nIerSify
Re: Two XBMC (.deb) compiled/prepared for users + instructio
Wed Sep 12, 2012 7:07 pm
terkhen wrote:Sorry, I had a stupid mistake with my last post. I wanted to say that I use Raspbian, but since before that I tried Raspbmc without success, I got confused :)
NP :)
does it work with
sudo /usr/lib/xbmc/xbmc.bin
http://selfprogramming.bplaced.net
terkhen
Thu Sep 13, 2012 4:28 pm
Thank you for your answer. With that command, the XBMC logo appears, after that I can see the default XBMC background (without any buttons yet) for a second before the console appears again. I have tried a few times without success.
nIerSify
Thu Sep 13, 2012 4:40 pm
terkhen wrote:Thank you for your answer. With that command, the XBMC logo appears, after that I can see the default XBMC background (without any buttons yet) for a second before the console appears again. I have tried a few times without success.
i think the problem is, that you haven´t setup the correct memory split. You have to set 128MB/128MB in the raspi-config menu.
Type:
sudo raspi-config
choose "memory_split" and select the proper menu entry and reboot.
After that xbmc should work as aspected :) Hopefully
terkhen
Thu Sep 13, 2012 6:38 pm
I was missing the memory split, yes. Sadly, after that I tried to run XBMC again wit the same command and I got the same results again: XBMC logo, background image, return to console.
nIerSify
Thu Sep 13, 2012 7:01 pm
Can you post or upload your tempory xbmc log file? Its located under your
home/.xbmc/temp/xbmc.log
or
/root/.xbmc/temp/xbmc.log
. It may help to handle your problem....
Best regards
nIerSify
Dweeber
Thu Sep 13, 2012 7:12 pm
nIerSify wrote:I have finished compiling the new xbmc version :) I have tested this xbmc build with the 2012-08-16-wheezy-raspbian image. This build contains nfs, airplay, dvdcss, optical-drive and libcec.
One last thing to say is that i haven´t testet cec support yet, because i don´t have a cec adapter... :roll:
You can download the xbmc package by following this link: http://dl.dropbox.com/u/12601231/Raspi/ ... _armhf.deb
You may have to install the following libraries:
sudo apt-get install libplist1 libmicrohttpd10 libtinyxml2.6.2 libyajl2 libssh-4 libmysqlclient18 liblzo2-2 libfribidi0
nIerSify is this the current version you have available? Weekend is approaching .... will have some time to play. I don't use NFS for my NAS shares but I can switch that around to test. I don't have any way to use CEC though.
Might start early tonight instead of waiting for Sat.
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
nIerSify
Fri Sep 14, 2012 5:33 am
the xbmc version with cec is the latest one i have compiled. I have tried to compile other repositories than this:https://github.com/xbmc/xbmc-rbp.git, but i had no success yet. At the weekend i will try to compile a newer version of xbmc.
Because the developers haven´t make any big changes in the source code you can also use the version from 20120905. Its the same as the latest version, the only difference is libcec. :)
Dweeber
Fri Sep 14, 2012 8:06 am
Just did a quick try and it still won't play any of my ISO's.... I also tried to play the same MP4 files that omxplayer successfully plays and it doesn't do anything... It looks like it is playing, but nothing is showing on the screen. If I use pause or fast forward, you see the control pop up on the screen top right, and it is moving, but nothing is on the screen picture wise nor is there any sound.
omxplayer plays those files without any issues.
Will spend more time on this including gathering log files tomorrow (today actually).
**UPDATE** actually, omxplayer no longer displays on the screen either.... I can however hear the movie playing, just no video. hmmmm... firmware update problem maybe??
nIerSify
Fri Sep 14, 2012 1:33 pm
For those who are facing some problems with my current xbmc build.
Please post ur upload your xbmc.log ("/root/.xbmc/temp/xbmc.log"). This will help to figure out what the problem is.
Make sure that you use the official raspian-wheezy image.
- Update your systems with
sudo apt-get update
and
sudo apt-get upgrade -y
- Select the correct memory split (128/128)
- Start xbmc with
- Check if all required libraries are installed
- xbmc don´t need x. It uses gles. I don´t know what happens if you try to start xbmc out of x
If it´s still not working, i can create a complete image of a fresh raspian installation with xbmc and upload it. :D
terkhen
Fri Sep 14, 2012 2:45 pm
nIerSify wrote:Can you post or upload your tempory xbmc log file? Its located under your
or
Best regards
nIerSify
That was quite helpful. It seems that I was missing some libraries, and that it complained about libcec. Installing all libraries and removing libcec1 solved my problems. It is working now, thank you for all the help! :)
It seems that the screen does not fit my TV, though... a small part of the borders would be "outside" the screen. The same thing happens with Raspbian's default LXDE and even the console, so it is probably a general issue of my installation.
nIerSify
Fri Sep 14, 2012 2:59 pm
Great that it works for you now ;)
To make xbmc fit to your screen you can correct the settings under apprearance in the main menu.
There is a option to reduce the size of the current selected skin. I have to use -4% if im not mistaking.
I can´t look it up right now, because i am setting up a fresh raspbian image with a preinstalled xbmc for sharing it.
P.S if you want to use cec you can install the libcec package, which is listed on my site. (Currently not available, because it is hosted on my pi :D). Otherwise you can ignore the warning in the log file :)
terkhen
Fri Sep 14, 2012 4:26 pm
Thanks, that solved my screen issues. I don't need libcec, so no need to worry about it. Everything seems to work nicely in XBMC now, the only thing I'm missing now is a way to start it automatically on login that does not mess up remote ssh login as just adding the startup command to .bashrc does. Any ideas with regard to this?
Now that I finally have everything working as I wanted I will probably not change my media center image, but if I decide to update it in the future I'll try your raspbian image first. Are you planning to strip it from all unneeded packages too?
nIerSify
Sat Sep 15, 2012 8:14 am
terkhen wrote:Thanks, that solved my screen issues.Are you planning to strip it from all unneeded packages too?
Its the official raspbian wheezy image, which can be found by following this link: http://www.raspberrypi.org/downloads. The only thing i have installed were the libraries needed by xbmc and xbmc itself of course . I have disabled the option to boot into x desktop after starting the raspberry pi.
terkhen wrote: Everything seems to work nicely in XBMC now, the only thing I'm missing now is a way to start it automatically on login that does not mess up remote ssh login as just adding the startup command to .bashrc does. Any ideas with regard to this?
I was facing the same problem. One thing i have tried is to start xbmc automatically on boot, which worked quite well.
To autostart xbmc on boot:
- sudo nano /etc/init.d/xbmc
- copy the script on my blog in this file
- save it, then: chmod +x xbmc
- sudo update-rc.d xbmc defaults
The last command will create symbolic links in all run levels to this script.
If you boot your raspberry pi, xbmc will start automatically.
The problem was, that i have a lot of other services running (pyLoad, flatpress for my blog, samba etc.) So i wanted to save the system resources until i really wanted to watch something on xbmc etc.At the moment i am writing a client, server application for android in order to start xbmc via android app. This works quite well but does need alot of further development. I posted the features of this application on my blog. Unfortunately this post is in german right now. I will translate all the previous posts to english...
gzz
Sat Sep 15, 2012 11:25 am
so what exactly are we looking for in the log file?
I find the installed xbmc binary to be way slower than the raspbmc distro. The scrolling text on the bottom lags and is choppy, and any movie file played is the same. Choppy. Interface is choppy, everything choppy. :-( And I get no sound (edit: sound now fixed). Settings it set for HDMI (which is correct). omxplayer -o hdmi from a command line plays the files fine and with sound. Pi is on 128/128 split.
EDIT: Sound works (by changing to 2.0 instead of capable receivers), but still everything is choppy.
ERROR: Unable to load libcec.so.1, reason: libcec.so.1:
cannot open shared object file: No such file or directory
07:05:04 T:1103912960 ERROR: Could not initialise the CEC adapter: libCEC was
not found on your system
Is that really the problem for choppiness? (although I installed the libcec fromhttp://dl.dropbox.com/u/12601231/libcec/libcec_1.8.0-1_armhf.deb so that doesnt help?)
Other interesting lines perhaps:
07:05:05 T:1103912960 NOTICE: CWinEGLPlatformRaspberryPI::SetDisplayResolution
set HDMI mode (2,1,4)=0
07:05:05 T:1103912960 NOTICE: EGL window and context creation complete
07:05:05 T:1103912960 NOTICE: GL_VENDOR = Broadcom
07:05:05 T:1103912960 NOTICE: GL_RENDERER = VideoCore IV HW
07:05:05 T:1103912960 NOTICE: GL_VERSION = OpenGL ES 2.0
07:05:05 T:1103912960 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1
.00
07:05:05 T:1103912960 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_textu
re GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_
vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_fram
ebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_
BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
07:28:18 T:1102828064 NOTICE: GL: NPOT texture support detected
07:28:19 T:1289126976 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
07:28:19 T:1289126976 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
07:28:21 T:1289126976 WARNING: Previous line repeats 17 times.
07:28:21 T:1289126976 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
07:28:22 T:1289126976 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
07:28:26 T:1289126976 WARNING: Previous line repeats 21 times.
07:28:26 T:1289126976 WARNING: CRenderManager::FlipPage - timeout waiting for fl
nIerSify
Sat Sep 15, 2012 12:13 pm
gzz wrote:so what exactly are we looking for in the log file?
This ist not the problem because most of your videos are chooping. Basically you can ignore this warning in the log. It occours because the libcec library is not installed. I will check if my package fixes this problem.
Edit:
I checked it and it came out that, in case you have installed the libcec package, you have not installed the package correctly, or you missing some libraries. libcec need liblockdev1 in order to work properly. I´ve installed it on fresh raspbian installation and was able to controle my xbmc with my remote tv controle. Check if you have installed libcec with
sudo dpgk -i libcec_1.8.0-1_armhf.deb
and
sudo apt-get install liblockdev1
gzz wrote: 07:28:18 T:1102828064 NOTICE: GL: NPOT texture support detected
I searched these errors in the internet and found this post: http://openelec.tv/forum/134-usage/3633 ... deo-output. It may help you with your problem
Best regards
nIerSify
gzz
Sat Sep 15, 2012 12:46 pm
Appreciate the quick response.
I do have raspbmc working on another sd card, and for example, in raspbmc, if i go to the summary information, it gives me anywhere from 30 to 45 fps. And movies and everything plays perfect.
If i run xbmc.bin under raspian, the summary information is max 15 fps, the the choppiness in videos appears.
weird eh.
I think Im going to through all the settings on raspxbmc, write them down, and make sure they are the same in raspian.
ahh well, half the fun of getting things working is problems and fixing them. ;)
nIerSify
Sat Sep 15, 2012 2:10 pm
I will upload a the latest raspbian wheezy image with a preinstalled version of my xbmc build. You can download this image and try it with your raspberry. Hope that this works better :)
Indeed :D
nIerSify
Sat Sep 15, 2012 6:39 pm
I´ve uploaded a fresh raspbian image with a preinstalled xbmc and libcec. ;)
It is the official raspbian image which can be found here: http://www.raspberrypi.org/downloads
You can download the image by following this link on my http://blog-selfprogramming.dyndns.org/ ... /comments/.
Its a clean installtion with xbmc (airplay, nfs, libcec, dvdcss, optical-drive support) libcec.
It is configured to start xbmc on boot. :D
Username: pi
Password: raspberry
Best regards
nIerSify
teeth_03
Sat Sep 15, 2012 8:29 pm
Suggestion:
Could you implement some kind of boot loader that lets you choose either to startx or xbmc,intead of just booting into xbmc?
I want to try to use both "operating systems" off 1 SD card if I can. Berryboot seems to break stuff, specifically my wifi.
Mertz
Contact: ICQ Website
Sun Sep 16, 2012 12:36 am
teeth_03 wrote:Suggestion:
Read carefully this topic
http://www.raspberrypi.org/phpBB3/viewt ... 84#п156384
You will have 5 seconds to select Raspi or xbmc by tomaz
gzz
Sun Sep 16, 2012 1:40 pm
nIerSify wrote:I´ve uploaded a fresh raspbian image with a preinstalled xbmc and libcec. ;)
Username: pi
Password: raspberry
Best regards
nIerSify
Thanks for sharing this, this version of xmbc works as expected and no stuttering, how do you remove xbmc from bootup? Edit: nm, its /etc/init.d/xbmc for those who are curious (was checking .bashrc or /etc/rc.local)
I couldnt get nfs to work (it doesnt even prompt for a path? is that normal for nfs in xbmc?) Not a big deal, got samba shares, and those do work.
so no idea what was wrong with my raspbian install, who cares, yours works. lol. good enough. :)
Might want to add something like > /dev/null 2>/dev/null to the xbmc init script, as if errors pop up, youre going to get text on the screen which can show up during playback.
gzz
Sun Sep 16, 2012 2:48 pm
whoops, wish I could edit, but I just added nfs shares manually, and its working.
Still get a couple of 'stutters' at the beginning of playback, I assume thats probably due to slower caching over the network.
and its always that in the log
matbos
Sun Sep 16, 2012 5:23 pm
I have accidantally deleted xbmc and now when i try to reinstall i get:
teeth_03
Mon Sep 17, 2012 10:36 am
I would still prefer it not boot automatically, but rather sit at a menu that lets you boot into Rasbian or XBMC, is this possible?
I am working on trying to see if i can get the packagaes to work, currently it just shows the logo then goes to the black screen where it shuts my tv off. I need to verify ram setting, but im fairly sure it was on 128.
teeth_03
Mon Sep 17, 2012 1:23 pm
I confirmed its not working with the 128 split.
I install the libraries as well
When i launch it from the command line, without starting x, i see the logo, and the wallpaper for a second, then shuts the pi off.
Return to “Raspbian”
