plugwash
Re: Packages from debian you want to see in raspbian reposit
Tue Jul 31, 2012 3:36 pm
AlArenal wrote: Found similar errors mentioned on the web using gcc 4.7 trying to compile for Fedora 17 ARM. Out of curiosity: What is the "right" / supposed way to try to compile the package on the Pi to be able to provide a pkg? I may have time and motivation to give it a try but I lack experience in building stuff for repos, etc.
same as on any other debian system, you unpackk the source package, change into the directory that has just been created and use dpkg-buildpackage to build it.
SamuelDebruyn
Wed Aug 01, 2012 9:50 am
Please add forked-daapd. I was using it in the official debian squeeze image from the backports repo so I think it's in sid or wheezy.
Altivo
Wed Aug 01, 2012 11:31 am
It's nice to see hercules in there.
Seems as if x3270 should be a natural complement to it, though.
plugwash
Wed Aug 01, 2012 1:01 pm
SamuelDebruyn wrote:Please add forked-daapd. I was using it in the official debian squeeze image from the backports repo so I think it's in sid or wheezy.
It seems that debian recently dropped this on all architectures except i386 and amd64. See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=642469
I could remove it and put in the last version before the gcd series started but i'm reluctant to ship a server package for which I know there will be no security support.
Thoughts?
plugwash
Wed Aug 01, 2012 1:06 pm
Altivo wrote: Seems as if x3270 should be a natural complement to it, though.
It in non-free which we have yet to sort out autobuilding for (which reminds me I need to talk to mpthompson about the migration to recent wanna-build)
SamuelDebruyn
Wed Aug 01, 2012 1:28 pm
Thoughts?
I agree that's it not secure to include it in the repo. In my case, it will only be used on my LAN so I don't care that much about security, so I should look for a .deb of an older version for amhf? Any idea where I can find that?
plugwash
Wed Aug 01, 2012 2:05 pm
I don't think you will find an armhf deb that will run on the Pi (official debian armhf package will not run on the Pi because their CPU requirements are too high)
You should be able to grab the source package and build it yourself though
wget http://snapshot.debian.org/archive/debi ... ian.tar.gz
wget http://snapshot.debian.org/archive/debi ... 0.19-1.dsc
wget http://snapshot.debian.org/archive/debi ... rig.tar.gz
dpkg-source -x forked-daapd_0.19-1.dsc
cd forked-daapd-0.19
dpkg-buildpackage
SamuelDebruyn
Wed Aug 01, 2012 2:25 pm
Succesfully installed the dependencies but got some build errors. I don't know enough about compiling packages to solve them. Could you take a look? Thanks in advance!
Btw, my locale is Dutch. "fout" means error and "map" means directory.
[email protected] ~/forked-daapd-0.19 $ dpkg-buildpackage
dpkg-buildpackage: source package forked-daapd
dpkg-buildpackage: source version 0.19-1
dpkg-buildpackage: source changed by Julien BLACHE <[email protected]>
dpkg-buildpackage: host architecture armhf
 dpkg-source --before-build forked-daapd-0.19
 fakeroot debian/rules clean
dh_testdir
dh_testroot
rm -f autotools-stamp build-stamp
# Add here commands to clean up after the build process.
[ ! -f Makefile ] || /usr/bin/make distclean
rm -f config.sub config.guess
dh_clean
 dpkg-source -b forked-daapd-0.19
dpkg-source: info: using source format `3.0 (quilt)'
dpkg-source: info: building forked-daapd using existing ./forked-daapd_0.19.orig.tar.gz
dpkg-source: warning: ignoring deletion of file config.sub
dpkg-source: warning: ignoring deletion of file config.guess
dpkg-source: info: building forked-daapd in forked-daapd_0.19-1.debian.tar.gz
dpkg-source: info: building forked-daapd in forked-daapd_0.19-1.dsc
 debian/rules build
ln -s /usr/share/misc/config.sub config.sub
ln -s /usr/share/misc/config.guess config.guess
touch autotools-stamp
dh_testdir
./configure \
		--host=arm-linux-gnueabihf --build=arm-linux-gnueabihf \
		--prefix=/usr --sysconfdir=/etc \
		--localstatedir=/var --mandir=\${prefix}/share/man \
		--enable-flac --enable-musepack \
		--enable-itunes
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for arm-linux-gnueabihf-gcc... arm-linux-gnueabihf-gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether arm-linux-gnueabihf-gcc accepts -g... yes
checking for arm-linux-gnueabihf-gcc option to accept ISO C89... none needed
checking dependency style of arm-linux-gnueabihf-gcc... gcc3
checking how to run the C preprocessor... arm-linux-gnueabihf-gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for arm-linux-gnueabihf-gcc... (cached) arm-linux-gnueabihf-gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether arm-linux-gnueabihf-gcc accepts -g... (cached) yes
checking for arm-linux-gnueabihf-gcc option to accept ISO C89... (cached) none needed
checking dependency style of arm-linux-gnueabihf-gcc... (cached) gcc3
checking whether arm-linux-gnueabihf-gcc and cc understand -c and -o together... yes
checking build system type... arm-unknown-linux-gnueabihf
checking host system type... arm-unknown-linux-gnueabihf
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by arm-linux-gnueabihf-gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 805306365
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert arm-unknown-linux-gnueabihf file names to arm-unknown-linux-gnueabihf format... func_convert_file_noop
checking how to convert arm-unknown-linux-gnueabihf file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for arm-linux-gnueabihf-objdump... no
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for arm-linux-gnueabihf-dlltool... no
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for arm-linux-gnueabihf-ar... no
checking for ar... ar
checking for archiver @FILE support... @
checking for arm-linux-gnueabihf-strip... no
checking for strip... strip
checking for arm-linux-gnueabihf-ranlib... no
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from arm-linux-gnueabihf-gcc object... ok
checking for sysroot... no
checking for arm-linux-gnueabihf-mt... no
checking for mt... mt
checking if mt is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if arm-linux-gnueabihf-gcc supports -fno-rtti -fno-exceptions... no
checking for arm-linux-gnueabihf-gcc option to produce PIC... -fPIC -DPIC
checking if arm-linux-gnueabihf-gcc PIC flag -fPIC -DPIC works... yes
checking if arm-linux-gnueabihf-gcc static flag -static works... yes
checking if arm-linux-gnueabihf-gcc supports -c -o file.o... yes
checking if arm-linux-gnueabihf-gcc supports -c -o file.o... (cached) yes
checking whether the arm-linux-gnueabihf-gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for gperf... gperf
checking for antlr3... antlr3
checking sys/wait.h usability... yes
checking sys/wait.h presence... yes
checking for sys/wait.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking for posix_fadvise... yes
checking for strptime... yes
checking for strtok_r... yes
checking for timegm... yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for off_t... yes
checking for ld used by GCC... /usr/bin/ld
checking for shared library run path origin... done
checking for iconv... yes
checking for working iconv... yes
checking for iconv declaration...
         extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for libunistring... yes
checking how to link with libunistring... -lunistring
checking for arm-linux-gnueabihf-pkg-config... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for ZLIB... yes
checking for CONFUSE... yes
checking for AVAHI... yes
checking for SQLITE3... yes
checking for sqlite3_unlock_notify in -lsqlite3... yes
checking if SQLite3 was built with threadsafe operations support... yes
checking for LIBAV... yes
checking for av_lockmgr_register in -lavcodec... yes
checking for MINIXML... yes
checking event.h usability... yes
checking event.h presence... yes
checking for event.h... yes
checking for event_init in -levent_core... yes
checking avl.h usability... yes
checking avl.h presence... yes
checking for avl.h... yes
checking for avl_alloc_tree in -lavl... yes
checking antlr3.h usability... yes
checking antlr3.h presence... yes
checking for antlr3.h... yes
checking for antlr3BaseRecognizerNew in -lantlr3c... yes
checking for antlr3NewAsciiStringInPlaceStream in -lantlr3c... yes
checking for arm-linux-gnueabihf-libgcrypt-config... no
checking for libgcrypt-config... /usr/bin/libgcrypt-config
checking for LIBGCRYPT - version >= 1.2.0... yes (1.5.0)
checking LIBGCRYPT API version... okay
checking for gpg-error-config... /usr/bin/gpg-error-config
checking for GPG Error - version >= 1.6... yes (1.10)
checking for FLAC... yes
checking for TAGLIB... yes
checking for LIBPLIST... yes
checking for ALSA... yes
checking sys/eventfd.h usability... yes
checking sys/eventfd.h presence... yes
checking for sys/eventfd.h... yes
checking for eventfd... yes
checking sys/signalfd.h usability... yes
checking sys/signalfd.h presence... yes
checking for sys/signalfd.h... yes
checking sys/timerfd.h usability... yes
checking sys/timerfd.h presence... yes
checking for sys/timerfd.h... yes
checking for timerfd_create... yes
checking size of void *... 4
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking for stdint.h... (cached) yes
checking for ANSI C header files... (cached) yes
checking for sys/wait.h that is POSIX.1 compatible... (cached) yes
configure: creating ./config.status
config.status: creating src/Makefile
config.status: creating sqlext/Makefile
config.status: creating Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
dh_testdir
/usr/bin/make
make[1]: Map '/home/pi/forked-daapd-0.19' wordt binnengegaan
/usr/bin/make  all-recursive
make[2]: Map '/home/pi/forked-daapd-0.19' wordt binnengegaan
Making all in sqlext
make[3]: Map '/home/pi/forked-daapd-0.19/sqlext' wordt binnengegaan
/bin/bash ../libtool --tag=CC   --mode=compile arm-linux-gnueabihf-gcc -DHAVE_CONFIG_H -I. -I..   -DFLAC -DMUSEPACK -DITUNES  -g -O2 -Wall -D_LARGEFILE_SOURCE -MT sqlext.lo -MD -MP -MF .deps/sqlext.Tpo -c -o sqlext.lo sqlext.c
libtool: compile:  arm-linux-gnueabihf-gcc -DHAVE_CONFIG_H -I. -I.. -DFLAC -DMUSEPACK -DITUNES -g -O2 -Wall -D_LARGEFILE_SOURCE -MT sqlext.lo -MD -MP -MF .deps/sqlext.Tpo -c sqlext.c  -fPIC -DPIC -o .libs/sqlext.o
mv -f .deps/sqlext.Tpo .deps/sqlext.Plo
/bin/bash ../libtool --tag=CC   --mode=link arm-linux-gnueabihf-gcc  -g -O2 -Wall -D_LARGEFILE_SOURCE -avoid-version -module -shared  -o forked-daapd-sqlext.la -rpath /usr/lib/forked-daapd sqlext.lo -lunistring
libtool: link: arm-linux-gnueabihf-gcc -shared  -fPIC -DPIC  .libs/sqlext.o   -lunistring  -O2   -Wl,-soname -Wl,forked-daapd-sqlext.so -o .libs/forked-daapd-sqlext.so
libtool: link: ( cd ".libs" && rm -f "forked-daapd-sqlext.la" && ln -s "../forked-daapd-sqlext.la" "forked-daapd-sqlext.la" )
make[3]: Map '/home/pi/forked-daapd-0.19/sqlext' wordt verlaten
Making all in src
make[3]: Map '/home/pi/forked-daapd-0.19/src' wordt binnengegaan
antlr3 -depend DAAP2SQL.g > DAAP2SQL.u
antlr3 -depend DAAP.g > DAAP.u
antlr3 -depend RSP2SQL.g > RSP2SQL.u
antlr3 -depend RSP.g > RSP.u
make[3]: Map '/home/pi/forked-daapd-0.19/src' wordt verlaten
antlr3  DAAP.g
antlr3  RSP.g
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'t'": TODAY, FIELD
As a result, token(s) FIELD were disabled for that input
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'s'": STARTSW, FIELD
warning(209): RSP.g:125:1: Multiple token rules can match input such as "'1'..'9'": INT, DATE
As a result, token(s) DATE were disabled for that input
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'i'": INCLUDES, FIELD
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'d'": DAY, FIELD
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'a'": AND, AFTER, FIELD
As a result, token(s) AFTER,FIELD were disabled for that input
warning(209): RSP.g:131:1: Multiple token rules can match input such as "'"'": QUOTE, STR
As a result, token(s) STR were disabled for that input
warning(209): RSP.g:104:1: Multiple token rules can match input such as "'>'": GREATER, GTE
As a result, token(s) GTE were disabled for that input
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'e'": ENDSW, FIELD
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'m'": MONTH, FIELD
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'w'": WEEK, FIELD
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'o'": OR, FIELD
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'y'": YEAR, FIELD
warning(209): RSP.g:120:1: Multiple token rules can match input such as "'b'": BEFORE, FIELD
warning(209): RSP.g:105:1: Multiple token rules can match input such as "'<'": LESS, LTE
As a result, token(s) LTE were disabled for that input
error(208): RSP.g:131:1: The following token definitions can never be matched because prior tokens match the same input: GTE,LTE,AFTER,DATE,STR
if gperf daap_query.gperf > daap_query_hash.c.tmp; then \
		mv daap_query_hash.c.tmp daap_query_hash.c; \
	elif gperf --version >/dev/null 2>&1; then \
		rm daap_query_hash.c.tmp; \
		exit 1; \
	else \
		touch daap_query_hash.c; \
	fi
if gperf rsp_query.gperf > rsp_query_hash.c.tmp; then \
		mv rsp_query_hash.c.tmp rsp_query_hash.c; \
		rm rsp_query_hash.c.tmp; \
		exit 1; \
	else \
		touch rsp_query_hash.c; \
	fi
if gperf dacp_prop.gperf > dacp_prop_hash.c.tmp; then \
		mv dacp_prop_hash.c.tmp dacp_prop_hash.c; \
		rm dacp_prop_hash.c.tmp; \
		exit 1; \
	else \
		touch dacp_prop_hash.c; \
	fi
if gperf dmap_fields.gperf > dmap_fields_hash.c.tmp; then \
		mv dmap_fields_hash.c.tmp dmap_fields_hash.c; \
		rm dmap_fields_hash.c.tmp; \
		exit 1; \
	else \
		touch dmap_fields_hash.c; \
	fi
make[2]: *** [all-recursive] Fout 1
make[2]: Map '/home/pi/forked-daapd-0.19' wordt verlaten
make[1]: *** [all] Fout 2
make[1]: Map '/home/pi/forked-daapd-0.19' wordt verlaten
make: *** [build-stamp] Fout 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
plugwash
Wed Aug 01, 2012 2:31 pm
Well the actual error is "error(208): RSP.g:131:1: The following token definitions can never be matched because prior tokens match the same input: GTE,LTE,AFTER,DATE,STR"
Unfortunately I don't know anything about antlr so I can't really help you any more.
solutionssquad
Wed Aug 01, 2012 4:49 pm
I desperately second that motion!
MrRauch wrote:libavg
berkelium
libbrowsernode
I really want to get the Xibo Linux client to run so that I can use these for digital signage. I have never really used Linux much and I am just starting to figure this out.
I know I can get this to work if I could compile these packages, but I can't figure it out! Any help would be greatly appreciated.
http://www.cnx-software.com/2012/01/19/ ... or-step-1/
davekempe
Wed Aug 01, 2012 10:13 pm
plugwash wrote:
davekempe wrote:Hi,
I would love to see http://packages.debian.org/wheezy/freerdp-x11
freerdp in rasbian
http://www.freerdp.com/
dealt with
Sweet!
jackokring
Contact: ICQ
Thu Aug 02, 2012 4:14 am
Free42
Google "Free42 source" and obtain the tgz. Needs GTK+ and X.
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
jhasler
Thu Aug 02, 2012 4:21 pm
Please add Libreoffice.
MrRauch
Thu Aug 02, 2012 9:34 pm
plugwash wrote:Further updates
libavg is in the repo.
gdal is still being dealt with (hopefully it should build this time, it nearly completed last time)
Can you give instructions on how to install libavg? I did a apt-get install but it says "Unable to locate package." Again, not the best linux user!
Thanks for any help!
mebepi
Thu Aug 02, 2012 10:46 pm
I was compiling a driver that need kernels headers and find out that there is no package to easily install the kernel in /usr/src
Would be interesting to have a package: linux-headers-`uname -r` to easily install it.
I follow this explanation and then finally successfully compile my kernel module:
https://www.grendelman.net/wp/compiling ... pberry-pi/
And this point out that file: Module.symvers is missing so he provide its own one.
Would be nice if the future pack: linux-headers-`uname -r` the file Module.symvers is also included.
I don't want to compile the full kernel but just being able to compile kernel module on the RPi.
This was the module that I want to compile (a DVB virtual tuner that can access a physical DVB tuner towards the network):
http://code.google.com/p/vtuner/
See my own tuto here:
http://www.nessiedvb.org/forum/viewtopic.php?f=19&t=70
Thanks,
Mebepi
MrRauch
Thu Aug 02, 2012 10:55 pm
I got it installed, didn't even think to use python-libavg, which is the package...
Anyway, found out that Xibo has a package, but I don't know if it can used on the Raspberry Pi. Here is a link to it: http://launchpad.net/xibo/1.3/1.3.0/+do ... 6.0.tar.gz
You can also find the list of packages needed for Xibo here: http://wiki.xibo.org.uk/wiki/Install_Gu ... hon_Client
libboost-python1.40.0 libboost-thread1.40.0 libdc1394-22 libgraphicsmagick++3
libgraphicsmagick3 libavutil49 bzr python-soappy python-feedparser python-serial flashplugin-nonfree
libavcodec52 libavformat52 libswscale0 libsdl1.2debian-pulseaudio libvdpau1
Newer packages would be fine too, I believe.
You guys are amazing. I wish I knew how to package these and post them for others...I just don't have any idea how to do it. Or if I got any errors I don't know where to look.
plugwash
Thu Aug 02, 2012 11:51 pm
MrRauch wrote: You can also find the list of packages needed for Xibo here: http://wiki.xibo.org.uk/wiki/Install_Gu ... hon_Client
ok
Looks like these have been replaced by libboost-python1.49.0 libboost-thread1.49.0
libavutil49 libavcodec52 libavformat52 libswscale0
Looks like these have been replaced by libavutil51 libavcodec53 libavformat53 libswscale2
flashplugin-nonfree
Since this is closed source we can't do anything until/unless adobe release a suitable build. I'd say the chances of adobe releasing an armv6 hardfloat build of flash are similar to those of hell freezing over but I could be wrong.
This no longer seems to exist in debian. It seems debian no longer builds many seperate versions of sdl for different output drivers.
libdc1394-22 libgraphicsmagick++3 libgraphicsmagick3 bzr python-soappy python-feedparser python-serial libvdpau1
All these seem to be in raspbian
victagayun
Fri Aug 03, 2012 11:49 am
i remember running teamviewer in my debian VM.
is it also possible?
plugwash
Fri Aug 03, 2012 3:43 pm
victagayun wrote:i remember running teamviewer in my debian VM.
I can't find any evidence of a package by that name in debian.
bob_binz
Fri Aug 03, 2012 4:06 pm
By VM, I wonder if he means x86 VM, which there is a package for (http://www.teamviewer.com/en/download/dyngate.aspx.) Not aware of any ARM flavour though.
victagayun
Sat Aug 04, 2012 3:12 am
that is correct, it x86. does it mean it is excluded?
i learn entirely my debian experiences thru vm (x86) and still coping on my pi...
bob_binz
Sun Aug 05, 2012 11:45 am
victagayun wrote: that is correct, it x86. does it mean it is excluded?
Yes, unfortunately, there is not a version of teamviewer, afaict, that will work on the pi
squarty
Mon Aug 06, 2012 8:20 pm
Please add Libusb 1.0.9
http://sourceforge.net/projects/libusb/ ... .9.tar.bz2
I see old legacy libusb 0.1.x
pholy
Tue Aug 07, 2012 1:32 am
squarty wrote:Please add Libusb 1.0.9
This probably needs some checking: See http://packages.qa.debian.org/libu/libusb-1.0.html which suggests that libusb-1.0 has just been dropped. It appears to be incompatible with libusb-0.1; and I'm not sure how they fit with libusb2. I don't really have a problem with adding it, but I'm not sure we should drop the 0.1 version. Ubuntu currently (10.4 current??) has both available. I haven't checked Debian releases, though.
blavery
Tue Aug 07, 2012 6:22 am
Is gtkterm a goer?
Return to “Raspbian”
