Is the Jessie image expanded?
Posted: Thu Nov 12, 2015 10:32 am
by alexandros301
When using the Jessie image for the first time it doesn't ask you to run "raspi-config". Does this mean that the image is expanded by default?
I did it anyway, and at some point this was printed to the terminal
Command (m for help): The partition table has been altered.
Calling ioctl() to re-read partition table.
Re-reading the partition table failed.: Device or resource busy
Is it something bad?
Re: Is the Jessie image expanded?
Posted: Thu Nov 12, 2015 10:35 am
by RaTTuS
via noobs or raspbian direct
Posted: Thu Nov 12, 2015 10:36 am
by ShiftPlusOne
alexandros301 wrote:When using the Jessie image for the first time it doesn't ask you to run "raspi-config". Does this mean that the image is expanded by default?
No, it shouldn't be anything bad, it won't actually expand fully until you reboot.
Posted: Thu Nov 12, 2015 10:54 am
by alexandros301
Does this mean I must expand the file system on the first boot?
@RaTTus via Raspbian, not NOOBS.
Posted: Thu Nov 12, 2015 12:49 pm
by kusti8
Yes, expand it with the option in raspi-config and then reboot.
