devenh
Re: Jessie Q&A
Wed Oct 21, 2015 1:45 pm
diederik wrote:
devenh wrote:every time I try to run one of my install scripts that worked with Wheezie
Then you need to upgrade your install scripts to work with jessie ...
... and if you want others to help you with that, it may be an idea to post them or when they are public, point to them.
Sorry. Didn't post the install scripts because they were exactly the same as the code that was included in the quoted text that I was replying to. So here is a typical line of what I am executing:
sudo apt-get install samba samba-common-bin
Here is the result:
E: Package 'samba' has no installation candidate
Hope that clears things up :D
diederik
Re: Jessie Q&A
Wed Oct 21, 2015 4:57 pm
Ok, I expected an actual script and not the normal command to install a package.
Can you post the output of 'apt-cache policy' ?
And the contents of '/etc/apt/sources.list' ?
gordon77
Re: Jessie Q&A
Wed Oct 21, 2015 5:11 pm
dom wrote:
gordon77 wrote: Any thoughts on the hdmi mode issue?
Very unlikely to be directly related to Jessie. It will be a firmware issue (that the upgrade to Jessie happened to update).
Create a github issue and we can do some troubleshooting.
Created.
devenh
Re: Jessie Q&A
Wed Oct 21, 2015 6:18 pm
diederik wrote: And the contents of '/etc/apt/sources.list' ?
I checked my script and I see that it replaced sources.list with a Wheezie version of the file. Once this was fixed, things worked much better ;)
Re: Jessie Q&A
Wed Oct 21, 2015 11:12 pm
I don't think it's a firmware issue. I rebooted my B+ today (after rebuilding my /dev/sda1 root filesystem on a hard drive).
When I modprobe'd rtc-ds1307 then modprobe'd i2c-bcm2708 that made /dev/rtc0 and /dev/rtc appear and hwclock works.
This is a doctor free zone.
S.Marwen
Re: Jessie Q&A
Thu Oct 22, 2015 12:52 am
how can i set autologin CLI for costum user? Thanx
gordon77
Re: Jessie Q&A
Thu Oct 22, 2015 12:11 pm
Dougie,
Can you detail what you mean by l modprobe'd...
Re: Jessie Q&A
Thu Oct 22, 2015 1:03 pm
sudo modprobe rtc-ds1307
sudo modprobe i2c-bcm2708
Do that and /dev/rtc and /dev/rtc0 appear.
gordon77
Re: Jessie Q&A
Thu Oct 22, 2015 5:24 pm
Created.
My error, at some time l must have set the buffer width and height in config.txt
ShiftPlusOne
Re: Jessie Q&A
Thu Oct 22, 2015 11:15 pm
Hmm, I've been playing around with the pi with RTC on it and it seems like the way RTC is handled has changed somewhat. There is no longer a hwclock serivce and the task of setting the system time has been moved to the kernel. However, the option to set the system time from rtc is disable in the kernel config. Digging further to see if enabling that option fixes the problem and/or introduces new ones.
jojopi
Re: Jessie Q&A
Thu Oct 22, 2015 11:49 pm
CONFIG_RTC_HCTOSYS is only effective if the RTC driver is compiled in, not a module. It might be interesting to check how much RAM is lost by compiling in all the I²C RTC drivers.
Although the mechanisms have changed, Debian wheezy was equally broken in that it too assumed the kernel would have read the RTC, and its userspace merely corrected for timezone in the case where the hardware was not set on universal time.
The hwclock service never did anything in the presence of udev. I believe that most people who got an RTC to work on wheezy did so by hacking out that restriction.
ShiftPlusOne
Re: Jessie Q&A
Thu Oct 22, 2015 11:55 pm
Oh, interesting. Sounds like the solution might be to provide a working hwclock-equivalent unit that works. Thanks, jojopi.
Malman35
Re: Jessie Q&A
Fri Oct 23, 2015 7:47 am
StuartF wrote:can't help with 2 or 3 but for setting the number of desktops try editing
/home/pi/.config/openbox/lxde-pi-rc.xml
find <desktops> and then <number>
change this to the number of desktops required
save
reboot or go cli and startx.
THANK YOU SO MUCH! :D I had such a hard time functioning with out having 2 desktops. I was able to get the desktop pager on the panel (the bar on top) but when I right clicked the desktop pager settings was greyed out so this was a great fix. ;)
Malman35
Re: Jessie Q&A
Fri Oct 23, 2015 9:58 am
What happened to Chromium? I just recently formatted my sd card (after backing up my files of course) and then installed Jessie. I was installing programs I had before. I had gotten to chromium and this is what happened
[email protected] ~ $ sudo apt-get install chromium
Reading package lists... Done
Building dependency tree
Package chromium is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  chromium-inspector chromium-bsu
E: Package 'chromium' has no installation candidate
I then searched for chromium
[email protected] ~ $ apt-cache search chromium
chromium-inspector - web browser - page inspection support
chromium-l10n - web browser - language packs
So then I tried installing chromium-l10n and this is what I got.
[email protected] ~ $ sudo apt-get install chromium-l10n
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 chromium-l10n : Depends: chromium (>= 46.0.2490.71-1~deb8u1) but it is not installable
E: Unable to correct problems, you have held broken packages.
The reason I like chromium and use it instead of epiphany is because I really do not like epiphany! Before when I used wheezy it was okay but since I have upgraded to jessie I really don't like it! I had written this post 2 times and each time when I was almost done epiphany crashed! It just went away! :x leaving me to write the message all over again! when it happened the second time I just gave up and went and wrote it on a mac. ;)
Re: Jessie Q&A
Fri Oct 23, 2015 10:10 am
Malman35 wrote:What happened to Chromium?
Chromium has been removed as the version in Raspbian Wheezy was to old to be used with Jessie, also Debian no longer support Chromium for ARM.
IF you have the RPi2B ARMv7 you can install Chromium 45:
viewtopic.php?f=63&t=121195
IF you have a RPi B or B+ ARMv6 unfortunately there is no version of Chromium suitable for Jessie...AFAIAA
fyi chromium-l10n is a language pack for Chromium
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
gkreidl
Re: Jessie Q&A
Fri Oct 23, 2015 10:22 am
It's also in the pipplware repository, which you can add. See here:
viewtopic.php?f=66&t=109088&p=832765#p832735
Minimal Kiosk Browser (kweb)
novacausekey
Re: Jessie Q&A
Fri Oct 23, 2015 11:08 am
Hi there, it's my first post here. I just installed Raspbian Jessie on my Pi2 & I'm really pleased with some changes, but I've got some problems with "Raspberry Pi Configuration" app. When I go to "Localisation > Set Keyboard", choose "Polska" (Polish) & click "ok", my keyboard layout change to polish. But Raspbian forgets about it when I restart - then it changes to "UK". How can I force it to save my choice?
kusti8
Re: Jessie Q&A
Fri Oct 23, 2015 11:12 am
gkreidl wrote:It's also in the pipplware repository, which you can add. See here:
I assume only for armv7 or an older version for ARMv6?
There are 10 types of people: those who understand binary and those who don't.
gkreidl
Re: Jessie Q&A
Fri Oct 23, 2015 11:26 am
It comes from the Ubuntu release, so it must be ARMv7 only.
kusti8
Re: Jessie Q&A
Fri Oct 23, 2015 11:37 am
Ah. That's what I thought.
dom
Re: Jessie Q&A
Fri Oct 23, 2015 11:39 am
novacausekey wrote:Hi there, it's my first post here. I just installed Raspbian Jessie on my Pi2 & I'm really pleased with some changes, but I've got some problems with "Raspberry Pi Configuration" app. When I go to "Localisation > Set Keyboard", choose "Polska" (Polish) & click "ok", my keyboard layout change to polish. But Raspbian forgets about it when I restart - then it changes to "UK". How can I force it to save my choice?
I've just checked and this is a known problem. A patch is being tested and will hopefully be available through "apt-get upgrade" soon.
Joe Schmoe
Re: Jessie Q&A
Fri Oct 23, 2015 11:42 am
I noticed this a while back and was told on the forum that it was a "known problem" (which usually translates into "something we're not going to fix...")
I was told that the solution is to use the old CLI raspi-config program - that that method would make the change in a way that would stick. Also note that the new GUI program doesn't allow you to set the Ctrl/Alt/Backspace key, so you need to use the CLI version for that in any case.
dom
Re: Jessie Q&A
Fri Oct 23, 2015 12:37 pm
This should be present now. Please run:
sudo apt-get update && sudo apt-get upgrade
test again, and report back if issue is fixed.
Re: Jessie Q&A
Fri Oct 23, 2015 1:29 pm
Just updated Jessie and this message popped up after reboot
Your Raspbian system has been upgraded to the latest version.
To ensure compatibility with the new version, some configuration files have been overwritten -
if you had customised your system, some of your changes may have been lost.
Your original configuration files have been backed up and put in the directory /home/pi/oldconffiles
dom
Re: Jessie Q&A
Fri Oct 23, 2015 2:34 pm
fruitoftheloom wrote:Just updated Jessie and this message popped up after reboot
I've checked and this is expected. Whenever configuration files are updated a backup of the old ones is made and this message is triggered on next boot.
If you have customised any configuration files your changes may have been overwritten, so this reminds you where to look for the originals.
Normally this can just be ignored assuming all is working as before.
I believe there were some theme files that have been updated recently as the changes were found that improve performance a little.
Return to “Raspbian”
