digidev
Re: Packages from debian you want to see in raspbian reposit
Tue Aug 21, 2012 2:55 am
I would like to see a good port of libretro and retroarch and a gui to pair the ps3 and wii controllers with proper bluetooth integration
ezar
Tue Aug 21, 2012 9:29 am
Can you update transmission to 2.61 please?!
atomix1040
Thu Aug 23, 2012 8:06 pm
Touch drivers for the eGalax USB touch screens, i know UBUNTU has some of those, and those on the eeti webpage work only for HID enabled devices (on the ARM arch), i have a touch screen that's not HID compliant and i can't get any drivers to work.
c_k
Thu Aug 23, 2012 9:21 pm
Phlogi wrote:Due to the low ressources needed by sqlite, a lot of users prefer sqlite over mysql server on their PI. So I'd like to see a package for sqlitemanager (like phpmyadmin for mysql).
http://www.sqlitemanager.org/
Thanks!
How about phpliteadmin instead?
http://code.google.com/p/phpliteadmin/
Wendo
Sat Aug 25, 2012 2:08 am
This isn't a package request, instead it's a kernel module request (doesn't seem to be a kernel module request thread).
Someone has already asked for usbip userspace packages (and they are there now, although may have been all along), however there doesn't appear to be the usbip kernel modules included with the raspbian kernels, which makes the userspace tools kind of useless :)
Can we get the usbip kernel modules included too?
Tanga
Sat Aug 25, 2012 2:15 pm
Thanks for all your hard work.
I have a request for something that is more RPi focused (it's not in the official wheezy repos, though I think it's in the experimental repos). That is ROS (the Robot Operating System). With this program the RPi can be fully realised as a robotics platform. :geek:
There have been some advances made on the forums:
http://www.raspberrypi.org/phpBB3/viewt ... =37&t=6552
But so far it's a very messy business, with things missing. I thought you might have more luck getting it to work - if not, then can we add it once it's all worked out. ie the fuerte version on raspbian, or failing that, the electric build.
The ros.org is down at the moment, otherwise I'd post some more info. I'll try again later and add that info too, so you're not searching too hard.
Thanks!
PS - just found:
http://www.ros.org/wiki/ROSberryPi/Sett ... aspberryPi
So I should be able to get it up and running when my RPi arrives. But I really do think it should be part of the repos.
Raspberry Pi (Raspbian) Tutorials by a fellow noob:
http://noobsquared.blogspot.com.au/
Tanga
Sat Aug 25, 2012 3:01 pm
Sorry for the double post but, in the same vein, I think the Julius speech recognition software should be in the repos. Who doesn't want a voice controlled Raspberry Pi, right?
http://www.aonsquared.co.uk/raspi_voice_control
In the "Installing Julius" section (about 1/4 of the way down the page) is the info on compiling Julius from the CVS source, and the compiler flags that are needed to compile it for Raspbian. Cheers!
carlosfm
Mon Aug 27, 2012 5:20 pm
MenuMaker.
Do you Pi?
AlArenal
Mon Aug 27, 2012 6:48 pm
plugwash wrote:
tomtor wrote: After applying the patch from:
http://sourceforge.net/tracker/index.ph ... tid=301355
and patching rules for gcc-4.7.0 and adding armhf as architecture to control, I could build and run the clisp packages on a qemu raspbian emulator.
The packages and changed files can be downloaded from:
http://tomv.home.xs4all.nl/raspberry/clisp/
Thanks for the help, fixed package uploaded.
Uhh, I missed that message but hust found it in the repo, installed and ran it. You're greatr, guys! I owe you a pint!
DanielBarker
Thu Aug 30, 2012 12:49 pm
Could we please have paml?
There would be at least eight users of this package, that I know of. Which suggests there should be plenty more out there too.
Thank you for all the work,
Daniel Barker
dancytron
Sat Sep 01, 2012 5:26 am
I am not sure this is the right place to request this. I would like you to update the directvnc package from version 1.7 to 1.8 to fix a fatal bug.
It gives the error "Couldn't parse the keyboard mapping file (null)" described here http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=668021 . As it says, it has been fixed in the next version which isn't in Raspian yet.
I found the github and tried to recompile it myself, but failed due mostly to not having the slightest idea what I was doing.
Here is the github. https://github.com/drinkmilk/directvnc
This is a vnc client that is supposedly very light and runs without x.
plugwash
Sat Sep 01, 2012 10:39 am
dancytron wrote:I am not sure this is the right place to request this. I would like you to update the directvnc package from version 1.7 to 1.8 to fix a fatal bug.
And isn't in debian yet either.
I've followed up to the bug report.
dancytron
Sat Sep 01, 2012 10:04 pm
This seems to be the same bug with more information and a patch. http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=677204
kyelo
Sun Sep 02, 2012 11:13 pm
I would like to see a lightweight VOIP/sip client package available in Raspbian, such as Twinkle.
Ekiga is available, but it is pretty heavy, sort of like using an elephant gun to hunt a mouse.
plugwash
Sun Sep 02, 2012 11:56 pm
Twinkle was removed from debian due to depending on old libraries.
Because there was no raspbian release before wheezy i've decided to generally keep arround stuff that is in debian squeeze but is no longer in debian wheezy but be aware such packages are unlikely to get much if anything in the way of security support. having said that twinkle didn't seem to receive any security updates since squeeze release already, I dunno if this means noone found any flaws or that noone could be bothered patching them.
As such i've decided that assuming I can get it to build i'll put twinkle into raspbian. I'd be wary of using it to connect to untrusted stuff though.
plugwash
Mon Sep 03, 2012 9:00 pm
ok twinkle is in.
kyelo
Tue Sep 04, 2012 1:38 am
Plugwash said
ok twinkle is in.
Wow! That was fast!
Thank you very much1
kyelo
Tue Sep 04, 2012 5:49 pm
When I do an "apt-get install twinkle" I get "E. Unable to locate package Twinkle", and when I do a Synaptic search for "VOIP" it is not listed.
Is there a waiting period of some sort before a newly-built package is downloadable?
plugwash
Tue Sep 04, 2012 7:41 pm
did you remember to do apt-get update ?
kyelo
Tue Sep 04, 2012 7:52 pm
@ Plugwash,
Your thought was right on the mark...I forgot!
I have it up and running now.
Jamstah
Tue Sep 04, 2012 11:19 pm
Saying that, xmcd is only in squeeze and sid (not sure why its not in wheezy).
Getting the squeeze source and compiling on the pi seemed to work fine, however.
Licaon_Kter
Wed Sep 05, 2012 10:31 am
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
plugwash
Wed Sep 05, 2012 5:58 pm
It failed to build with an internal compiler error, i'll try and find a workaround (from past experiance building with 4.7 usually works).
plugwash
Thu Sep 06, 2012 12:45 am
ok workaround successful, it should be in the repo soon.
Return to “Raspbian”
