pcote_pi
Jessie taskbar: application list incomplete
Wed Oct 07, 2015 1:46 am
Just updated to Jessie 2015-10-15. I tried to put on the taskbar the shortcuts for icedove, iceweasel and midori and they do not appear on the list.
1) Right click
2) Apps bar Setting
3) Select internet -> not there.
But they are available on the main menu.
devenh
Re: Jessie taskbar: application list incomplete
Thu Oct 22, 2015 6:58 pm
I've seen the same thing. Not a real solution, but I did reinstall Jessie and that solved the problem.
JimmyN
Thu Oct 22, 2015 7:28 pm
I think you can only add applets to the taskbar. If you want to add items from the menu then you add those to the "Launch Bar".
On the left end, next to the "Menu" button, right click on "File Manager", "Terminal" or whatever you have over there and select "Application Launch Bar Settings" from the list. Then you can add items from the menu.
Return to “Raspbian”
