Re: Jessie: How to display "My IP address is" at login promp
Thu Oct 15, 2015 7:39 am
I think the simplest fix for /etc/rc.local is to change
/lib/systemd/system/rc.local.service from
After=network.target
to
After=network-online.target
hippy
Thu Oct 15, 2015 2:30 pm
DougieLawson wrote:After=network-online.target
That did not work for me. It seems the network is considered online before rc.local and dhcpcd are started.
Joe Schmoe
Thu Oct 15, 2015 2:32 pm
On and on they bravely go into the gloom.
ShiftPlusOne
Thu Oct 15, 2015 2:45 pm
network-online.target doesn't REALLY know when you're online. You could put something that tests for connectivity and exits when it's found and run it Before=network-online.target, but I don't see much of a point in doing that.
Until we see services which require network-online.target actually rely on network-online.target in their unit files, we'll just settle for either waiting until an IP is granted before saying the network is up or accepting that the network may or may not be up.
At this stage, the following has been decided:
The headless image will wait for the network and the IP address line will appear.
The full image will not wait for the IP address.
The option will be configurable in rc_gui and raspi-config.
I think the 'right' solution would be to make dhcpcd start 'Before' network-online.target and tell it to wait for an IP address. It would speed up boot, since things which don't require the internet connection are free to start in parallel. However, then rc.local and some other services would need to be changed to start after network-online.target.
Another option is to do the above and not modify any service files. Instead, provide instructions on how to make the change yourself, but that's just shifting the burden to the users.
hippy
Thu Oct 15, 2015 2:58 pm
ShiftPlusOne wrote:I think the 'right' solution would be to make dhcpcd start 'Before' network-online.target and tell it to wait for an IP address. It would speed up boot, since things which don't require the internet connection are free to start in parallel. However, then rc.local and some other services would need to be changed to start after network-online.target.
That would seem to me to be the best and most correct solution.
ShiftPlusOne
Thu Oct 15, 2015 3:19 pm
And perhaps that will be it eventually.
vrx
Sun Nov 29, 2015 7:20 pm
sudo emacs /etc/network/interfaces
# for dhcp
auto eth0
iface eth0 inet dhcp
# manual should be deactivated and auto eth0 added
# for a minimal static address
auto eth0
iface eth0 inet static
address 192.168.0.200
netmask 255.255.255.0
sudo emacs /etc/rc.local
# Print the IP address with red color
_IP=$(hostname -I) || true
RED='\033[0;31m'
NC='\033[0m' # No Color
if [ "$_IP" ]; then
printf "IP address is ${RED} %s ${NC}\n" "$_IP"
rm -f /etc/issue
printf "IP address is ${RED} %s ${NC}\n" "$_IP" >> /etc/issue
cp -f /etc/issue /etc/issue.net
fi
exit 0
Mon Nov 30, 2015 8:28 am
vrx wrote:sudo emacs /etc/network/interfaces
# for dhcp
auto eth0
auto eth0
RED='\033[0;31m'
if [ "$_IP" ]; then
rm -f /etc/issue
fi
exit 0
What are you trying to do?
Static addresses are set in /etc/dhcpcd.conf now. Leave /etc/network/interfaces and /etc/rc.local alone.
Also why emacs? Are you 100% insane?
ronnyvdbr
Thu Feb 04, 2016 8:13 am
To set a static IP address, add below lines to /etc/dhcpcd.conf
interface eth0
static ip_address=192.168.0.x/24
static routers=192.168.0.x
static domain_name_servers=192.168.0.x
(replace the x's with your own details :mrgreen: )
Reboot to apply, or run sudo dhcpcd -n to apply immediately.
To set a static ip address on the fly with immediate effect:
sudo dhcpcd -S ip_address=192.168.0.x/24 -S routers=192.168.0.x -S domain_name_servers=192.168.0.x -n eth0
japi
Re: Jessie: How to display "My IP address is" at login prompt
Thu Jan 18, 2018 6:25 am
Just check "Wait for network" in the Raspberry Pi Configuration, you will get it.
Return to “Raspbian”
