Jessie : Removing Java [SOLVED]
Posted: Fri Oct 09, 2015 5:37 pm
by hippy
For Wheezy my notes say that to get rid of Java; "sudo apt-get remove --purge oracle-java7-jdk".
I am guessing with Jessie it's now "sudo apt-get remove --purge oracle-java8-jdk", but that seems to want to bring in a whole load of other stuff ...
The following extra packages will be installed:
  ca-certificates-java gnome-mime-data icedtea-7-jre-jamvm java-common
  libatk-wrapper-java libatk-wrapper-java-jni libbonobo2-0 libbonobo2-common
  libcanberra0 libgconf2-4 libgnome-2-0 libgnome2-0 libgnome2-bin
  libgnome2-common libgnomevfs2-0 libgnomevfs2-common libgnomevfs2-extra
  libice-dev liborbit-2-0 libpthread-stubs0-dev libsm-dev libx11-dev
  libx11-doc libxau-dev libxcb1-dev libxdmcp-dev libxt-dev openjdk-7-jdk
  openjdk-7-jre openjdk-7-jre-headless tzdata-java x11proto-core-dev
  x11proto-input-dev x11proto-kb-dev xorg-sgml-doctools xtrans-dev
Suggested packages:
  default-jre equivs libbonobo2-bin libcanberra-gtk0 libcanberra-pulse
  libgnomevfs2-bin libice-doc libsm-doc libxcb-doc libxt-doc openjdk-7-demo
  openjdk-7-source visualvm icedtea-7-plugin sun-java6-fonts
  fonts-ipafont-gothic fonts-ipafont-mincho ttf-wqy-microhei ttf-wqy-zenhei
  fonts-indic
The following packages will be REMOVED:
  oracle-java8-jdk*
The following NEW packages will be installed:
0 upgraded, 36 newly installed, 1 to remove and 0 not upgraded.
Need to get 62.5 MB of archives.
After this operation, 77.5 MB disk space will be freed.
So what's the best way to get rid of as much Java related stuff as I can as I have no current interest in using Java and want to maximise SD card space for what I do have interest in ?
Re: Jessie : Removing Java
Posted: Fri Oct 09, 2015 5:46 pm
by ShiftPlusOne
try this
sudo apt-get remove --purge oracle-java8-jdk openjdk-7-jre oracle-java7-jdk openjdk-8-jre
Posted: Fri Oct 09, 2015 5:59 pm
by hippy
Excellent, thanks. 204MB removed. It all adds up!
