fbuster
fdisk output on raspbian jessie
Sun Nov 01, 2015 1:16 pm
I am getting output as below on a raspberry pi 2 running jessie.
It seems there are a lot of small ram devices, what is this?
sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 14.9 GiB, 15980298240 bytes, 31211520 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xba2edfb9
Device         Boot  Start      End  Sectors  Size Id Type
/dev/mmcblk0p1        8192   122879   114688   56M  c W95 FAT32 (LBA)
/dev/mmcblk0p2      122880 31211519 31088640 14.8G 83 Linux
Disk /dev/sda: 7.5 GiB, 8004829184 bytes, 15634432 sectors
Disklabel type: dos
Disk identifier: 0xc3072e18
Re: fdisk output on raspbian jessie
Sun Nov 01, 2015 5:20 pm
It is the Jessie and systemd way.
If you want to run fdisk on a specific device name it on the command line
sudo fdisk /dev/mmcblk0
sudo fdisk /dev/sda
Sandbird
Sat Mar 12, 2016 3:50 pm
And i thought it was a corrupted sd lol.
Return to “Raspberry Pi OS”
