same NOOBS for B+ and 2?
Posted: Tue Nov 03, 2015 3:07 pm
by hank9924
Hi. First timer here. I just ordered a Raspberry Pi 2 starter kit and mistakenly received the Raspberry Pi B+ starter kit. Will all the peripheral stuff (wifi adapter, NOOBS card, power source, heat sinks) that came with the B+ work with the Rasberry Pi 2? The vendor can send me the Raspberry Pi 2 and the 2 case, but does not have it available as a kit, so I'm hoping I can keep all the peripherals and just send them back the B+ and its case. Thanks
Re: same NOOBS for B+ and 2?
Posted: Tue Nov 03, 2015 8:17 pm
by kusti8
If it's updated, then yes. If not, then it's really simple just to make your own. Google is your friend.
Posted: Tue Nov 03, 2015 8:22 pm
by fruitoftheloom
hank9924 wrote:Hi. First timer here. I just ordered a Raspberry Pi 2 starter kit and mistakenly received the Raspberry Pi B+ starter kit. Will all the peripheral stuff (wifi adapter, NOOBS card, power source, heat sinks) that came with the B+ work with the Rasberry Pi 2? The vendor can send me the Raspberry Pi 2 and the 2 case, but does not have it available as a kit, so I'm hoping I can keep all the peripherals and just send them back the B+ and its case. Thanks
You do not need Heat Sinks, hope you did not overpay for this fancy kit ?
http://swag.raspberrypi.org/collections/pi-kits
Posted: Wed Nov 04, 2015 1:46 pm
by hank9924
Well I'm returning it because the company that sold it to me doesn't do exchanges so I guess it doesn't matter!! (Is $50 overpaying?)
Loved the tag line about those who understand binary!
