channemann
Reset USB Stack in Jessie
Fri Oct 09, 2015 2:32 am
On an RPi2 Model B with Wheezy installed, I was able to reset the USB stack using:
sleep 0.1
echo 0 > /sys/devices/platform/bcm2708_usb/buspower
sleep 1
echo 1 > /sys/devices/platform/bcm2708_usb/buspower
sleep 2
However, on a Jessie install,
does not exist.
Is there another way to power-cycle the USB ports programmatically in Jessie?
channemann
Re: Reset USB Stack in Jessie
Sat Oct 10, 2015 4:37 pm
Found the answer elsewhere; looks like the device ID is different and has moved. This worked:
echo 0 > /sys/devices/platform/soc/3f980000.usb/buspower
sleep 2
echo 1 > /sys/devices/platform/soc/3f980000.usb/buspower
sleep 3
(specifics of sleep durations not finely tuned, so this may be optimizable for other applications)
virtualguy
Sat Feb 20, 2016 10:42 pm
As far as I can tell your suggestion disables the usb module inside the SOC so it stops talking to the USB hub. It doesn't actually disable the power to the USB ports on a Raspberry Pi B+. I imagine it WOULD work for a Raspberry Pi A+
Return to “Raspberry Pi OS”
