matbos
Re: Two XBMC (.deb) compiled/prepared for users + instructio
Mon Sep 17, 2012 2:29 pm
So here is mine full error code:
[email protected]:/home/pi# sudo dpkg -i xbmc-rdp-tomaz.armhf.deb
(Reading database ... 66082 files and directories currently installed.)
Unpacking xbmc-rdp-tomaz (from xbmc-rdp-tomaz.armhf.deb) ...
dpkg: error processing xbmc-rdp-tomaz.armhf.deb (--install):
trying to overwrite '/usr/bin/xbmc', which is also in package xbmc-20120905 1rpb-1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Removing additional XBMC settings on your RaspberryPi
Coping /boot/arm224_start.elf to /boot/start.elf
update-rc.d: using dependency based boot sequencing
insserv: warning: current start runlevel(s) (3 4 5) of script `lightdm' overwrites defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (0 1 2 6) of script `lightdm' overwrites defaults (0 1 6).
Deleting XBMC from /etc/inittabi...
Deleting XBMC autostart in .bashrc...
sed: can't read /home/pi/.bashrc: No such file or directory
Deleting automount USB for XBMC
Deleting .xbmc settings...
Setting disable_overscan= in your config.txt was NOT changed.
If you need to change it use "sodo rapsi-config"
Arm224_start.elf in your /boot will be used after you REBOOT.
Errors were encountered while processing:
nIerSify
Mon Sep 17, 2012 2:46 pm
teeth_03 wrote:I confirmed its not working with the 128 split.
I install the libraries as well
sudo apt-get install libplist1 libmicrohttpd10 libtinyxml2.6.2 libyajl2 libssh-4 libmysqlclient18 liblzo2-2 libfribidi0
When i launch it from the command line, without starting x, i see the logo, and the wallpaper for a second, then shuts the pi off.
Some libraries are missing. Try this:
libmysqlclient18 liblzo2-2 libfribidi0 libcurl3-gnutls liblockdev1
and then start with
sudo /usr/lib/xbmc/xbmc.bin
If it fails again, pls post your xbmc.log located under /root/.xbmc/temp/xbmc.log
You can also try the image i have uploaded... see this link for more details http://blog-selfprogramming.dyndns.org/ ... /comments/
Best regards
nIerSify
http://selfprogramming.bplaced.net
nIerSify
Mon Sep 17, 2012 2:49 pm
matbos wrote:So here is mine full error code:
It seems that have installed my version before. You have to uninstall the previous xbmc installation before you can install a new one. Try this:
sudo dpkg -r xbmc-20120905
and then
to install the version from tomaz again...
JeremyF
Mon Sep 17, 2012 2:54 pm
Does anyone know how I could add USB IR receiver support to this? Standalone XBMC distros support it, but it seems like Raspbian + XBMC doesn't.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
matbos
Mon Sep 17, 2012 5:17 pm
Thanks, that solved mine problem.
But i have another question. Has anybody figured out how to make cec support working?
nIerSify
Mon Sep 17, 2012 5:55 pm
matbos wrote:Thanks, that solved mine problem.
To make cec support working, you will need a xbmc version with libcec compiled.
My version http://blog-selfprogramming.dyndns.org/ ... /comments/ supports cec.
You have to install libcec.deb from my site
http://blog-selfprogramming.dyndns.org/ ... /comments/ and the required libraries.
http://blog-selfprogramming.dyndns.org/ ... /comments/ After starting xbmc you can controle xbmc with your remote controle, in case your tv supports cec. Otherwise you will need an adapter.
matbos
Tue Sep 18, 2012 1:14 pm
Thanks!
CEC works perfectly with yout instructions, i tried it on my samsung tv. :D
nakaori
Tue Sep 18, 2012 3:55 pm
is anyone else having issues with .mkv files?
i am trying to open a .mkv file i made with makemkv from a movie dvd. vlc says its an mpeg 1/2 stream.
the movie starts, and i hear the sound. but the screen goes black.
also when using the particular video addon "fernsehkritik.tv" i get the same issue.
using a fresh install of xbmc eden on my eee-top plays the movies and the addon like a charm.
nIerSify
Tue Sep 18, 2012 6:12 pm
nakaori wrote:is anyone else having issues with .mkv files?
Had no issues with .mkv playback using this file: http://www.techpowerup.com/downloads/530..._1080p.mkv
nIerSify
Tue Sep 18, 2012 9:16 pm
To keep you guys informed, i made a new post on my blog: http://blog-selfprogramming.dyndns.org/ ... /comments/.
Basically i will compile a new xbmc version on the weekend. I will try to compile it from the mainline tree:
https://github.com/xbmc/xbmc.
If it works out, i will also put the .deb file in a raspbian wheezy image for downloading...
Best regards
nIerSify
teeth_03
Tue Sep 18, 2012 9:46 pm
here is my failed log:
21:29:40 T:1103691776  NOTICE: -----------------------------------------------------------------------
21:29:40 T:1103691776  NOTICE: Starting XBMC (12.0-ALPHA5 Git:20120804-efef226), Platform: Linux (wheezy/sid, 3.2.27+ armv6l). Built on Sep  9 2012
21:29:40 T:1103691776  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
21:29:40 T:1103691776  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
21:29:40 T:1103691776  NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
21:29:40 T:1103691776  NOTICE: special://home/ is mapped to: /root/.xbmc
21:29:40 T:1103691776  NOTICE: special://temp/ is mapped to: /root/.xbmc/temp
21:29:40 T:1103691776  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
21:29:40 T:1103691776  NOTICE: Local hostname: raspberrypi
21:29:40 T:1103691776  NOTICE: Log File is located: /root/.xbmc/temp/xbmc.log
21:29:40 T:1103691776   FATAL: CApplication::Create: Failed to load an AudioEngine
21:29:40 T:1103691776  NOTICE: load settings...
21:29:40 T:1103691776  NOTICE: special://profile/ is mapped to: special://masterprofile/
21:29:40 T:1103691776  NOTICE: loading special://masterprofile/guisettings.xml
21:29:40 T:1103691776  NOTICE: Getting hardware information now...
21:29:40 T:1103691776  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:29:40 T:1103691776  NOTICE: Loaded playercorefactory configuration
21:29:40 T:1103691776  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:29:40 T:1103691776  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:29:40 T:1103691776  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:29:40 T:1103691776  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:29:40 T:1103691776  NOTICE: Default DVD Player: dvdplayer
21:29:40 T:1103691776  NOTICE: Default Video Player: dvdplayer
21:29:40 T:1103691776  NOTICE: Default Audio Player: paplayer
21:29:40 T:1103691776  NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:29:40 T:1103691776  NOTICE: Log level changed to 0
21:29:40 T:1103691776  NOTICE: Loading media sources from special://masterprofile/sources.xml
21:29:41 T:1103691776   ERROR: Unable to load libcec.so.1, reason: libcec.so.1: cannot open shared object file: No such file or directory
21:29:41 T:1103691776   ERROR: Could not initialise the CEC adapter: libCEC was not found on your system.
21:29:41 T:1166525504  NOTICE: Thread XBMC Peripherals start, auto delete: false
21:29:42 T:1103691776  NOTICE: CWinEGLPlatformRaspberryPI::GetSupportedModes (1) = 9, prefer_group=1, prefer_mode=10
21:29:42 T:1103691776  NOTICE: 0: [email protected] :1
21:29:42 T:1103691776  NOTICE: 1: [email protected] :2
21:29:42 T:1103691776  NOTICE: 2: [email protected] :3
21:29:42 T:1103691776  NOTICE: 3: [email protected] :4
21:29:42 T:1103691776  NOTICE: 4: [email protected] I:5
21:29:42 T:1103691776  NOTICE: 5: [email protected] I:6
21:29:42 T:1103691776  NOTICE: 6: [email protected] I:7
21:29:42 T:1103691776  NOTICE: 7: [email protected] N:10
21:29:42 T:1103691776  NOTICE: 8: [email protected] :20
21:29:42 T:1103691776  NOTICE: CWinEGLPlatformRaspberryPI::GetSupportedModes (2) = 8, prefer_group=1, prefer_mode=10
21:29:42 T:1103691776  NOTICE: 0: [email protected] :4
21:29:42 T:1103691776  NOTICE: 1: [email protected] :6
21:29:42 T:1103691776  NOTICE: 2: [email protected] :9
21:29:42 T:1103691776  NOTICE: 3: [email protected] :b
21:29:42 T:1103691776  NOTICE: 4: [email protected] :10
21:29:42 T:1103691776  NOTICE: 5: [email protected] :11
21:29:42 T:1103691776  NOTICE: 6: [email protected] :12
21:29:42 T:1103691776  NOTICE: 7: [email protected] :52
21:29:42 T:1103691776  NOTICE: CWinEGLPlatformRaspberryPI::GetSupportedModes (3) = 0, prefer_group=1, prefer_mode=10
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 640 x 480 @ 60.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 720 x 480 @ 60.000000 Hz
21:29:42 T:1103691776  NOTICE: Previous line repeats 1 times.
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 1280 x 720 @ 60.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 1920 x 1080 @ 60.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 1920 x 1080 @ 24.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 640 x 480 @ 75.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 800 x 600 @ 60.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 800 x 600 @ 75.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 1024 x 768 @ 60.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 1024 x 768 @ 70.000000 Hz
21:29:42 T:1103691776  NOTICE: Found resolution for display 0 with 1024 x 768 @ 75.000000 Hz
21:29:42 T:1103691776  NOTICE: Found ([email protected]) at 32, setting to RES_DESKTOP at 16
21:29:42 T:1103691776  NOTICE: special://profile/ is mapped to: special://masterprofile/
21:29:42 T:1103691776  NOTICE: loading calibration special://masterprofile/guisettings.xml
21:29:42 T:1103691776  NOTICE: Checking resolution 16
21:29:42 T:1103691776  NOTICE: CWinEGLPlatformRaspberryPI::SetDisplayResolution set HDMI mode (2,2,82)=0
21:29:42 T:1103691776  NOTICE: EGL window and context creation complete
21:29:42 T:1103691776  NOTICE: GL_VENDOR = Broadcom
21:29:42 T:1103691776  NOTICE: GL_RENDERER = VideoCore IV HW
21:29:42 T:1103691776  NOTICE: GL_VERSION = OpenGL ES 2.0
21:29:42 T:1103691776  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
21:29:42 T:1103691776  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
21:29:43 T:1103691776  NOTICE: start dvd mediatype detection
21:29:43 T:1103691776  NOTICE: initializing playlistplayer
21:29:43 T:1103691776  NOTICE: DONE initializing playlistplayer
21:29:43 T:1102718016  NOTICE: Thread CDetectDVDMedia start, auto delete: false
21:29:46 T:1103691776  NOTICE: initialize done
21:29:46 T:1103691776  NOTICE: Running the application...
21:29:48 T:1188095040  NOTICE: Thread Jobworker start, auto delete: true
21:29:48 T:1103691776  NOTICE: ES: Starting event server
21:29:48 T:1197204544  NOTICE: Thread CEventServer start, auto delete: false
21:29:48 T:1197204544  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
21:29:48 T:1197204544  NOTICE: UDP: Listening on port 9777
21:29:48 T:1205867584  NOTICE: Thread CTCPServer start, auto delete: false
21:29:48 T:1103691776  NOTICE: starting zeroconf publishing
21:29:48 T:1223205952  NOTICE: Thread Jobworker start, auto delete: true
21:29:48 T:1223205952 WARNING: FillBuffer: curl failed with code 6
21:29:48 T:1223205952   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
21:29:48 T:1223205952   ERROR: Open - failed to open source <http://mirrors.xbmc.org/addons/eden/addons.xml.md5>
21:29:49 T:1102718016  NOTICE: Thread CRssReader start, auto delete: false
21:29:49 T:1102718016 WARNING: FillBuffer: curl failed with code 6
21:29:49 T:1102718016   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
teeth_03
Tue Sep 18, 2012 10:10 pm
would that fact I forgot to expand my partition and only ad 84MB free had any effect on my ability to get this working? I'm expanding it now
nIerSify
Wed Sep 19, 2012 7:16 am
teeth_03 wrote:here is my failed log:
it seems that you haven´t installed libcec correctly.
make sure that you installed my libcec package from here:http://blog-selfprogramming.dyndns.org/ ... /comments/
and installed all the libraries mentioned here:http://blog-selfprogramming.dyndns.org/ ... /comments/
It also seems that your xbmc tries to connect to the xbmc addon repository, which failes. Please make sure that you have internet connectivity when you start your xbmc.
It is just a first analysis of your log. but it may fix your problem :?:
teeth_03
Wed Sep 19, 2012 10:19 am
Im starting over with a fresh install of raspbian, going to make sure to expand the sd card first. It actually started working after i did that, but would freeze shortly after trying to use it.
So i need a special libcec off your blog for that to work?
Quite honestly, i think you need to start another thread, and keep the first post updated and have a list of instructions. 8 pages of thread is hard to follow...
Dweeber
Wed Sep 19, 2012 11:10 am
teeth_03 wrote:Quite honestly, i think you need to start another thread, and keep the first post updated and have a list of instructions. 8 pages of thread is hard to follow...
Unfortunately the forum is setup to not allow updating after posting. You get the Edit button for a short while, but then it disappears. Makes it hard for the forum to be used to provide up to date status on a project.
Could be put into the Wiki, or the OP's could have details on their web/wiki/blog pages like I do (see sig).
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
terkhen
Wed Sep 19, 2012 1:06 pm
nIerSify wrote:I was facing the same problem. One thing i have tried is to start xbmc automatically on boot, which worked quite well.
To autostart xbmc on boot:
- sudo nano /etc/init.d/xbmc
- copy the script on my blog in this file
- save it, then: chmod +x xbmc
- sudo update-rc.d xbmc defaults
The last command will create symbolic links in all run levels to this script.
If you boot your raspberry pi, xbmc will start automatically.
Thanks for your answer! I had no time lately to test this solution, but given the nice updates to Raspberry Pi firmware / Raspbian mentioned in the homepage I think that I will update to your Raspbian image with XBMC preinstalled when/if you switch to the new Raspbian version. I will be checking your blog to keep myself informed about your progress :)
nIerSify
Wed Sep 19, 2012 5:18 pm
I´ve a faq site.....i have to put some more content on this site but maybe this will be enough for user information because i don´t want to setup a wiki on my raspberry pi :D It will slow down the whole system because of the database ;)
nIerSify
Wed Sep 19, 2012 7:21 pm
After having some trouble with my file hoster (uploaded, dropbox), i found a new one that fits best for our needs :) . He provides free downloads, no email or captchas needed.
In order to keep the links alive feel free to take a look at http://blog-selfprogramming.dyndns.org/ ... /comments/
Best regards
nIerSify
teeth_03
Thu Sep 20, 2012 1:28 am
I installed the new raspbian, expanded SD card, update/upgraded, installed the libraries, then the 9/17 xbmc,and i get a shared library error upon trying to launch it. My log is empty, so it doesnt even try to run. This is from the command line before x is started.
[email protected] ~ $ sudo /usr/lib/xbmc/xbmc.bin
/usr/lib/xbmc/xbmc.bin: error while loading shared libraries: libpcrecpp.so.0: cannot open shared object file: No such file or directory
epoke
Thu Sep 20, 2012 4:51 am
teeth_03 wrote:I installed the new raspbian, expanded SD card, update/upgraded, installed the libraries, then the 9/17 xbmc,and i get a shared library error upon trying to launch it. My log is empty, so it doesnt even try to run. This is from the command line before x is started.
sudo apt-get install libpcrecpp0
teeth_03
Thu Sep 20, 2012 12:34 pm
Thanx, that fixed it for me
I finally got it up and running, and works with my windows share and the android app. I was able to pull up a youtube by browsing it on my phone, its pretty neat.
It seems to be a little flaky with my windows share, it sometimes connects, othertimes not so much. I need to test it more
nIerSify
Thu Sep 20, 2012 5:16 pm
i created a new Topic to keep this thread "clean" :) : http://www.raspberrypi.org/phpBB3/viewt ... 66&t=17891
In that thread i will post new downloads and keep you guys informed.
Best regards
nIerSify
teddyyyy
Fri Sep 28, 2012 8:01 am
Thanks for this package.
I installed it , works pretty well.
but there is a problem: the picture viewer seems to stall randomly: sometimes I load a picture, the screen just goes into black, and never comes back. the machine is still responsive, and cpu is low. in fact "ps " shows that xbmc is in "Sl" state. strace -p shows that it's simply doing "nanosleep" all the time.
I suspect that there is a bug causing it to go into endless sleep
nIerSify
Fri Sep 28, 2012 4:16 pm
teddyyyy wrote:Thanks for this package.
pictures works fine for me....but i didn´t test it extensive. I just had problems when browsing images in the folder. There was a problem with creating thumbnails. So i had to disable it...
teddyyyy
Fri Sep 28, 2012 4:55 pm
sorry I mean I installed the package from the first post in this thread, i.e.
wget https://github.com/downloads/RB-tomaz/x ... .armhf.deb
is that what you installed?
video playing seems fine though
Return to “Raspbian”
