r0nnie
Re: Two XBMC (.deb) compiled/prepared for users + instructio
Thu Sep 06, 2012 3:44 pm
hello, are there any noob friendly guides to install libcec with this version of xbmc
or would i need to add it in a fresh install of xbmc?
thanks r0n.
Mertz
Contact: ICQ Website
Thu Sep 06, 2012 3:54 pm
Hi! I'm somewhere on this forum read that the CEC supported on the last image Raspbian 2012-08-16-wheezy-raspbian. Support CEC should be on OS Raspbian, and not on xbmc...
amyren
Thu Sep 06, 2012 5:10 pm
tomaz wrote:Hi Mertz,
maybe XBMC doesn't support MPEG-2 ?
Tomaz.
Mertz wrote:Hello! Thank you for your excellent work, but I do when receiving channels of MPEG-2 from Tvheadend, only sound no picture. MPEG-4 channels, including HD, works fine. Who knows how to fix this problem?
raspbmc is also updated to use the mpeg2 and vc-1 licence keys (see raspbmc.com)
There are some changes in the xbmc git that enables this, if I got the info right from this thread
http://www.raspberrypi.org/phpBB3/viewt ... 4&p=167047
Do you think that you have time to update the xbmc for raspian as well?
It would be much appreciated, thank you.
Mertz
Thu Sep 06, 2012 5:47 pm
XBMC well works with MPEG-2, and it does not need to update of XBMC or Raspbian. For normal work the codec you need to buy and enter the license key to file /boot/config.txt
amyren
Thu Sep 06, 2012 6:00 pm
Mertz wrote:XBMC well works with MPEG-2, and it does not need to update of XBMC or Raspbian. For normal work the codec you need to buy and enter the license key to file /boot/config.txt
That is exactly what I have done, I got my keys by mail today.
I downloaded two test files, one VC-1 HD testfile, and another testfile in mpeg2. I tested booting raspian, and none of this files would play in omxplayer.
Then I inserted the keys inside config.txt and rebooted. Then both files played without any trouble.
But starting up xmbc the same files refuse to play.
Have you tested yourself by testing a file that wont play in xbmc and that will work if you enter the key?
Its strange that raspbmc needed to be recompiled to add this support then.
Mertz
Thu Sep 06, 2012 6:13 pm
Look this post http://www.raspberrypi.org/phpBB3/viewt ... 33#p167033, downloading & write image, then enter licence key MPEG-2. If your have key for VC-1 only, MPEG-2 will not work.
Dweeber
Thu Sep 06, 2012 6:46 pm
Mertz wrote:Look this post http://www.raspberrypi.org/phpBB3/viewt ... 33#p167033, downloading & write image, then enter licence key MPEG-2. If your have key for VC-1 only, MPEG-2 will not work.
The link you are posting is not really the same thing that this thread is about. The link you are posting replaces the Image with a version that includes a new XBMC version. While that is an interesting solution it is not really the same as this thread which allowed you to add XBMC to an existing Rasbpian OS setup.
It would appear that all that is needed is a recompile of the XBMC app like what was done in this thread so that it supports the license key system.
The current XBMC that this thread is about works great on my existing 16GB SDcard... it just doesn't support the new license abilities. It also includes a lot of other packages that I spent time setting up and tuning to work. A new image would not have any of that.
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
matbos
Fri Sep 07, 2012 12:09 pm
WHAT ABOUT CEC SUPPORT ????
amyren
Fri Sep 07, 2012 5:19 pm
Mertz: you are right, it does work now.
I had the files (mpeg2 and vc-1 sample files) on a usb stick. But xbmc didnt play them, I tried both the tomaz version for raspian and raspbmc.
Then I had a look at the /home/pi/.xbmc/temp/xbmc.log file. I noticed there was some error messages concerning a couple of .rar files that also was on the stick. Further down in the log was some error messages about the movie files.
Then I cleaned ut the usb stick, and moved all files exept for the sample files and on emp3 file to a different directory on the stick.
Then I tested next time it all was working, both on Raspian/xbmc and in raspbmc. :)
Dont know what happened, but somehow those other files on the stick must have been messing with xbmc.
nIerSify
Fri Sep 07, 2012 6:10 pm
For those who are interested in a .deb package of the latest xbmc build, i have compiled the latest xbmc build using the compile instructions mentioned by mpthompson in this thread:
http://www.raspberrypi.org/phpBB3/viewt ... 66&t=10304
I´ve configured it additionally with dvdcss and optical drive support. Airplay is also working fine.
I haven´t tested nfs yet... :roll:
I have tested this build against the previous 2012-07-15-wheezy-raspbian image. ;)
You can download it using this link: https://www.dropbox.com/sh/il7is1w4p6bb ... ASf5/Raspi
which i posted in my blog: http://blog-selfprogramming.dyndns.org/ ... pberry-pi/
http://selfprogramming.bplaced.net
Dweeber
Fri Sep 07, 2012 7:25 pm
Cool... will play with it tonight. My 2nd RPi should be here by Saturday to allow for my playing as well, all the parts for it (WiFi, Memory, SDcard) arrived yesterday.
nIerSify
Sat Sep 08, 2012 8:37 am
Dweeber wrote:Cool... will play with it tonight. My 2nd RPi should be here by Saturday to allow for my playing as well, all the parts for it (WiFi, Memory, SDcard) arrived yesterday.
would be nice if you check out the nfs support by trying to connect your xbmc with your NAS :)
P.S
I will compile a new xbmc version next week to try out more features ;)
itsonlyme
Sat Sep 08, 2012 10:48 am
nIerSify
Does this build include the modifications to omxplayer to enable playback of all WMV3 files. This does not yet appear to have reached the XMBC Masters.
This link seems to be the XMBC modification. https://github.com/huceke/xbmc/tree/raspberrypi
nIerSify
Sat Sep 08, 2012 1:38 pm
itsonlyme wrote:nIerSify
No my current build doesn´t contain this modification. I used the repository: git://github.com/xbmc/xbmc-rbp.git for getting the xbmc sources.
I will compile a new version tomorrow and try the repository you mentioned. :)
If it compiles, i will post a download link here in this thread and on my blog ;)
itsonlyme
Sat Sep 08, 2012 2:12 pm
nIerSify
Many Thanks
itsonlyme
Sun Sep 09, 2012 9:51 am
nIerSify
The modifications have now been merged with the XBMC master, so I suggest now just using your normal repository
DraZtiK
Sun Sep 09, 2012 3:52 pm
nIerSify wrote:For those who are interested in a .deb package of the latest xbmc build, i have compiled the latest xbmc build using the compile instructions mentioned by mpthompson in this thread:
Thanks for this...I was wondering if you have experienced the same issue as mentioned here.
nIerSify
Sun Sep 09, 2012 4:41 pm
Cool,
i am cloning the git repository right now. I have compiled libcec to enable it for xbmc. 8-)
I will compile the new xbmc version over night and post a download link if it is successful :)
nIerSify
Mon Sep 10, 2012 7:16 am
I have finished compiling the new xbmc version :) I have tested this xbmc build with the 2012-08-16-wheezy-raspbian image. This build contains nfs, airplay, dvdcss, optical-drive and libcec.
One last thing to say is that i haven´t testet cec support yet, because i don´t have a cec adapter... :roll:
You can download the xbmc package by following this link: http://dl.dropbox.com/u/12601231/Raspi/ ... _armhf.deb
You may have to install the following libraries:
sudo apt-get install libplist1 libmicrohttpd10 libtinyxml2.6.2 libyajl2 libssh-4 libmysqlclient18 liblzo2-2 libfribidi0
nIerSify
Mon Sep 10, 2012 7:14 pm
I use the hdmi output for audio playback so i can´t confirm if my build has the same problems mentioned in the post. If i got some time for experimenting i will try out and see if i have the fluttering effect ;)
nakaori
Wed Sep 12, 2012 10:28 am
Hey,
i am getting:
12:16:39 T:1103175680 NOTICE: CWinEGLPlatformRaspberryPI::SetDisplayResolution set HDMI mode (2,1,16)=0
12:16:39 T:1103175680 ERROR: EGL couldn't create window surface
12:16:39 T:1103175680 NOTICE: EGL not configured correctly. Let's try to do that now...
12:16:39 T:1103175680 ERROR: EGL not configured correctly to create a surface
12:16:39 T:1103175680 FATAL: CApplication::Create: Unable to create window
and on the display information says:
XBMC needs hardware accelerated OpenGL rendering.
Install an appropiate graphics driver.
terkhen
Wed Sep 12, 2012 5:28 pm
nIerSify wrote:I have finished compiling the new xbmc version :) I have tested this xbmc build with the 2012-08-16-wheezy-raspbian image. This build contains nfs, airplay, dvdcss, optical-drive and libcec.
Hello:
I'm trying to use this version in my Raspbmc, but all I am getting is a black screen. I am using RCA output and I have tried to start it by typing "xbmc" on the console. Am I doing something wrong? And, if required, how can I provide you with more interesting information about my problem? I am a newbie in XBMC :)
nIerSify
Wed Sep 12, 2012 6:16 pm
Hello:
If you use Raspbmc OS you shouldn´t install my package. XBMC is already included in Raspbmc and should start automatically. I tested this package against the 2012-08-16-wheezy-raspbian image. If you installed this package you can start xbmc with
sudo /usr/lib/xbmc/xbmc.bin
. If you installed all required libraries it should start straightaway.
nIerSify
Wed Sep 12, 2012 6:17 pm
nakaori wrote:Hey,
i am getting:
Hi :)
have you tried to start it with
terkhen
Wed Sep 12, 2012 6:59 pm
Sorry, I had a stupid mistake with my last post. I wanted to say that I use Raspbian, but since before that I tried Raspbmc without success, I got confused :)
Return to “Raspbian”
