ontheair
Jessie: rc.local vs. systemd
Fri Oct 02, 2015 3:14 pm
Hi everybody,
a big "thank you" to all the people who worked on the Jessie-release of Raspbian! Great work!
I made a dist-upgrade from Wheezy to Jessie and everything works like a charm. No problem at all.
There is just one question left: With systemd my old rc.local seems not to be executed at startup. In my case, I just added one line to my rc.local a long time before. Its the update deamon for TinyTinyRSS:
sudo -u www-data screen -d -m /usr/bin/php /var/www/rss/update.php --daemon
Its not executed anymore on Jessie. So I have to find a way to get this simple command executed at startup. I have to admit that I have never worked with systemd before - and maybe its not necessary to learn everything of this complex system just for this one line that should be executed at startup.
Any ideas or hints to
- get the old rc.local working again
- or put the line somewehere else for execution at startup time?
Thank you for your help!
Joe Schmoe
Re: Jessie: rc.local vs. systemd
Fri Oct 02, 2015 3:28 pm
There's another thread on this same topic (disguised as "Why doesn't it print out my IP address anymore?").
The consensus seems to be that rc.local does get run, but it runs very early (before the network is up - which means that you can't do anything network-y there anymore), and so you probably miss any output of it.
firstness
Fri Oct 02, 2015 3:34 pm
You could check some the information here:
http://blog.iopsl.com/rc-local-compatib ... rch-linux/
In particular:
Tip
You can also handle dependencies by modifying the .service file’s [unit] section to allow proper execution of stuff in /etc/rc.local.
Example
If /etc/rc.local is designed to connect Internet and do something to network interface, you can put After=network.target in the [unit] section, meaning it will only start AFTER network is configured.
ontheair
Fri Oct 02, 2015 3:37 pm
Joe, thank you for your reply!
Yes, I already followed this other thread. And it seems you are right: These two issues seems to have the same cause (executed too early). But anyway, in both cases we still dont have an idea for a workaround or solution.
I could imagine this sceanario:
- Deactivating the execution of rc.local by systemd
- Find another trigger to execute rc.local (maybe by crontab @reboot)
Just an idea. Im not a professional when it comes to this... So any help would be really appreciated!
ontheair
Fri Oct 02, 2015 3:41 pm
@firstness: Thank you for your help!
I am going to test this now and getting back if it works (or not) ;-)
ShiftPlusOne
Fri Oct 02, 2015 3:45 pm
You may want to use 'sudo journalctl' and 'sudo systemctl status rc-local.service' to see the output.
firstness wrote:Example
Unfortunately, that won't work with the current dhcpcd setup.
Systemd doesn't know when the dhcpcd service is 'done' (gets a lease). We've just been playing around a bit with this in the office and seem to have found a solution. Will try to get an update out as soon as it's more thoroughly tested.
ontheair
Fri Oct 02, 2015 3:53 pm
Thats also what I have seen now testing this workaround. After=network.target does not make any difference and the rc.local seems to be executed too early again.
If it helps, this is the output of "systemctl status rc-local.service -l":
● rc-local.service - /etc/rc.local compatibility
   Loaded: loaded (/etc/systemd/system/rc-local.service; enabled)
   Active: active (exited) since Fr 2015-10-02 17:44:34 CEST; 5min ago
  Process: 347 ExecStart=/etc/rc.local (code=exited, status=0/SUCCESS)
 Main PID: 347 (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/rc-local.service
Okt 02 17:44:32 10.0.42.3 sudo[348]: root : TTY=unknown ; PWD=/ ; USER=www-data ; COMMAND=/usr/bin/screen -d -m /usr/bin/php /var/www/rss/update.php --daemon
Okt 02 17:44:32 10.0.42.3 sudo[348]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Okt 02 17:44:32 10.0.42.3 sudo[348]: pam_unix(sudo:session): session closed for user www-data
Okt 02 17:44:34 10.0.42.3 systemd[1]: Started /etc/rc.local compatibility.
So it looks like all is fine, but the daemon (that should be executed by rc.local) is not active.
@ShiftPlusOne: I am looking forward to hear about the soultion you found!
hippy
Fri Oct 02, 2015 4:21 pm
Putting a printf "Within rc.local" within rc.local does show it is being run during boot-up and where. In my experience (Pi-B+), that output can still be seen on the TV when it reaches the CLI login prompt.
firstness
Fri Oct 02, 2015 4:28 pm
As a workaround what if you add "sleep 10" to rc.local above your command?
ontheair
Fri Oct 02, 2015 4:33 pm
In my case the device is running headless, so I can not see it. But anyway, its beyond dispute that rc.local is executed (proofen by the output of systemctl status rc-local.service). Just the point in time is wrong.
I am really looking forward for ShiftPlusOne's ideas! In the meantime I will try to learn a bit about systemd - maybe there is a way to delay the execution or something like this...
Just have seen your reply right now ;-) Yes, a good idea. I will try this tomorrow when I am back!
ShiftPlusOne
Fri Oct 02, 2015 4:41 pm
ontheair wrote:I am really looking forward for ShiftPlusOne's ideas!
Don't want to take the credit for something I had nothing to do with; this was spl's fix. Will keep you posted.
hippy
Fri Oct 02, 2015 5:10 pm
firstness wrote:As a workaround what if you add "sleep 10" to rc.local above your command?
That worked for me and my "My IP address is..." issue, delaying things until the dhcpcd client had run and obtained an IP address.
Added: It appears a fix is being worked on for these issues so possibly the best course is to wait for that unless there is an immediate need to try to get things working.
ShiftPlusOne
Sat Oct 03, 2015 5:45 am
ontheair
Sat Oct 03, 2015 6:49 am
This is working. So its a great workaround!
In this solution the dhcpd is launched by systemd instead of the traditional init script. I checked my setup again and remembered: In this case I am not using dhcpd. The Pi is configured with a static IP and dhcpd is not even installed. So this workaround is no option for me; I have to use the sleep-10-solution instead.
Are you talking about the dhcpd-startup-fix mentioned before or are there other solutions in the pipeline?
Just asking for information and curious purposes - right now I am happy with the delayed execution of rc.local.
hippy
Sat Oct 03, 2015 1:03 pm
Yes, that seems to be the fix. I don't know if it will fix everything and I haven't yet tried it but will and will report back. I believe it ensures dhcpcd is run before rc.local which means the temporary "sleep 10" to hold off rc.local execution can then be removed.
danjperron
Sat Oct 03, 2015 7:01 pm
Did you try to put your script in the crontab instead.
something like
crontab -e
@reboot  sudo -u www-data screen -d -m /usr/bin/php /var/www/rss/update.php --daemon
mntmst
Sat Oct 03, 2015 8:51 pm
You can still install sysvinit, systemd-shim, sysvinit-utils and sysvinit-core if you still want init instead of systemd on your system.
glreese
Tue Nov 03, 2015 5:59 pm
Has there been an update to Jessie for this issue? :? I am experiencing the same problems related to execute timing of rc.local. Trying to boot to Kiosk - all worked w/ Wheezy. Will try the sleep 10 work-around - thank you for that guidance.
Thanks,
ShiftPlusOne
Tue Nov 03, 2015 8:31 pm
in raspi-config, "Wait for Network at Boot" -> " Slow Wait for network connection before completing boot"
nl3prc
Sun Jul 24, 2016 12:48 pm
I also have a problem with rc.local with jessie on te NOOBS system it work´s fine on jessie som of the commands don´t seem to load in my case kissattach is not workin when i enter the some executaqble on the command line it works
when in boot it up in rc.local some of the ax25 commands are not set
howe do i correct this error
IgorGanapolsky
Sun Aug 07, 2016 9:49 pm
I am having a similar issue on the latest Raspbian. I have a command in rc.local to start Ngrok. However, it doesn't start until AFTER I login. I don't understand, how can I make this command execute BEFORE I login?
ccosse
Sat Feb 04, 2017 5:33 pm
I solved rc-local.service startup issues by adding #!/bin/bash at top of /etc/rc.local
dazz100
Wed Apr 26, 2017 10:15 am
My rc.local file already has
#!/bin/sh -e
on the top line.
rc.local fails with errors.
dazz100
Fri Apr 28, 2017 6:46 am
Hello
A fail of rc.local is a significant bug.
I looked at other options, including daemontools. Then I found that daemontools start command is in rc.local, so that's no good.
My application is always on so a delay in starting apps after boot is not a big issue. At present, I have scripts running in crontab that check for specific apps running. eg. autossh. crontab is easy to use but rather crude.
A better solution might be to install upstart.
Dazz
Return to “Raspbian”
