays. You shouldn't have to build it yourself.
As far as I know, the driver only supports USB2 devices. There exists an USB3 driver for Ubuntu, but it's partly closed source and only runs on x86.
Ragnar
hippy
Re: USB Displaylink
Mon Jan 29, 2018 10:55 am
DisplayLink support for USB2 is built into the kernel now. I have found it's best to boot with DisplayLink plugged in as I have had issues with hot-swapping. When plugged in, even if not enabled and being used, I believe the DisplayLink monitor should show a green background.
lordaker
Re: USB Displaylink
Fri Jun 08, 2018 8:41 am
Hello @ragnarjensen,
Now it's work, I add in the /boot/config.txt file the line bellow:
framebuffer_depth=16
with the code foward:
Section "Device"
    Identifier "displaylink"
    Driver "fbturbo"
EndSection
Section "Device"
    Identifier "Raspberry Pi FBDEV"
    Driver "fbturbo"
EndSection
Section "Monitor"
    Identifier "PHILIPS 221E"
EndSection
Section "Monitor"
    Identifier "PHILIPS Brilliance 220SW"
EndSection
Section "Screen"
    Identifier "screen"
    Device "displaylink"
    Monitor "PHILIPS Brilliance 220SW"
    SubSection	"Display"
    		Mode	"1680x1050"
    EndSubSection
EndSection
Section "Screen"
    Identifier "screen1"
    Device "Raspberry Pi FBDEV"
    Monitor "PHILIPS 221E"
EndSection
    Screen 0 "screen1" 0 0
    Screen 1 "screen" RightOf "screen1"
EndSection
But on my second screen I have little resolution all my icons are big. How can I resolve that ?
I use a DisplayLink USB 2.0 to VGA (U2-165-VGA). I try to install xorg-xrandr but when I put the command
xrandr in my terminal emulator I have the message below:
RandR extension missing
ragnarjensen
Re: USB Displaylink
Mon Jun 11, 2018 12:28 pm
The keyword to set screen resolutions is "Modes"
The "Mode" keyword is something very different.
Have you tried without the Subsection Display?
Ragnar
lordaker
Re: USB Displaylink
Tue Jun 12, 2018 1:08 pm
Ragnar
Hello @ragnar
I try without the SubSection but it's always the same thing.
But the command xrandr doesn't work...
ragnarjensen
Re: USB Displaylink
Tue Jun 12, 2018 3:56 pm
And if you have a subsection with Modes in there?
    		Modes	"1680x1050"
EndSubSection
I have never had to use the Randr extension myself.
Ragnar
lordaker
Re: USB Displaylink
Tue Jun 12, 2018 7:14 pm
ragnarjensen wrote: And if you have a subsection with Modes in there?
    		Modes	"1680x1050"
EndSubSection
Ragnar
Yes, it's the same thing. I have the same result... :cry:
What's the matter ? Is it the os ? If you have a solution, please tell me, thank a lot...
ragnarjensen
Re: USB Displaylink
Wed Jun 13, 2018 9:50 am
I have googled a little on your Kensington K33907 DisplayLink adapter.
Apparently it only supports resolutions up to 1440 x 1050.
Ragnar
lordaker
Re: USB Displaylink
Wed Jun 13, 2018 5:27 pm
Ragnar
Hi @ragnarjensen,
Now I use a adapter USB 2.0 to VGA (U2-165-VGA) with a supported resolution bellow:
Widescreen (16/32 bit)
- 1920x1080, 1680x1050, 1600x900, 1440x900, 1360x768, 1280x768, 1280x720
Standard (16/32 bit)
- 1600x1200, 1400x1050, 1280x1024, 1280x960, 1152x864, 1024x768, 800x600
Return to “Raspbian”
