alias_neo
Re: Two XBMC (.deb) compiled/prepared for users + instructio
Tue Aug 28, 2012 10:50 am
sammybarlow wrote:I had the same problem with the symlinks...from the wiki you need to run
sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/libEGL.so
sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so
sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so.1
sudo ln -fs /opt/vc/lib/libEGL_static.a /usr/lib/libEGL_static.a
sudo ln -fs /opt/vc/lib/libEGL_static.a /usr/lib/arm-linux-gnueabihf/libEGL_static.a
sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/libGLESv2.so
sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so
sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2
sudo ln -fs /opt/vc/lib/libGLESv2_static.a /usr/lib/libGLESv2_static.a
sudo ln -fs /opt/vc/lib/libGLESv2_static.a /usr/lib/arm-linux-gnueabihf/libGLESv2_static.a
sudo ln -fs /opt/vc/lib/libbcm_host.so /usr/lib/libbcm_host.so
sudo ln -fs /opt/vc/lib/libbcm_host.so /usr/lib/arm-linux-gnueabihf/libbcm_host.so
sudo ln -fs /opt/vc/lib/libvchiq_arm.a /usr/lib/libvchiq_arm.a
sudo ln -fs /opt/vc/lib/libvchiq_arm.a /usr/lib/arm-linux-gnueabihf/libvchiq_arm.a
sudo ln -fs /opt/vc/lib/libvchiq_arm.so /usr/lib/libvchiq_arm.so
sudo ln -fs /opt/vc/lib/libvchiq_arm.so /usr/lib/arm-linux-gnueabihf/libvchiq_arm.so
sudo ln -fs /opt/vc/lib/libvcos.a /usr/lib/libvcos.a
sudo ln -fs /opt/vc/lib/libvcos.a /usr/lib/arm-linux-gnueabihf/libvcos.a
sudo ln -fs /opt/vc/lib/libvcos.so /usr/lib/libvcos.so
sudo ln -fs /opt/vc/lib/libvcos.so /usr/lib/arm-linux-gnueabihf/libvcos.so
They're the ones! Apologies for not getting them pasted as promised, busy morning!
http://2byt.es - Just my two bytes - RPi - Android - Arduino - Blog
gabello
Tue Aug 28, 2012 12:04 pm
Thanks both of you guys, I will try them once I get back home and let you know the result.
gabello
Tue Aug 28, 2012 4:09 pm
I created the symlinks but now I get:
/usr/lib/xbmc/xbmc.bin: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/libEGL.so: file too short
and in /opt/vc/lib/ size of the lib is 0.
-rw-r--r-- 1 root root 0 Aug 28 09:40 libEGL.so
I have the same file in:
[email protected]:~/.rpi-firmware/vc/hardfp/opt/vc/lib# ls -ltra | grep libEGL.so
-rw-r--r-- 1 root root 205372 Aug 18 13:43 libEGL.so
[email protected]:~/.rpi-firmware/vc/hardfp/opt/vc/lib# cd /root/.rpi-firmware/vc/softfp/opt/vc/lib/
[email protected]:~/.rpi-firmware/vc/softfp/opt/vc/lib# ls -ltra | grep libEGL.so
-rw-r--r-- 1 root root 205336 Aug 18 13:43 libEGL.so
I'm also missing (from /opt/vc/lib) the below two files:
alias_neo
Tue Aug 28, 2012 4:17 pm
gabello wrote:I created the symlinks but now I get:
Did you get Hexxeh's rpi-update and run that? I ran that on my Raspbian install before I did all this, perhaps you have some out of date firmware.
gabello
Tue Aug 28, 2012 4:50 pm
I'm on one of the latest kernels. I wonder if an upgrade would actually fix the issue if somehow I uninstalled some needed packages.
alias_neo
Tue Aug 28, 2012 4:55 pm
gabello wrote:I'm on one of the latest kernels. I wonder if an upgrade would actually fix the issue if somehow I uninstalled some needed packages.
Possibly, maybe ask apt-get what packages those files belong to? I can't remember the exact syntax.
gabello
Tue Aug 28, 2012 6:24 pm
I managed to fix this by removing and then installing back libraspberrypi0, but it might be that I messed up other things as I got some errors during reinstall of this package.
Dweeber
Thu Aug 30, 2012 12:38 pm
Just tried this but it wacked out my WiFi.... tried to reinstall the WiFi drivers, but the WiFi is still not working.
If I run xbmc, it pops something up on the screen but then clears the screen so I can't see what it said and I am back at the command prompt. does the same thing as pi or as root.
Headless system, so I will have to fix the edges getting cut off first so I can see what I am typing and do some more digging (reading more of the thread to see if someone else is having similar)
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
Dweeber
Thu Aug 30, 2012 1:42 pm
Would have edited the last post but this forum doesn't allow that ... kinda dumb.
In any case, I was able to get my WiFi back... Had to re-apply the driver more than once.
When running xbmc I see now (from an SSH terminal) the following is error..
/usr/lib/xbmc/xbmc.bin: error while loading shared libraries: libEGL.so: cannot open shared object file: No such file or directory
A quick check using ldd shows:
        libEGL.so => not found
        libGLESv2.so => not found
        libbcm_host.so => not found
        libvcos.so => not found
        libvchiq_arm.so => not found
I see another user is having the same issue.
** UPDATE **
Ahh.. edit button is still there..
I redid the symbolic links and I've got it running. will play now...
matbos
Sat Sep 01, 2012 1:05 pm
I have a problem:
After I have installed your xbmc I cant see taskbar and a few icons on the desktop. Like screen is not synchnorized with raspi desktop...
Dweeber
Sat Sep 01, 2012 5:06 pm
You need to start XBMC and use setup to calibrate the settings to your display. Note you can do this with only a keyboard, no mouse needed.
Dweeber
Sat Sep 01, 2012 5:08 pm
I have been unable to play ANY iso images that I have. Other things work okay. In this mode (with non-dedicated setup), it is a tad bit slow to use but if it played my ISO's that would be good enough.
Dweeber
Sat Sep 01, 2012 10:03 pm
As mentioned above, I am unable to play ISO files... I turned on logging and got a log of what it said.
Not really sure what I should be looking for though..
Log is found:
https://raw.github.com/gist/3588807/bc6 ... 3/xbmc.log
Not sure if there is a different thread I should be posting this in.
digital_addict
Sat Sep 01, 2012 11:46 pm
Dweeber wrote:As mentioned above, I am unable to play ISO files... I turned on logging and got a log of what it said.
Log is found:
This question has been mentioned a few times in a thread called “OpenELEC meets Raspberry Pi - Part 1 (XBMC)”. The only likely answer I found, was that it could be a license issue. This is not gospel, There are 50 pages on this thread and I have not read all of them. I am not an expert.
itimpi
Sun Sep 02, 2012 9:43 am
It was not practical to consider playing .iso files (for DVD's at least) until there was hardware support for mpeg2 decoding because of performance limitations. Now that the mpeg-2 licenses can be bought to do mpeg-2 decoding in the GPUmaybe the Pi version of XBMC will be enhanced to support this as well.
Dweeber
Sun Sep 02, 2012 7:18 pm
I didn't see any mention of MPEG in the output of the log file, so I didn't think of that as being the issue. I have the Mpeg-2 license, but never thought that the XBMC app needed to be updated.
It has been updated in the bundled versions already, but this most likely will need to be updated before it works.
matbos
Mon Sep 03, 2012 2:33 pm
by Dweeber » Sat Sep 01, 2012 6:06 pm
Thanks, that worked for xbmc. but what about raspbian? I have the same problem with it.
Dweeber
Mon Sep 03, 2012 3:28 pm
to be honest, I commented out the entry that was changed in the config.txt so that it uses the default. Has no effect on XBMC after it was configured.
## disable_overscan
##     Set to 1 to disable overscan
##     Value    Description
##     0        Overscan Enabled (Default)
##     1        Overscan Disabled
#disable_overscan=1
Commenting it out is the dame as setting it to default which disables Overscan.
matbos
Mon Sep 03, 2012 5:55 pm
Uf i dont know where can i find config.txt because i dont have disc name written on my file manager (there is just Pi than Desktop) ... But no other disc names like mmcblk0
Dweeber
Mon Sep 03, 2012 6:08 pm
config.txt is located in the /boot partition.
If you are booting and accessing the RPi from SSH or direct from the console...
/boot/config.txt
Note it may not be as commented as mine is. I have added the fully commented version Ref: http://ly.tnet.com/U.
In any case, all you need to do is find the line:
disable_overscan=1
And comment it out.
matbos
Mon Sep 03, 2012 6:45 pm
Thanks that worked fine :)
matbos
Tue Sep 04, 2012 6:44 pm
I have another quastion:
Could i use buttons on remote control of tv for controling xbmc?
I tryed to turn on this in system settings of xbmc but nothing worker :cry:
Dweeber
Tue Sep 04, 2012 7:46 pm
If you have a android phone or tablet you can use a remote app. there are similar things for the iDevices as well.
I use one on both my Nexus 7 tablet and HTC Rezound phone.
The app I am using is: https://play.google.com/store/apps/deta ... oid.remote
matbos
Wed Sep 05, 2012 12:49 pm
No... I was thinking more about remote control of tv, with cec.
http://www.raspberrypi.org/archives/1839
Mertz
Contact: ICQ Website
Thu Sep 06, 2012 1:24 am
Mertz wrote:Hi! Maybe someone is interested, especially lazy :), I suggest to download the image Raspberri Pi, including xbmc by Tomaz
http link: http://www.letayka.tv/2012-08-16-wheezy ... -tomaz.rar
Everything fine works us Plug-N-Play on the SD 2GB. Set time zone GMT +4 (Moscow). Can be changed via sudo raspi-config
Updated image, with the latest updates whis the overclocking CPU to 900 MHz, small adjustments to the stable operation of the video in the file config.txt
Have Fan!
Return to “Raspbian”
